Well, this is for those people who have some knowledge in ecu tuning...
Today I got this idea,to make pit limiter for my K51000...as you know in definition maps there are two neutral maps...you can also set the neutral soft and hard limiter...
My clutch switch is bypassed and wire at ecu is cutted...so no signal to prevent from bike going to neutral map...the clutch switch basically puts ground on this wire and send it to ecu...so my idea was, putting a switch on this wire and sending the ecu that "the clutch is pulled", it will go in neutral map where I set the rpm limiter to 3000RPM...
Uploaded the file and guess what?! The limiter is now in every gear.....I have checked every other options..dont know why, but I think the k51000 doesnt have a neutral map for itself...
Tips welcome...thanks
