knocking noise - GSXR.com
post #1 of 12 (permalink) Old 07-22-2007, 04:46 PM Thread Starter
Ackrite12's Avatar
knocking noise
Hey guys,
I am experiencing a knocking noise on my 01 gsxr 750. sound seems to be coming from around the front sprocket area.
Now, i changed my chain and front sprocket and still no cure.
noise only noticeable when rear tire is off the ground, freely spinning in 1st gear, sounds like it is something internal. when the knock occurs the chain slightly jerks like a sprocket is missing a tooth and it is slipping (thats why i changed the sprocket and chain).
when im riding i cant hear it or really feel it, even w/ helmet off closely listening.
any inputs or suggestions would be greatly appreciated.
thnks.
Randy
Randy[/FONT]
Ackrite12 is offline
post #2 of 12 (permalink) Old 07-22-2007, 05:23 PM
tsenfw's Avatar
rear wheel aligned well enough? Slack right?
tsenfw is offline
post #3 of 12 (permalink) Old 07-22-2007, 07:32 PM Thread Starter
Ackrite12's Avatar
everything lined up and chain slack is perfect. i was told that 00-01 gsxr 750 have common trans. problems??!
or could it be someting else?
Randy[/FONT]
post #4 of 12 (permalink) Old 07-22-2007, 07:46 PM
johnnylovely's Avatar
Thats normal. It's just the chain binding a bit due to lack of load on the rear tire. The momentum of the rear wheel spins faster than the chain and causes that symptom.
If it happens while you're riding that's another story though.
master moto tech...fire away.
johnnylovely is offline
post #5 of 12 (permalink) Old 07-23-2007, 10:09 PM Thread Starter
Ackrite12's Avatar
johnny .. thnx
hopefully that is the case, just for piece of mind im probably goin to get it checked out
Randy[/FONT]
post #6 of 12 (permalink) Old 07-28-2007, 05:24 AM
nevacme's Avatar
i guess im that other story then....i picked up my girls 750 and take off all i hear is a loud knocking noise...1st thing i thought was a trans problem
05 GSXR XX0 (ready for paint)
00 ESCORT ZX2 S/R
MySpace
nevacme is offline
post #7 of 12 (permalink) Old 07-28-2007, 10:38 AM
Ever oil your chain?
post #8 of 12 (permalink) Old 07-28-2007, 10:45 AM
mladin_jr's Avatar
Have you looked at the bearings in the wheel? They may be shot.
mladin_jr is offline
post #9 of 12 (permalink) Old 02-17-2012, 05:23 PM
i know this is old but im havig the same issue on a 01 also but if u rev it in neutral on a stand it sounds like it catches the front sprocket and clunks. it also makes the sound if its on the ground also. i do know the chain is bad. but that dont expalin how it does it nuetral on a stand. i have been told its a clutch or clutch
afish is offline
post #10 of 12 (permalink) Old 02-17-2012, 05:39 PM
Tripsrad83's Avatar
Cush drive? (The rubber dampers behind your rear sprocket!)
1. Do not argue with an idiot. They will drag you down to their level and beat you with experience.
Tripsrad83 is offline
post #11 of 12 (permalink) Old 02-17-2012, 06:02 PM
any body else have any ideas
afish is offline
post #12 of 12 (permalink) Old 02-25-2012, 06:21 PM
changed the clutch, sprockets and chain and the oil again. helped some what. but i found a peice of metal in the oil almost looked like a tooth off a gear. i just going to ride the bike till it blows and then put in a used motor. idk if its worth rebuilding i dont know what that metal all tore up and i can get a used motor for 800 or so. how much time does it take to swap out a motor.
afish is offline
