Ignition dwell & battery? - GSXR.com
post #1 of 17 (permalink) Old 03-19-2017, 11:58 PM Thread Starter
Hi guys, while editin the dwell times,i also heared that the battery helps a lot loading up the coils,is there better to run higher amp battery? Also are the "energy" coils worth any dollar? Cheers
Sent from my D6603 using Tapatalk
dany1000 is offline
post #2 of 17 (permalink) Old 03-20-2017, 12:59 AM
There's no need for more coil intensity unless you are running more than 13:1 compression on average. Very high compression can actually eliminate spark intensity. Near stock compression it is not necessary.
Carbureted bikes benefit from stronger coils because their fuel mixture is less than optimal, thus needed to completely burn the mixture. Modern day fuel injected bike, there is no need and manufacturers have produced more than optimal coils for the application.
Here is a link that explains things Im referring to in more detail, its worth the read.
High Performance Ignition Coils www.motorcycleproject.com
At my previous shop we built 300hp turbo Hayabusas using stock coils.
post #3 of 17 (permalink) Old 03-21-2017, 10:47 AM Thread Starter
Cool thank you, what would be a good ignition adv. For the 1000 k6? Right now i have set the map 5-6 for the rest and keeping neutral as factory,have also given earlier openings of stva /secondary tb plates / and adjusted afr to 13.2
dany1000 is offline
post #4 of 17 (permalink) Old 03-21-2017, 11:18 AM
The best timing is the timing that doesn't cause your bike to pre-ignite. Which, as you might imagine, is not the same for every bike, so it's smarter to start at a low setting and work your way up.
Timing To Win: Ignition Timing for Maximum Performance - How To - Hot Rod Network
post #5 of 17 (permalink) Old 03-21-2017, 11:20 AM Thread Starter
How do you determine? Stetoscope?
dany1000 is offline
post #6 of 17 (permalink) Old 03-21-2017, 11:54 AM
A listening device will work, but you have to be very careful.
post #7 of 17 (permalink) Old 03-21-2017, 12:02 PM Thread Starter
That at high revs..puff
dany1000 is offline
post #8 of 17 (permalink) Old 03-21-2017, 12:25 PM
Sounds great and forgive me for not knowing what all you have,
But what are you using, Power commander 5? What?
K5 Liter Bike
Originally Posted by Ix_SOUNDWAVE_xI View Post
holy sex on wheels
u sir are screwed now ...
team k5/k6 for a full decade of win!
BOTM- 12/16
post #9 of 17 (permalink) Old 03-21-2017, 12:25 PM Thread Starter
Ecu flash from woolich
dany1000 is offline
post #10 of 17 (permalink) Old 03-21-2017, 01:16 PM
A 5 degree advance helps most folks.
post #11 of 17 (permalink) Old 03-21-2017, 01:20 PM Thread Starter
dany1000 is offline
post #12 of 17 (permalink) Old 03-21-2017, 01:20 PM Thread Starter
Aparently up to 7 by this values
dany1000 is offline
post #13 of 17 (permalink) Old 03-21-2017, 01:26 PM
You can adjust an ECU flash on your own at home?
I thought 5degree was the stock advance, maybe you meant 5 more degrees?
My 'ol Honda 350 twin had a counterbalancer thingy that would advance the timing by centrifigal force with increased rpms by using this spring loaded thingy- at least I think I remember that- was a long time ago.
K5 Liter Bike
holy sex on wheels
BOTM- 12/16
post #14 of 17 (permalink) Old 03-21-2017, 02:01 PM
Motionelco's Avatar
Yup https://www.woolichracing.com/produc...x#productTable
Motionelco is offline
post #15 of 17 (permalink) Old 03-21-2017, 02:19 PM Thread Starter
Thats the one
dany1000 is offline
post #16 of 17 (permalink) Old 03-21-2017, 02:22 PM Thread Starter
The blue cells are the modds i did changing the ign from factory settings 5-6 gear through 1 to 4 leaving neutral factory, dont need a performance map in neutral....some kids might do to be the best neutral revers till blow up...jzzzz
dany1000 is offline
post #17 of 17 (permalink) Old 03-21-2017, 02:26 PM Thread Starter
So,back to issue...how can i best determine this? Increase or decrease values here?? I can add % but i dont have a dyno at home to test torque...maybe just giving it +5% from 6000rpm and 50%tps and above...im quite careful with this..dont want to look through a piston or any similar
dany1000 is offline
