"5d" or "Sd" ERROR ?? - GSXR.com
post #1 of 43 (permalink) Old 12-03-2008, 04:46 PM Thread Starter
SeanGSXR's Avatar
I recently wrecked and fixed my 08' GSXR-1000. Now the red light is on (NOT blinking) and a "5d" or "Sd" error is blinking. Now, even though it looks like a 5, I think its an S, because I had to replace the steering damper with an after market. The bike rides perfect as it used too, so I dont think its anything else. If it is the steering damper, how do I fix that damn error??? Thank you!!
SeanGSXR is offline
post #2 of 43 (permalink) Old 12-03-2008, 04:59 PM
italianmike's Avatar
May be totally off here but I changed the sprockets & chain on my k7 1k and forgot to put back on the little nut that tells the speed and registers mileage. But I was too lazy to pull the clutch cover back off and put it back on right away cause I wanted to play around with my new gearing. When I drove it around without the speedometer nut in the output shaft it wouldn't register speed and the Sd light started flashing. I think it stands for Sd or abreviated for speed sensor. It's the sensor down there that plugs into the clutch cover on my bike. Don't know what kind of bike you have though. Opps, okay, you have the same bike I have! Yeah, my Sd light was flashing too and I just put that nut back on the output shaft and it went back off. Is your speedo and mileage working on your display?
italianmike is offline
post #3 of 43 (permalink) Old 12-03-2008, 06:06 PM Thread Starter
SeanGSXR's Avatar
Yeah, Everything is working fine. I never touched the clutch except to put fluid in it. I have no clue what the damn Sd means, I looked all over the manual. YOU THINK THEY WOULD PUT IMPORTANT STUFF LIKE CODES IN THERE!?!
SeanGSXR is offline
post #4 of 43 (permalink) Old 12-03-2008, 06:33 PM
Well if you turn the bike on does the Sd start flashing immediately? Or do you have to drive it a little while then it comes on? If it immediately comes on then shut the bike down and put it in dealer mode. If it throws a C-93 thats 4-108 in the service manual and then you will know if it is the steering damper. C-93 is the steering damper solenoid sensor. If it's not then I'm positive it has something to do with the speed sensor. Maybe not in the sensor itself but in the cluster or in the ECU. Like I said, mine was throwing Sd and I put that nut back on and it went away. It wouldn't throw Sd until I drove it about a quarter mile first though. It didn't come immediately on when I started the bike.
Yeah no they don't put codes in there. Thats the stealerships way of making money. If the bike has been wrecked though it could be many ways the speed code is being thrown. Do I know all those way? No... but maybe somehow that nut inside the cover in there got damaged somehow, but then you shouldn't be registering mph though so I don't know. Just try to pull a code on it by putting it in dealer mode and if you get a C-93 then replace the damper solenoid.
post #5 of 43 (permalink) Old 12-04-2008, 03:20 PM Thread Starter
SeanGSXR's Avatar
Everyone on gixxer.com is satying its the damper and to unplug, and plug it back in... Im going to try that. I know I snapped off the end of the wire (connector) when I wrecked, so IDK if thats going to mess it up...
SeanGSXR is offline
post #6 of 43 (permalink) Old 12-04-2008, 10:38 PM
hopefully it works, if so let me know. It must be something weird that happened with me then cause when I put my speed nut back on the Sd went off.
post #7 of 43 (permalink) Old 12-04-2008, 11:29 PM
Shoua's Avatar
If you read your manual, it will say that when "Sd" comes on, you have a problem with your "S"teering "d"amper. So if it's an aftermarket unit, you can't plug it in. But if it's another electronic stock damper, then by all means plug it back in!
Shoua is offline
post #8 of 43 (permalink) Old 12-05-2008, 09:20 PM
What page in the manual is that???
post #9 of 43 (permalink) Old 12-05-2008, 09:40 PM
SD fault code + no mph/mileage
Hey all,
I am getting a SD light on my 07 1000 which i am assuming is a steering damper issue. On top of that i am not get MPH/mileage. Everything else is working fine such as the tach, gear indicator etc.
