sprocket change question - GSXR.com
post #1 of 11 (permalink) Old 03-07-2011, 03:44 PM Thread Starter
worthey360's Avatar
so im thinking about doing a sprocket change on my k7 600 to give it more torque... i was told to go -1 in the front and +2 in the rear... to be honest im not very familiar with this type of job.. if i could get some suggestions on what to buy it would be helpful.... thanks for your help in advance-Darryl
worthey360 is offline
post #2 of 11 (permalink) Old 03-07-2011, 03:46 PM
SlickWill's Avatar
use the search bar
2008 GSXR 1000
M4 Slip-on Exhaust
Carbon Fiber Gel-seat
Frame Sliders
Tinted Windscreen
520 conversion
Super Sprox sprocket
R1 throttle tube
Lightech chain adjusters
SlickWill is offline
post #3 of 11 (permalink) Old 03-07-2011, 03:48 PM Thread Starter
worthey360's Avatar
i have used the search bar on 3 different forums and every1 says the same thing
post #4 of 11 (permalink) Old 03-07-2011, 04:29 PM
busdriver's Avatar
Go to motomummy.com get your bikes stock gearing numbers off there, confirm that's what you have then order a sprocket for 1 tooth less in the front and order a sprocket with 2 teeth more for the rear. If you have basic mechanical abilities and decent selection of tools you should be able to do the job yourself if not bring it by the house and I'll throw em on there for ya....
busdriver is offline
post #5 of 11 (permalink) Old 03-07-2011, 04:34 PM
RedMist's Avatar
Go to the Google search at the top left. There are hundreds of posts on this. If everyone is saying the same thing. Maybe it's true. I like my stock setup though.
RedMist is offline
post #6 of 11 (permalink) Old 03-07-2011, 05:21 PM
ShAnO77's Avatar
You will lose roughly 15 mph with a -1 +2 setup make sure you get a speedo adj to keep up the miles and also to know your mph !!.02... If it were me i would do -1 +1 ... Jus saying Motomummy has the stock gearing app on their website
BLACK and ORANGE
K7 1K
M4/BMC Race
GixxerTune
DDM 6k
D3s
Frame Sliders
Much more to come
ShAnO77 is offline
post #7 of 11 (permalink) Old 03-07-2011, 06:59 PM
Bry
The Honey Badger
Bry's Avatar
A service manual and someone that knows what they are doing would be very beneficial. If you feel unsure of what you are doing, take the bike to someone that does..Incorrectly installing a chain spells diaster to your bike and/or yourself.
As far as what gearing you go with, the most common is -1/+2, -1, +1, and stock.
2011 ZX10R
07 750-Sold
Bry is offline
post #8 of 11 (permalink) Old 03-07-2011, 08:28 PM
If you only change the rear sprocket does it still mess up the speedo?
Redrockunderpants is offline
post #9 of 11 (permalink) Old 03-07-2011, 08:43 PM
pswamp605's Avatar
i have a -1+2 and like it, usually cruise around 6-8k rpms, aluminum sprockets dont hold up as well as steel ones, sunstar is pretty good.
06 1000
5.68@131
8.90@155
....zoom zoom bishes
pswamp605 is offline
post #10 of 11 (permalink) Old 03-07-2011, 09:45 PM
Bry
The Honey Badger
Bry's Avatar
Yes..you're speedo will be off even more than stock.
2011 ZX10R
07 750-Sold
Bry is offline
post #11 of 11 (permalink) Old 03-07-2011, 11:27 PM
busdriver's Avatar
Yes... Any gear change will cause the speedo to read inaccurately. It will also cause the odometer to be off as well. Common fix is a speedo healer by Healtech or other comparable unit....
