2006 gsxr 600 shifting hard - GSXR.com
post #1 of 6 (permalink) Old 09-01-2009, 06:37 PM Thread Starter
I have a problem with shifting into nuetrul when my bike is warmed up i have to be rolling it is hard to pull up from first. Is there a way to fix this?
jjcline28 is offline
post #2 of 6 (permalink) Old 09-01-2009, 07:10 PM
gsxr600pc's Avatar
Sounds like your clutch isnt engaging to go into nuetral. Is it just hard in Nuetral or all gears?
gsxr600pc is offline
post #3 of 6 (permalink) Old 09-01-2009, 07:25 PM
Jeff405's Avatar
Make sure you have alittle play in your clutch lever before it grabs. It could be too tight and not disengaging all the way.
Speed Tribe
03' GSXR 600
01' GSXR 1000
Jeff405 is offline
post #4 of 6 (permalink) Old 09-02-2009, 08:20 AM
Shot Caller
Yes, 99% of the time a clutch adjustment will fix that condition.
Mister Tee is offline
post #5 of 6 (permalink) Old 09-02-2009, 10:07 AM
WoodShoe's Avatar
Unscrew the cable adjuster on your clutch lever a bit and see if that helps. If not, you may need to get your clutch properly adjusted.
coincidentally someone just posted some steps on how to do this the next post down. if you download the manual, there is pics to help you along
Internal Clutch Adjustment
KSIX600 w/ K7750 swap -- PCIII + LCD + WIDEBAND02, K&N, -2 / + 1
WoodShoe is offline
post #6 of 6 (permalink) Old 09-02-2009, 03:08 PM Thread Starter
Hey thanks a lot guys ill try it thanks for the link to