Can a damaged steering damper be the cause of no MPH/mileage
I have checked the sensor on the left side near the chain. look fine. checked fuses seems like i have done it all. Anybody else experienced this b4. kinda at a loss right now.
Well I guess this says it all. I would have to see in the manual where it says Sd stands for Steering Damper. I looked at EVERY aspect of my manual and there is nothing there.
Here is an old post of a guy with an Sd code flashing and affirming that he has NO reading on Odo or mph. And like I said I had the EXACT problem and putting the nut back on made the light stop flashing IMMEDIATELY.
Anyway I still could be wrong even with all that said, it wouldn't be the first but it definately would be the freakiest coincidence that my light just went back off putting the nut for the SpeeD sensor back on and Sd flashing with my mph and odo not working and other people on this forum in a forum search experiencing the same exact thing.
post #10 of 43 (permalink) Old 12-05-2008, 10:47 PM
orange-demon
Posts: 3 07 1000 with no mph reading
got on my bike and my MPh stopped working. i have pulled the cluster off and unhooked it and pluged it back in anybody else had this problem, what did you do to fix it??//
orange-demon
View Public Profile
Find More Posts by orange-demon
Add orange-demon to Your Buddy List
07-28-2008, 10:29 PM #2
K7-1000
No light? No "Sd" code on the dash? Weird.
Check the speed sensor connection to the speedo down the inside of the left framerail, near the transmission. It's a white 3-pin plug coming from the sensor on the housing over the drive sprocket.
You can pull that sensor too and inspect it. Sometimes the sprocket cover gets full of crap from the chain and makes it not work so well.
If you can find no trouble here and the bike runs well (it will run like shit, typically, if the actual sensor to ECM speed signal is lost), you have a failure at the instrument cluster or connections. I'd expect you'd better bring your butt-plug to Suzuki if you have to buy one of those.
K7
Here are some more posts of people experiencing Sd errors and mph/odo not working. The first post goes on to further explain that his Sd code is thrown but its way down in the thread so I didn't copy/paste it.
Here is the other part of the post he wrote...
orange-demon
sorry the description was really short. i have the sd error code. i give the sensor a try. thanks fellas
post #11 of 43 (permalink) Old 12-05-2008, 11:00 PM
Shoua's Avatar
Man, I can't believe you're making me look this up in my manual.
In my k8 600 manual, it's on page 3-16.
You're welcome.
Shoua is offline
post #12 of 43 (permalink) Old 12-06-2008, 06:12 AM
check the plug on the steering dampener i had the same problem it was broke off. if that is not it take it to a dealership and they can read the code
busakillin07 is offline
post #13 of 43 (permalink) Old 12-06-2008, 07:48 AM
Two things and two things only cause an Sd code: One is the speed sensor signal is lost, that'll be obvious because you'll have no speedo or odo either. The other is the aforementioned steering damper issues. Both of these are electrical problems. As long as the connections are good, no Sd code, regardless of whatever mechanical faults may also be present.
K7
K7-1000 is offline
post #14 of 43 (permalink) Old 12-06-2008, 11:17 AM
K7
Thank you for clarifying that the Sd error IS TRIGGERED BY THE SPEED SENSOR!!!!!!!!!!!!!!!!!!!!!!!!! As well the steering damper can cause the code but the SPEED SENSOR does cause an error code and this is no 600 in question, these are 1000's we're talking about here and they are two very different machines. My 1000 manual has no info on that page stating the steering damper as an Sd code.
I think I've posted enough convincing posts of other riders to have proven the point that an Sd code means SPEED SENSOR AND RELATED PARTS LIKE THE SPEED NUT, and in other cases the steering damper.
