u may have just got an excessive amount of water into the intakes. idk how the fuel pump would be damaged from that. if u needed to replace it they are very simple tho.
Check the code and post it here, but I think you should also try running it so the heat allows any excess water to evaporate. You may have water trapped in connectors and that is going to cause all sorts of headaches if you don't get it out of there. Which means you should lift the tank and remove the seat, and start drying everything that's wet. And NEVER powerwash it. I don't even use a hose on it, for this very reason, I use a bottle of water and pour just enough to get the surface I'm working on wet, wash it, rinse it with the bottle, then Dry it. That, or use Optimum No Rinse on a sponge/cleaning pad, then dry it.
Thanks man , I will never power wash again,,, Just an update , Ive noticed the fuel pump isn't delivering fuel when it should , and then randomly will let me start it up. ( The noises it makes when I rev to keep it going really doesn't sound healthy.. I cant believe washing my pride and joy has caused me so much grief. )
any ideas on maybe an immobilised/fuel pump issue ?
You may have water in your fuel pump connector, may have water in your spark plug connectors, may have gotten in your airbox, etc. You need to lift the tank and check
Listen you dont need to be anti water. Your bike isnt allergic to water. I've washed every bike ive had with a hose 100s of times with no issue and been caught in just as many rain storms. Just need to be careful where you get it, know where not to spray and power washing is just not needed. Don't stress anything till you check the code. It's simple. Google Gsxr dealer mode and see what the bike is telling you. Why guess?
So Update is this.. This morning tried to fire it up and its worse. The led display is now showing the digital number 8 on every section (no fault codes just buzzing sound and digital 8 everywhere..
Also battery is showing 9.6v reading ... So I'm buying a new one.
What the hell has happened to my bike lol,
I honestly think water has killed my bike , gotta wait until Tuesday to get it to the dealers which will no doubt charge me a fortune.
It's SO hard to help ppl who don't take the advice given to them after they ask for help.
Good luck.
PS: I deleted your other thread, please just use one thread for all similar issues. Youll be getting answers in two different threads and it will become hard to follow (not that youll listen anyway. Also you were posting these threads in the SITE issues section. Thats for problems with the SITE not your bike. I moved it to the tech section which is for problems with your BIKE.
The new battery helped big time , I've now got the bike running in limp mode.. it's still got really random noises coming from the fuel pump area. And I'm pretty sure the idle is rough.
P.s please excuse me on this site as I am a noob and still getting used to it.
Again with the making another thread? Keep your problem in one thread please.
I noticed you still have an FI light and STILL didn't tell us what it is. You want us to spend our time trying to guess and diagnose over the internet but won't do what we suggest or ask. It's kind of rude and annoying.
ya, what gives? get a paper clip and go get that code! quit guessing already!
if a car has a check engine light on and a running issue, I'd start by plugging an obd2 reader up and ... finding what codes came up so I know where to start
that FI light is like ur check engine light. ur bikes trying to tell u what's wrong in the only way she knows how. u gotta listen to her man, she's asking for u for help :lol:
I cant get the error code read until tomorrow , I'm just trying to get the exact cause so I can make sure the dealership don't rob me as I'm flying out to Spain Thursday and they will have it a week. Also I started a new thread because it's no longer ' the bike wont run after washing'. Now its what the hell is that noise ???
I was hoping someone would of known this problem and told me what it is. So lets say I need a new pump any ideas on the cost ££ ?
all u need to get the code is ur bike and a paperclip. if ur FI light is on, there's an issue with ur bike and that's how u find out what's up.
if ur fuel pump is what ur thinking about replacing, they're not much and pretty easy to change out. u really don't need a dealer or shop to do it. seriously if u can remove ur fairings u have the skill level to change ur fuel pump.
I bought an oem fuel pump off a crashed salvage bike on ebay for like $150ish last year
my advise is pull the code and figure out what's exactly wrong before u start thinking about replacing sh!t. u'll save urself some money and aggravation, trust me
Cheers Dude , im hoping the dealership will actually fix the problem as even thou i could manage it i wont have the time this week and really want it running for when i get back.
It prob IS still all issues from power washing though. Considering it started then.
The noise you hearing is the fuel pump constantly priming and the throttle bodies constantly cycling, suggesting there is still something wrong from getting wet.
Your bike would tell you what was wrong but instead of Googling dealer mode as I suggested many posts ago youd rather just keep trying to start it. Putting it in dealer mode and getting the code takes less time then it did for me to write this post.
So as I mentioned the noise if your throttle bodies. You prob fucked up your STVA with the water (like I also said, same issue as the original). @rv6john , @Chuckster and the factory service manual will be your friends here. There is also MANY threads on both of those codes on this site if you search them. Im guessing your STVA is just friend now and youll need a new one, but they can show you how to test it.
Thanks SRAD600 , I had the codes already and I just wanted to keep it updated on this thread, I will just get the dealership to install a new one. Will that clear both codes and solve my problem you think.
Install a new one.... are you made of money? The plugs for the STVA and STPS are vulnerable to the spray. You could probably fix it if raised the tank, disconnected the STVA and STPS couplers, dried it all the best you could, then just let it sit in the sun for a few hours.
Cheap ebay stva replacement that MAY work for a lil while $300. If you need to go OEM route and it needs a whole kitnkaboodle $1k maybe?
Chuckster wrote the book on STVA diagnosis and repair. WIDELY known as the go to for it on the internet. GOOGLE and do your research. When you find all lines pointing to "The Geek" thats the bible on STVA. If you want help with it, hes the one to listen to. Or throw money at it. Typically with STVA issues the dealerships tell you that you need a whole new throttle body assembly, starts at $1k for parts alone.
You can drop a cell phone in the toilet and it wont work for DAYS after it gets dried out. Just humor us.
So possibly dry it out... hmmm, think I've got some stva research to do. What did you guys think of the ignition sound video, does that sound like the results of c28 and c29 problems?
