Squeak from front wheel - GSXR.com
post #1 of 17 (permalink) Old 02-28-2009, 11:59 AM Thread Starter
Shoua's Avatar
There is a squeak from my front wheel when moving very slowly. It's not bad, but I'm getting annoyed. Where exactly do I lube the wheel to stop the squeak?
Shoua is offline
post #2 of 17 (permalink) Old 02-28-2009, 12:10 PM
Chamfer (angle), the edges of the brake pads slightly
K7
K7-1000 is offline
post #3 of 17 (permalink) Old 02-28-2009, 12:57 PM
SP GSX-R's Avatar
Post
i get that too. when i brake down to about 5mph
K7 600 Red/White
"If loud pipes save lives, imagine what riding that thing can do."
"I Ride in Leathers because I would rather sweat than Bleed..."
SP GSX-R is offline
post #4 of 17 (permalink) Old 03-01-2009, 09:33 PM Thread Starter
Shoua's Avatar
No, it doesn't squeak because of the brakes. This is just when I'm backing up using my legs, with NO BRAKE pressure. It's coming from the front wheel, but not the brakes.
Shoua is offline
post #5 of 17 (permalink) Old 03-01-2009, 11:56 PM
PacificGSXR1000's Avatar
You might as well angle cut the sides of the pads when you take your front wheel off to lube the front axle like you figure it is.
Oh yah the floating discs might be squeking. If your pads haven't worn evenliy the discs have to do their float back and forth while the wheel rolls. Kind of pulsing braking will sometimes let you know you have uneven pads. Try holding a front disc one at a time in different areas and trying to move them around to see if you hear squeking. That or try a little silicone lube that wont get slung onto the discs while at speed. Do what ever it takes to be happy.
Another note is pads can squek when the brakes aren't applied.
K6 GSX-R1000
PacificGSXR1000 is offline
post #6 of 17 (permalink) Old 03-02-2009, 07:20 AM
bustanut's Avatar
most likely brake dust, or dry wheel seal, clean the grooves in your pads and check to see if they are glazed.
Bustanut
bustanut is offline
post #7 of 17 (permalink) Old 03-02-2009, 05:22 PM
Motophoria's Avatar
Remove the brake pads and LIGHTLY lube the back of the pads/springs. Clean and lube the brake pad pins before reassembly.
The road to hell is paved....
and slightly banked!
Motophoria is offline
post #8 of 17 (permalink) Old 03-03-2009, 01:30 PM
DOBERDEWD's Avatar
Well it sounds like everyone pretty much has it covered .... The only other thing that I can think of is that you may have a slightly warped rotor but if you did, you would feel the pulsation when your braking as well ... But just for the hell of it, if you have exhausted all of the other suggestions, I would put a dial indicator on your ft rotors and check for runout or warpage .... I guess I'm just grasping at straws here but I was thinking about it so I wanted to share that tidbit of info ...
The
Doberdewd
"OLD SCHOOL GIXXERS ROCK"
DOBERDEWD is offline
post #9 of 17 (permalink) Old 03-03-2009, 01:58 PM
MR DANGLES's Avatar
Mine does it too I have chalked it up to floating rotors
FU*K AVERAGE
THE HUNT IS ON
MR DANGLES is offline
post #10 of 17 (permalink) Old 03-03-2009, 04:09 PM
MPG mod
gixxerfool's Avatar
Its the pads. My rear has done it since day 1. Chamfer the fronts and spread some of that gold paste shit on the backing plate of the pad NOT the friction surface.
MPG wins=6
gixxerfool is offline
post #11 of 17 (permalink) Old 03-03-2009, 09:14 PM Thread Starter
Shoua's Avatar
Thanks for the replies, guys.
There is NO pulsation whatsoever. It brakes just fine.
I figured it might be somewhere from the front axle, and/or bearings, but cannot find a spot on the front axle where it would squeak. My k7 600 never did it, and this just came up about a month ago. It's just buggging me a little. If it is the brakes, then I'll just live with it.
Shoua is offline
post #12 of 17 (permalink) Old 03-03-2009, 09:37 PM
KippKyEva's Avatar
I have the same issue, just hadn't gotten around to asking about it yet. Thanks for the info!
When buying a used car, punch the buttons on the radio. If all the stations are rock and roll, there's a good chance the transmission is shot. ~Larry Lujack
KippKyEva is offline
post #13 of 17 (permalink) Old 03-03-2009, 09:50 PM
i have a similar squeak
ITzAn808 is offline
post #14 of 17 (permalink) Old 03-04-2009, 11:57 PM
Good excuse for new wheels and everything else.
Replace everything
K6 GSX-R1000
post #15 of 17 (permalink) Old 03-05-2009, 03:40 AM
Replace everything
Put new Marchesinis with full floating rotors and brembo calipers and you'll probably still have some squeaking
PushHands is offline
post #16 of 17 (permalink) Old 03-05-2009, 06:39 AM
Clarksroom's Avatar
Just my 2 cents here but I had that problem on my 1000 when I first picked it up, bought it used and it was very annoying. I took the front apart 4 times, fixing break pads, cleaning everything, pulled out the dust cover/seals on front and claened them and put a little lube on them...still the squeak. I was putting new tires on it so I went ahead and installed new bearings and the squeak went away. The inside of the oem bearing was actually starting to come apart. Looked like just a bad piece. Not trying to scare anyone or anything but something you might think about if it gets worse or you can't fix the problem with previous info in the thread. All I did was replace the bearings, used the same dust seals but the noise was gone and 5500K miles later no noise. Just an FYI as to another option on where the noise is coming from. Good luck!! Keep us informed as to what fixes the problem if you find out.
Clarksroom is offline
post #17 of 17 (permalink) Old 03-05-2009, 08:24 AM
Shot Caller
It it were actually the wheel bearings squeaking, they would have seized up shortly after you started hearing it.
Mister Tee is offline