I don't want to computer warrior with anyone I don't want to be told something I know is right, is wrong though.
We're both correct, and the point is that he probably is having a problem because of his steering damper but until I could find out whether or not the mph was reading on his then I wouldn't have been able to tell him for sure.
I simply posted what experiences I went through and what I did to get the Sd light to go off which was screw the nut back on and the light went out.
But either way before I abandone this post where I was trying to help someone with my experiences I will say to the original poster of this that I found out that if you bridge the Steering Damper wires with a 1watt 20ohm resistor for a 1000 it should turn the light off or you can take a hex head driver and take off the sensor part off the damper itself and plug it into the harness and wrap it in plastic and be done.
Good luck.
post #15 of 43 (permalink) Old 12-07-2008, 09:46 AM
Shoua's Avatar
Good luck.
For your information, k8 600 DO HAVE AN ELECTRONICALLY CONTROLLED STEERING DAMPER as well. If you read my last post, it even states in the owner's manual that "Sd" stands for a fault with the steering damper, whether it's actually caused by the speed sensor or steering damper. Isn't that what the first guy's question was?
Shoua is offline
post #16 of 43 (permalink) Old 02-12-2009, 12:44 PM
I have a k7 1000 and i am getting the "5d" or "Sd" code. I built my own TRE and have it wired to a push button and mounted where the right side seat bolt used to be. The TRE works very well but when I ride for awhile the light comes on (does not blink) and everything seems to work just fine. When the TRE is off I can ride all day long without a single light or code issue. I'm not too worried about it, I was just wondering if anyone knows what it means.
Chambeers is offline
post #17 of 43 (permalink) Old 02-27-2009, 05:29 AM
biker_gsxr's Avatar
Sd Error
Hi
i had the same problem my self.
The problem was spoted in the wire that goes to the plug of the steering damper. it was cut in two spots. At first i have just saw the first cut, but the problem was still there. so i took the plug from the steering damper out took all the wires to the right site (as you sit in the bike) and i find another cut in the wire. After fixing this problem, everything seem fine, and the indicator "SD" has switched off. Good luck, i hope it was helpfull.
George Gsxr 1000 k7 (Greece)
biker_gsxr is offline
post #18 of 43 (permalink) Old 02-28-2009, 01:22 PM
simplyorange's Avatar
mine did this today, after reading this post i have a broken steering damper wire right at the plug. looks like the harness is a little too short for when the steering is maxed out, ill be extending the wires about 2" and repinning mine to fix this issue.
btw, thanks for the good tech advice guys, it only took me about 3 minutes to find my problem and thats because i had to log in.
simplyorange is offline
post #19 of 43 (permalink) Old 07-20-2010, 10:02 AM
I am having a similar problem with my k8 600. It starts up fine and will run for a while then the code pops up and a few min after that the bike just shuts off and wont start. Any ideas? I dont think the steering dampner would shut the bike off.
chrisblkz is offline
post #20 of 43 (permalink) Old 07-21-2010, 06:24 PM
onefastnismo's Avatar
"chrisblkz" My 09 gsxr600 did that today too????? was riding for a good hr, then solid red light with flashing Sd (where temp gauge is at). rode it for lil bit, then rpm, mph, everything froze. Bike still ran.....so I wasn't to far from home so hurried then bout 2 blocks from when tach freezing, bike shuts off and wouldn't start. So I tried to start it couple of time and no luck. feels like a weak battery when trying too.....So then I had someone help me jump it. Fired right up, tach fully functional.......???????rode it 2 more block to the house, parked it, tried to start it up again.........NOTHING, now i'm pissed.....brand spanking new bike. well not new anymore but has 2200 miles on it now. Any help on this would be helpfull. Thanks
onefastnismo is offline
post #21 of 43 (permalink) Old 07-21-2010, 07:39 PM
These codes are being triggered and are the result of low battery voltage. In other words, not part of the main problem.
