Loss of power PLEASE HELP ME - GSXR.com
post #1 of 7 (permalink) Old 05-17-2017, 11:16 AM Thread Starter
GSXR MANOLO's Avatar
Ok before I completely lose my sanity .... I have a 2007 GSXR 600 with a PC3 and TRE switch installed ...... the pc3 failed on me on the way to panama city and shut the bike down, the battery died and all ... so I just replaced the stator and rectifier and took the pc3 off as well as the TRE switch and I just installed new NGK iv iridium plugs but yet it is still losing power in low rpm in first gear .... can anyone help me resolve this ? Thanks in advance 🤙🏾
GSXR MANOLO is offline
post #2 of 7 (permalink) Old 05-17-2017, 11:47 AM
This should be in the tech section. I asked the mods to move it.
I don't understand the sequence of events. Are you saying the PC killed the battery?
After changing the R/R and stator did you ever check the charging voltage.
I also don't know what you mean by "but yet it is still losing power in low rpm in first gear". Was it doing this before?
You need to up your communication level a bit.
post #3 of 7 (permalink) Old 05-17-2017, 01:18 PM Thread Starter
No I wasn't saying that the PC killed the battery.... I was simply just stating the series of events that happened but however that's irrelevant at this point ...... my bike was running perfectly fine with a TRE switch installed and a PC3 .... somehow the PC3 failed and my bike wouldn't start back up after I cut it off and the battery also died in the process trying to get it to start back up .... so I bought a new battery . New stator and rectifier all OEM PARTS .... I took the TRE switch off the bike which is what tricks the bike into believe it is in 5th gear at all times ... and I took the pc3 off the bike .... now the bike will start up and run and sounds solid while idling but if I turn the throttle it lags around 6k rpm .... i just spoke with a friend moments ago and he stated that he thinks it may be out of tune .... what do you take of the current situation ? Thorough enough ?
post #4 of 7 (permalink) Old 05-17-2017, 01:53 PM
I hope you understand that "yet it is still losing power in low rpm in first gear" and "but if I turn the throttle it lags around 6k rpm" are two different symptoms.
If it is actually the latter, I agree with your friend, you probably need another PC and a tune.
Thank you for explaining what a TRE is.
post #5 of 7 (permalink) Old 05-17-2017, 03:12 PM
The TRE advances timing and removes top speed limit due too as he said ,tell ECM it's in 5th. I did notice it would warm up faster and hit cooling fan much quicker.
post #6 of 7 (permalink) Old 05-17-2017, 03:24 PM Thread Starter
https://video-atl3-1.xx.fbcdn.net/v/...=591E76D1&dl=1
post #7 of 7 (permalink) Old 05-17-2017, 03:25 PM Thread Starter
This is a video of the lagging I was referring to , my buddy had just installed the new stator and rectifier and ngk iv iridium spark plugs
