1990 GSXR 1100 Rear Shock - GSXR.com
post #1 of 8 (permalink) Old 11-17-2007, 06:19 PM Thread Starter
I was taking apart the GSXR 1100 that I just picked up and I found a problem with the rear shock. The line from the shock to the external reservoir has a kink and it is leaking black fluid. Can the line be replaces and then shock recharged? What does this shock get recharged with? Is it even worth my time or should I try and find another used one?
Let me know your thoughts or ideas.
RMBillings is offline
post #2 of 8 (permalink) Old 11-18-2007, 07:31 AM
768-Ryda's Avatar
hey bro the best mod i did to my 93 gixxer 1100 was swap the old style shock out with a shock off a busa, and u can get them off ebay pretty cheap and it's a direct bolt on and alot better shock vs the old crapy shock and its got a stiffer spring to
Water cooler comin to a track near you !
768-Ryda is offline
post #3 of 8 (permalink) Old 11-18-2007, 09:37 AM Thread Starter
What year Busa shock did you use? Does it matter what year?
post #4 of 8 (permalink) Old 11-18-2007, 09:52 AM
768-Ryda's Avatar
really doesn't matter bc they all are the same, but i got 1 off a 05 busa with low mileage
768-Ryda is offline
post #5 of 8 (permalink) Old 11-18-2007, 10:13 AM Thread Starter
So the resevoir on the top of the Busa shock did not hit the bottom of the battery box?
post #6 of 8 (permalink) Old 11-18-2007, 12:45 PM
768-Ryda's Avatar
nope
768-Ryda is offline
post #7 of 8 (permalink) Old 11-24-2007, 06:12 PM Thread Starter
Just for reference the 2005 Hayabusa shock does not work on the 1990 GSXR1100. It comes in contact with the battery box.
Thank you.
post #8 of 8 (permalink) Old 11-25-2007, 11:58 AM
768-Ryda's Avatar
did u go from the top of the battery box or did u come from the bottom, i had to go from the top but it did work and the res did not hit the battery box at all, and it works like a charm
768-Ryda is offline