Low battery voltage can cause the ECU to display trouble codes in error.
The cause of low battery voltage could be the result of several things. A defective or bad battery, an issue with the stator, reg./rec. Damaged / loose connectors that are part of the charging system wire harness. Damaged charging system wiring harness.
ocularus is offline
post #22 of 43 (permalink) Old 07-21-2010, 10:09 PM
ocularus any way for me to test 'em out without taking it to the dealer?
post #23 of 43 (permalink) Old 07-22-2010, 01:29 AM
This could be the case of a bad battery, but.....
Depends? Do you own and know how to use a multimeter? How comfortable are you troubleshooting electrical problems?
All you would need then is the correct service manual for your bike. All the procedures for testing the charging system's various components and service spec's are outlined in the electrical section of the service manual.
Remember all these test should be performed with a good and fully charged battery (12.5v+) or the tests results may not be accurate.
Make sure you have good, clean, tight, wire harness connectors/terminals to the stator and reg/rec. (ie. make sure the stator wire harness connector under the left lower cowling is secure and undamaged)
You could start by checking charging system output. This basically consist of connecting the multimeter's + lead to the Positive battery terminal and the meter's - lead to the neg. battery terminal. Start the bike and hold the engine RPM's at 5000RPM. You should see voltage rise to and hold @ approx. 14v @ 5000RPM.(verify charging system voltage output spec. for your model in the service manual) As stated in the service manual, a reading above or below the specified range indicates a charging system issue.
You'll would then proceed with measuring generator coil resistance at the gen. wire harness connector. The manual also provides info on how to check the regulator/rectifier.
You may want to check out this information in the service manual and based on that, make a decision on whether you want to tackle it yourself.
Barring this just being the case of a bad battery....I'm leaning towards a bad stator, but you are still going to want to test everything including the battery, reg./rec. applic. wiring and confirm this.
ocularus is offline
post #24 of 43 (permalink) Old 07-22-2010, 08:24 AM
Thanks man.....not a big fan of electrical, but i'll look into the battery first.
post #25 of 43 (permalink) Old 07-22-2010, 10:05 AM
If the battery won't take a charge you know you have a problem there. I would attempt to fully charge the battery first. Then have someone with a battery load tester check it's condition. Perhaps you could charge it and bring the battery to your local dealer and ask them if they would be willing to load test it for you.
ocularus is offline
post #26 of 43 (permalink) Old 07-22-2010, 07:42 PM
ocularus, so i tried the voltage reading while reving up to 5k and if I did it right.....think it read 11-12 volt. but talk with the dealer i bought the bike from and they said they'll take a look and should be under warranty if anything....
post #27 of 43 (permalink) Old 07-22-2010, 07:59 PM
Oh yeah. If the bike is still under warranty you should take advantage of that. Let us know what it turns out to be.
ocularus is offline
post #28 of 43 (permalink) Old 07-23-2010, 03:16 PM
will do....
post #29 of 43 (permalink) Old 07-27-2010, 02:35 PM
so the dealer called me yesterday and said it was the battery regulator???? something is drawing to much juice and said it could be the HID kit that i have...............
post #30 of 43 (permalink) Old 08-09-2010, 02:40 AM
Hi onefastnismo,
I'm having the exact issues with my K8 gixxer. I brought it 2nd hand a couple of months ago and 40mins into the first journey, the red light came on, Sd error code and then within about 5-10mins, the engine started to idle funny and cut out, refused to start. Took it in for service and the battery was replaced, however same issue. Now i've worked out that 40mins into any journey, expect the red light and don't expect to be able to start the bike if you stop the engine. I have it booked in for another service this week, however any advise you can share with your experience will help me to get it sorted.
