PSR Drain Plug Safety tether? - GSXR.com
 3Likes
  • 1 Post By Last Week
  • 1 Post By MadeInAmerica
  • 1 Post By apiazza
post #1 of 9 (permalink) Old 08-24-2016, 04:01 AM Thread Starter
apiazza's Avatar
I just picked up a PSR magnetic drain plug for the track bike. Without knowing it actually came with a safety wire tether. Is it worth using? My only concern with it only being a safety pin on a wire, I can't really get clockwise tension on the bolt. Should I just safety wire it by hand? If I do opt for the tether, it comes with a mounting tab to go under a bolt. The most obvious one in the area would be one of the oil pan bolts. If I pull just one long enough to put the mount under it any real chance of a leak starting there?
2004 GSXR600 (Track)
2009 Ninja 650R (Street)
apiazza is offline
post #2 of 9 (permalink) Old 08-24-2016, 05:59 AM
CCS/ASRA Expert #77
Last Week's Avatar
Safety wire it yourself, and use tubing anywhere it rubs.
Sent from my SAMSUNG-SM-N900A using Tapatalk
JohnPaul likes this.
K7GsxR600 Race 2012 BOTY http://www.gsxr.com/42-gsxr-news/981...last-week.htmlSold
K6GsxR750 Track 2015 BOTY http://www.gsxr.com/44-gsxr-ride-mon...bike-year.html
2012 Ducati Panigale S Race
Last Week is offline
post #3 of 9 (permalink) Old 08-24-2016, 06:18 AM
I have the same plug and I am using the pin. First pic shows pretty well; second pic is blurry but shows where I put the tab (that my oil filter wire also runs to). I might change it to just wire the plug directly though. Not like it's difficult to snip and rewire for an oil change.
post #4 of 9 (permalink) Old 08-24-2016, 06:18 AM Thread Starter
apiazza's Avatar
That's the direction I was leaning. I don't think it would pass tech with the safety pin.
apiazza is offline
post #5 of 9 (permalink) Old 08-24-2016, 06:42 AM
I think some orgs don't accept pins on any safety wiring. For racing, I'd probably manually wire it. Has to be more secure.
post #6 of 9 (permalink) Old 08-24-2016, 07:17 AM
MadeInAmerica's Avatar
I have the same plug and I use the pin. I'll take a pic of where mine is mounted.
MadeInAmerica is offline
post #7 of 9 (permalink) Old 08-24-2016, 07:36 AM
Here are a couple of pics. I took the bracket off the right side that was used to mount the OEM fairing. I used that same spot to mount the plug safety wire bracket. I didn't want to remove a oil pan bolt and risk causing a slight leak.
tigerblade likes this.
post #8 of 9 (permalink) Old 08-24-2016, 08:07 AM Thread Starter
apiazza's Avatar
That's a good placement. I might mount the bracket there as a wiring point even if I decide to manually safety wire it.
MadeInAmerica likes this.
apiazza is offline
post #9 of 9 (permalink) Old 08-24-2016, 08:39 AM
Looks good. I think my bodywork brackets are different.
