Knocking noise at low RPM's??? - GSXR.com
post #1 of 7 (permalink) Old 08-23-2007, 06:49 PM Thread Starter
Hey all, I've got a 2005 750 all stock other than 190 rear tire and yoshi exhaust. Lately I've been hearing a knock when I let out the clutch in first and move about 10 feet. It will also knock below 5k rpm in almost every gear and i can feel it in my left footpeg. It doesn't sound like an engine knock bc its a little louder than that and not very rapid, maybe one knock per second, if that often. I have had no effects on my performance and the knock goes away if i open the throttle more and completely goes away about 5k rpm. Do you guys have any ideas as to what this could be? I'm stumped. Also, I tightened my chain thinking that it could have been the problem, but that didn't solve it. Any ideas would be appreciated.
titleiststud is offline
post #2 of 7 (permalink) Old 08-24-2007, 07:48 AM
Shot Caller
It sounds like a drive train noise - it's possible that you could have your chain too tight, or the chain may have some seized links, or your rear wheel alignment might be off.
Put your bike on a stand, and see if something is clicking or binding when you rotate the wheel by hand.
Mister Tee is offline
post #3 of 7 (permalink) Old 08-24-2007, 01:47 PM Thread Starter
I turned the bike off and rolled it through a parking lot and it doesnt make the noise. I really have no idea what this could be. Chain is within tightness specs and the wheel alignment is good.
post #4 of 7 (permalink) Old 08-27-2007, 08:25 PM
firebrand's Avatar
Pretty new bike for this type of damage, but maybe big-end bearing? Good indication of this if you hear the knock on deceleration.
'86 TS50W
'82 GS1100L
'96 GSX-R1100W
firebrand is offline
post #5 of 7 (permalink) Old 08-28-2007, 08:51 AM Thread Starter
It's only on acceleration and hasn't been doing it since i lubed my chain up really good. Most of the time it starts to happen when the bike it hot or ive been riding it for a while.
post #6 of 7 (permalink) Old 08-28-2007, 09:27 AM
It's probably the chain binding. How many miles are on it? I usually get chains to make it around 20k before it becomes an issue, but I clean and lube it fairly regular. My chain did the same thing when it was dying though, lube it and it would be fine for 300 miles or so and then start binding again. New chain and binding goes away as does the "knocking".
cbreater is offline
post #7 of 7 (permalink) Old 08-28-2007, 09:28 AM
What's the play on the chain like? It could just as easily be slapping against the frame.
2009 GSX-R 750 - coming soon
2007 GSX-R 750 - stolen :(
2001 GSX-R 750 - sold
lude is offline
