2006 GSXR 600 shutting off - GSXR.com
post #1 of 2 (permalink) Old 10-17-2016, 11:12 AM Thread Starter
Unhappy 2006 GSXR 600 shutting off
So here is everything I've done so far.... Unfortunately I'm short on $$$$ to take it to a shop so here I am....
The bike started randomly shutting off while riding. I replaced the stator, rectifier and battery. The bike continues to shut off. I checked the wires and plugs everything looks good. Nothing fried. The FI light is not on.
I checked my charging voltage at the battery with the meter and it was from 12 -13 V. The issue is that the stator and rectifier are not charging the battery so after charging it it works but it doesn't recharge. I also had the meter on the battery while bike was on and the voltage kept dropping until bike shut off. Once is shut off, bike doesn't start.
Help please! What else can I check? What am I missing?
SkittlesGixxer06 is offline
post #2 of 2 (permalink) Old 10-17-2016, 12:52 PM
You have diagnosed that the bike isn't charging. Now you need to find out why.
Charge the battery fully.
Unplug stator from r/r.
With bike off measure the resistance between each pair of the 3 stator wires. Should be 0.2 to 1 ohm.
Measure resistance between each stator wire and ground. Must be infinite resistance for all 3.
Start the bike.
Hold revs at 5 k rpm.
Measure AC voltage between each pair of stator wires. Should be at least 65V and within 5% across all 3 readings.
If you are ok so far, stator is good.
It is then either the r/r or bad wiring/connections between the stator/r/r and battery.
What brand of replacement stator and r/r did you use?
I hope not cheap eBay rubbish as that would be like pissing money down the toilet.
Ozsyd600 is online now
