How to change spark plugs K6 1000 - GSXR.com
post #1 of 15 (permalink) Old 06-13-2010, 03:34 PM Thread Starter
paan998's Avatar
How to change spark plugs on a 2006 GSXR 1000: Allow about 45 minutes to change plugs.
TOOLS NEEDED: 4mm/5mm allen sockets, 10mm socket,#2 Phillips screwdriver, 3" extension, 5/8" swivel spark plug socket, and (4) NGK CR9E spark plugs, which are OEM. I use NGK CR9EK's
Seat removal- 4mm allen socket to remove (2) frame/tank covers
Tank removal- 4mm allen socket to remove (2) front bolts
5mm allen socket to loosen long rear
bolt/ (remove bolt later)
Have someone tilt tank in the up position, then disconnect fuel line, fuel pump wire, clear/black vent hoses on rear of gas tank
NOW remove rear bolt from the back of tank and place the tank in a safe area. I chose a lawn tractor tire to protect the fuel pump.
Airbox removal- loosen (12) screws on top cover/ pull off cover
loosen (4) screws on the intake clamps
remove 1 10mm bolt on the frame
remove (2) airbox vent hoses on the Right side
remove GREEN sensor plug on the Right side
remove BLUE plug/sm black vent hose off rear.
PULL lower airbox by lifting up/back. You need to clear the front (2) intake vents by frame rails.
Disconnect coil wire and remove the coil to expose plug. I always move from LEFT to RIGHT. Using a swivel socket, remove plug and then REVERSE the order. You may want to check gap.
I took PICs of each/every step and I'll try to load them up.
If not, feel free to email me(paan998@hotmail.com). I hope this make the job easier from anyone who can benefit.
2013 ZX10R (partout)
2005 GSXR750 "Sold 5/15"
2003 Yam. Zuma 49cc
1993 Kawi ZX7(950 bigbore)
1992 GSXR750(1276 Build)
1989 GSXR1100 (Roller)
1989 GSXR750 in B/W '91 colors
paan998 is offline
post #2 of 15 (permalink) Old 06-14-2010, 09:06 AM
Shot Caller
I personally don't go to the extreme of removing the tank, but I guess you could.
Mister Tee is offline
post #3 of 15 (permalink) Old 06-14-2010, 09:11 AM
VaBarber2's Avatar
+1
VaBarber2 is offline
post #4 of 15 (permalink) Old 06-14-2010, 09:20 AM
Moderator
HOG SLYR's Avatar
+2
HOG SLYR is offline
post #5 of 15 (permalink) Old 06-14-2010, 09:22 AM
RUS777's Avatar
+3
99 GSXR600, JETTED, FULL YOSH, LOVING IT!
New Birth Day: 08/25/09
RUS777 is offline
post #6 of 15 (permalink) Old 06-14-2010, 09:37 AM
bladerunner70's Avatar
+4
Ummm yeah, you also don't need to remove the 12 screws on the air filter box, that just splits it in 2 so you can get at the filter. I just swapped out the plugs on my K6 1000 yesterday and once you disingage the air intake clamps, connectors and hoses the filter box slides back and out.
There's a time to think and a time to act, and right now is no time to think
K6 GSX-R1000
bladerunner70 is offline
post #7 of 15 (permalink) Old 01-30-2011, 06:53 PM Thread Starter
paan998's Avatar
CORRECT on splitting the airbox, BUT I didn't note that I usually change the airfilter when I do a plug change.
2003 Yam. Zuma 49cc
paan998 is offline
post #8 of 15 (permalink) Old 01-30-2011, 06:57 PM
Thanks for the how to thread..
OUTINFRONT is offline
post #9 of 15 (permalink) Old 01-30-2011, 07:30 PM
How often do you change the plugs?
I guess it would be a good time to replace/clean the filter
2002 GSX600F. K&N, Stage 1 jet kit, Yoshi pipe
2006 GSXR 1000 Powder coat red frame, Pazzo levers, Giles rearsets, Factory pro engine covers, Frame sliders/spools and more to come
lordviper13 is offline
post #10 of 15 (permalink) Old 01-30-2011, 07:41 PM
Live Fast Die FUN
SRAD600's Avatar
You guys like bringing threads back lately.
Good how to, but I also dont take my tank off. I do split the air box tho so I can inspect my filter and clean if needed...might as well.
GSXR.com Moderator
SRAD600 is offline
post #11 of 15 (permalink) Old 01-30-2011, 07:52 PM
Terd Ferguson
JohnPaul's Avatar
Good hot to, but I also dont take my tank off. I do split the air box tho so I can inspect my filter and clean if needed...might as well.
+1
JohnPaul is offline
post #12 of 15 (permalink) Old 01-30-2011, 08:51 PM Thread Starter
paan998's Avatar
Glad to help. I change plugs every other season as I only make about 1K miles a season now
2003 Yam. Zuma 49cc
paan998 is offline
post #13 of 15 (permalink) Old 01-30-2011, 09:05 PM
Live Fast Die FUN
SRAD600's Avatar
Damn man we need to get you out more.
GSXR.com Moderator
SRAD600 is offline
post #14 of 15 (permalink) Old 01-31-2011, 04:57 PM Thread Starter
paan998's Avatar
NO doubt!! My 1st season on a sportbike, I put on over 8,000 miles and this is WI. Our riding season is less than 6 month. Once a wife, house, and kids came along, my riding time was/has been tragically limited
2003 Yam. Zuma 49cc
paan998 is offline
post #15 of 15 (permalink) Old 01-31-2011, 11:38 PM
WOW I do like 1000 a month