Thanks.
ashukgixer is offline
post #31 of 43 (permalink) Old 08-09-2010, 11:16 AM
ashukgixer the regulator was out, and wasn't charging the battery according to the dealer. They replaced it under warrantie, but said something is over working the charging system. They told me it could be the HID kit that i have but its only one that is running, a 35w 8000k
post #32 of 43 (permalink) Old 08-09-2010, 11:51 AM
Thanks for the reply! Is it still cutting out on you or has the new regulator fixed that? What did they suggest to do to sort the charging system? Replace the HID i'm assuming but not ideal...
post #33 of 43 (permalink) Old 08-09-2010, 01:01 PM
ashukgixer new regulator fixed the problem, but they did suggest that it is the HID that caused the problem.......and my hid are staying in until it dies again, then take it back with the stock ones in 'em.
post #34 of 43 (permalink) Old 08-09-2010, 01:11 PM
5d/sd error
I bought a brand new 2009 Suzuki GSXR 600 yesterday with 3 miles on it. I rode it at the dealership for a half mile brought it home on a trailer cause I live far from my Suzuki dealer. When I got it home I hoped on it rode around for about 12 miles. I noticed the red light was on. Then I headed home and everything lit up on the odometer and froze. I parked the bike turned it off and tried starting it. So the next day I tried starting it and it wouldnt turn on. It sounded like it had a dead/weak battery. So I went bought a new battery hooked it up the bike started normally without any codes or anything. I rode it around for 40 miles and the redlight turned and and it started flashing "5d" or "Sd". and the whole thing repeated all over. Now im a at loss cause I bought a 11k bike and cant ride it. PLEASE HELP
09GSXR600 is offline
post #35 of 43 (permalink) Old 08-09-2010, 01:43 PM
Your new battery went dead too? Well, it's probably safe to assume that you have a short somewhere slowly draining the battery when the igntion is off or perhaps a faulty, loose or damaged charging system related wire harness connector or damage to the charging system related wire harness.
As stated before, you may sometimes see an FI light and codes display on the meter assembly due to low battery voltage. Low battery voltage will sometimes cause the FI light and a code to display when there is nothing wrong with that component. This is probably just a byproduct of the main problem you are having with your bike.
There are numerous things that could be causing this issue, for example a short or charging system malfuction, It's anybody's guess at this point.
That said, you bought a brand new bike with a warranty, why don't you just take the bike back to the dealer and have them diagnose and repair the issue you are having? Any Suzuki dealer can perform warranty repairs. You don't have to go back to the place you bought it from. The battery should be covered also.
ocularus is offline
post #36 of 43 (permalink) Old 08-10-2010, 06:14 AM
Hi 09GSXR600, sorry to hear about your problems with the new bike. My bike is being picked up for service today, so as soon as i hear any feedback i'll post here. My battery was replaced before but symptoms still showed so i'm hoping they'll look to replace the regulator/rectifier this time and it'll resolve the problem.
post #37 of 43 (permalink) Old 08-10-2010, 06:39 AM
Dakota1810's Avatar
sd, can either be the steering damper, a failed sensor or any type or a voltage issue such as a low battery, loose ground wire, or bad rectifier/regulator
and i know for a fact the unplugged steering damper is why, my steering damper cable got caught in a weird place on my forks which caused it to get pulled on full left steering and made the light constantly come on an go away
just find/make a dummy plug or bypass it
Dakota1810 is offline
post #38 of 43 (permalink) Old 08-10-2010, 07:29 AM
09gsxr600 save the headache. call your dealer that you purchased it from, let them know your problem and should be under warranty for 'em to diagnose and fix. But your description is exactly like mine, can be the same problem i had, the regulator (a $200 part) good luck
post #39 of 43 (permalink) Old 08-10-2010, 02:17 PM
Yeah I called my dealer today cause they were closed on Mondays. They said it should be under warranty but I'll let you know what they say the issuse is.
post #40 of 43 (permalink) Old 08-13-2010, 04:18 AM
Just heard back from the dealer and as we suspected the regulator/rectifier was shot. Will be changed out under warranty so looking forward to getting it back.
