No key need to get number off of ignition... - GSXR.com
post #1 of 9 (permalink) Old 06-02-2008, 10:27 AM Thread Starter
Well on the weekend some relitives graced me with their presence long enough to have there youngest flush my last key down the toilet. Now I need to get the number off the bottom of my ignition, if there is one. I own a 2000 GSX-R750, so if anyone can help me out or send me a link on how to remove my ignition, I would appreciate it a lot. Thanks in advance.
bruno__33 is offline
post #2 of 9 (permalink) Old 06-02-2008, 11:07 AM
burnsv11's Avatar
Taking the ignition swich off is a simple task.
1.) Loosen the pinch bolts on both sides of the upper tripple clamp.
2.) Remove the stem nut: 32mm
3.) Lift the clamp and rotate to see underside.
3.) Use a key type torx bit (has a hole in the middle, most kits found under $50)
That will remove the ignition from the clamp, but if you need to remove the ignition all together:
1.) Remove the upper and side fairings
2.) Disconnect plugs on right side under your ram air tube.
To your original question:
Loosening your your pinch bolts and removing your stem nut will grant you acess to see the underside of your ignition.... best of luck to you..
burnsv11 is offline
post #3 of 9 (permalink) Old 06-02-2008, 11:14 AM
Streetdremz's Avatar
FYI no key code on the ignition. Only way the dealer can make a key is by using that little black stamp that came with the bike.
You'll need to take it to a locksmith and have them rekey ALL your locks. Looking at about 120 bucks. Good luck
Streetdremz is offline
post #4 of 9 (permalink) Old 06-02-2008, 12:39 PM Thread Starter
thanks a lot guys... and that sucks about the price but i guess yah gotta do what yah gotta do
post #5 of 9 (permalink) Old 06-02-2008, 12:47 PM
Terd Ferguson
JohnPaul's Avatar
after the locksmith makes you some keys, zip tie one near the battery box under the seat.
JohnPaul is offline
post #6 of 9 (permalink) Old 06-03-2008, 10:07 AM
johnnylovely's Avatar
So..uuh..um..yeah, where do you live again?
master moto tech...fire away.
johnnylovely is offline
post #7 of 9 (permalink) Old 06-03-2008, 06:39 PM
Drag Racer
PhqOphRacing's Avatar
A locksmith can take the ignition apart and make a key, theres no need to rekey everything, at my shop it would run around 12-15 bucks.
PhqOphRacing is offline
post #8 of 9 (permalink) Old 06-03-2008, 11:11 PM
wish you locksmith lived near me. it`s about $90 around here. cory
corybusa is offline
post #9 of 9 (permalink) Old 07-25-2008, 06:17 AM
GSXR key ingnition
http://gsxr.tcpstudio.com
Im giving step by step instructions with pictures on the correct tools needed to change an ignition system. That way you dont have to tap out any screws and I also gave estimates on how much everything should cost. Go check it out!!!
tcontradiction is offline
