2002 GSXR 1000, Exhaust Control Valve Actuator, Code C46?? - GSXR.com
post #1 of 3 (permalink) Old 03-28-2012, 06:28 PM Thread Starter
I have a near stock(TRE, Dealer Mode Switch and PAIR Mod) 2002 GSXR 1000. I bought the bike new, and it has about 3500 miles on it. It has a stock exhaust. I do not want to put an aftermarket exhaust on it and I do not want to disable the valve.
I have been getting a C46 code. It does not always set the code, but it usually does. It does not seem to be affecting the way the bike runs, but I am tired of seeing the light/code.
I lifted the tank and run the bike, blipping the throttle. I can see the cables to/from the servo move and it seems like it is working normally, but I am not really sure what normal is.
I have searched and found lots of post regarding a C46 code with an aftermarket exhaust, but none about a stock exhaust.
How do I "test" the ECVA system? How do I "fix it"? Is there some "maintanance" I should do to it?
Joelk is offline
post #2 of 3 (permalink) Old 03-29-2012, 06:25 PM Thread Starter
No one has had this issue with a Stock Exhaust?
Joelk is offline
post #3 of 3 (permalink) Old 07-16-2012, 12:55 PM
stariondriver's Avatar
I have the code 46 too. Seems to not run as smooth when the FI light is lit up and i dont always get it.
looking for info on head bearings, fork seals and sprocket chains for my k3 gsxr 1000
stariondriver is offline
