Fuel Pump Help - GSXR.com
post #1 of 5 (permalink) Old 11-30-2007, 01:21 PM Thread Starter
Fuel Pump Help
I have a 97 TLS. The fuel pump quit. Seems to be getting power, no error codes, etc. I removed the pump and it's a Mitsubishi uc-t30. I can't find just the pump. I have heard there is a Walbro replacement that will work, however I need some part numbers, or if anyone knows of where to find a uc-t30 that would be great. Any other suggestions? I don't really want to spend $400.00+ for the whole assembly
TLS97 is offline
post #2 of 5 (permalink) Old 11-30-2007, 02:42 PM
dg78o6's Avatar
can you put some pics of the TL fuel pump?
dg78o6 is offline
post #3 of 5 (permalink) Old 11-30-2007, 06:08 PM Thread Starter
Here They Are
TLS97 is offline
post #4 of 5 (permalink) Old 12-01-2007, 07:41 PM
dg78o6's Avatar
that is totally different from my gixxer. i just thought they would be similar if not identical.
dg78o6 is offline
post #5 of 5 (permalink) Old 12-02-2007, 12:26 PM
Bikebandit lists it for $524! Do a salvage yard part request (you can find it on google) and you should be able to find a good used one for cheap. The request will probably net you with at least 10 different yards that have your part. It helped me out.
falcotim is offline
