I AM FIXING MY BIKE TODAY BY REPLACING HTE STATOR COVER AND ALL THE OIL IS GONE... WHAT TYPE of oil DO I NEED TO BUY TONIGHT TO GET IT UP AND RUNNING AGAIN? I can't find my chilton's manual and would like to get this done.
If you don't have access to any motorcycle oil and you want to get it running by tonight, you can purchase car oil such as castral and stuff. I'd run 10w40.
your battery being dead would not have much to do with the oil put in the bike, But whatever you do don't jump it with a car that is running. I would use the syn motor cycle oil if it avaliable (should be at most parts stores) and 10w40 is what I run year round so the weight would be fine. Stay away from syn car oils as they can cause clutch problems. I have read people use shell rotella without any problems and you can get it at walmart.
Steve
thanks for the info; I understand the dead battery was unrelated, I was just remarking that, because I now have more time to get better oil, I will do so.
so I found my manual; it specifies that an '04-'05 GSXR 750 should take SF or SE motor oil 10W-40. It does not say specifically that motorcycle oil should be used nor does it specify synthetic vs. regular. I also do not know whether SG or other grades of oil would be better. I probably ought to read an oil guide but, for the benefit of others, perhaps somebody could provide some input.
motorcycle oils are recommended cause of the high rpms motorcycles turn compare to oil, i use Lucas synthetic motorcyle oil, but have used mobile1 synthetic car oil for yaers with no problems.
