FI Fault Code List / Dealer Mode Switch - Page 2 - GSXR.com
post #41 of 59 (permalink) Old 09-21-2008, 10:26 AM
i have a gsxr 750 1997 how do i bypass the dealer switch...
domfd is offline
post #42 of 59 (permalink) Old 10-03-2008, 01:45 PM
06gix1k's Avatar
Fi 06 1000
There is no pink or black wire under the tail. Mine seem to be by the battery. I do not know which wires to jump to find the code can anyone help
06gix1k is offline
post #43 of 59 (permalink) Old 10-12-2008, 08:44 AM
D.T.'s Avatar
Question
I have an SV and I have the dealer mode switch hard wired into a switch. Anyway, I have the SDS connector down by the dealer mode connector and was wondering if anybody has any information on the Suzuki Diagnostic System and how it's used?
Don't see much about this. My dealer told me about it a little.
K5 SV1000R, too many gixxers out there...
D.T. is offline
post #44 of 59 (permalink) Old 10-17-2008, 10:45 PM
2007GSXR600qvo's Avatar
Hi all
today after dropped the bike with a slow speed, tried to turn on and found out that my F I flashing, do some research online and test the dealer mode , code : -C00, according to the code list it's ok, but don't know why its still on, just do the oil change and top up the coolant last week, any idea guys
thanks.
by the way to those who have 07, the dealer mode is under the rider seat just incase u need it.
2007GSXR600qvo is offline
post #45 of 59 (permalink) Old 01-05-2009, 08:55 PM
uneedthis2's Avatar
So after searching for a while (yes i used the search function) I can't seem to find an answer that is 100%.
Tonight I took the exhaust valve motor and cables off of my 05 1000. What do I need to do with which wire to avoid getting a check engine light?
Any help is MUCH appreciated
uneedthis2 is offline
post #46 of 59 (permalink) Old 01-06-2009, 05:30 AM
uneedthis2's Avatar
Bump it up for an answer
post #47 of 59 (permalink) Old 02-08-2009, 01:30 PM
C42 Gsxr600 K9
im from Israel and i have a GSXR600 2009 (Eurupien version)
the bike is limited to 33hp by CDI/ECU (from the factory)
i ordered a unlimited/regular CDI from the US
when i connected it, the bike wont start and shows FI
i found out its C42 that means IGNITION SWITCH SIGNAL
the red light (with the key in it) stays on and wont blink.
someone knows how to fix it without going to the dealer (dont want to lose my warenty), instructions ?
thanks Daniel
biggiGSXR is offline
post #48 of 59 (permalink) Old 03-07-2009, 01:46 PM
My friend's bike wont start. He said he tried the paper clip thing for dealer mode but put the clip in the wrong place. Probably shorted something out. What did he kill and how do we fix his mess?
04 gsxr1000
1time is offline
post #49 of 59 (permalink) Old 03-09-2009, 06:22 AM
FI fault...2001 GSX1000R
Throughtout these posts seems most are just having the fault light appear, but my bike always sputters a bit as it comes on indicating it's a little more than just a fault light problem. It only happens at low RPMs, but can happen at the beginning of my ride before its completely warmed up or after a long highway ride. There doesn't seem to be much of a pattern, but it does happen about 4 out of 5 times on the bike.
I've taken it to the Suzuki dealer twice and the first time they adjusted the idle and all that changed was that it idles faster. The next trip they replaced all 4 injectors claiming rust, but all that changed was making my bank account smaller. At the same time the guy said he gave me a new map and I could tell a difference in performance (very, very strong), but it will still sputter at low RPMs and the FI light is right back. I can reset it by turning off the ignition, but it will come back.
Add ons: Previously it had a Power Commander that started acting up, so it was removed by those same Suzuki guys. It also has a Jardine slip on exhaust and a GPS tracking system with Alarm & back-up battery.
In reading these posts I will attempt to get the code using the tips I've read, but does anyone have any suggestions of what may be the cause?
Thanks!
gilstrr is offline
post #50 of 59 (permalink) Old 03-09-2009, 06:23 AM
FI fault...2001 GSX1000R: Please help!
Thanks!
gilstrr is offline
post #51 of 59 (permalink) Old 07-06-2009, 05:24 AM
...BUZZ...'s Avatar
these codes should be made a sticky on here.......
C00 no fault
C11 camshaft position sensor
C12 crankshaft position sensor
C13 intake air pressure sensor
C14 throttle position sensor
C15 engine coolant temperature sensor
C21 intake air temp sensor
C22 atmospheric pressure sensor
C23 tip over sensor
C24 ignition signal for no.1 cyl.
C25 ignition signal for no.2 cyl.
C26 ignition signal for no.3 cyl.
C27 ignition signal for no.4 cyl.
C28 secondary throttle valve actuator
C30 secondary throttle control unit
C31 gear position signal
C32 injector signal for no.1
C33 injector signal for no.2
C34 injector signal for no.3
C35 injector signal for no.4
C41 fuel pump control system
C42 ignition switch signal
C46 exhaust control valve actuator (1000 only)
C11 (P0340) CMP SENSOR CIRCUIT MALFUNCTION
C12 (P0335) CKP SENSOR CIRCUIT MALFUNCTION
C13 (P0105-H/L) IAP SENSOR CIRCUIT MALFUNCTION
C14 (P0120-H/L) TP SENSOR CIRCUIT MALFUNCTION
C15 (P0115-H/L) ECT SENSOR CIRCUIT MALFUNCTION
C21 (P0110-H/L) IAT SENSOR CIRCUIT MALFUNCTION
C22 (P1450-H/L) AP SENSOR CIRCUIT MALFUNCTION
C23 (P1651-H/L) TO SENSOR CIRCUIT MALFUNCTION
C24 (P0351), Coil #1IGNITION SYSTEM MALFUNCTION
C25 (P0352), Coil #2
C26 (P0353) Coil #3
C27 (P0354) Coil #4
C28 (P1655) Secondary TV ACTUATOR CIRCUIT MALFUNCTION
C29 (P1654-H/L) Secondary TP SENSOR CIRCUIT MALFUNCTION
FI SYSTEM DIAGNOSIS
C31 (P0705) Gear Position SWITCH CIRCUIT MALFUNCTION
C32 (P0201), #1PRIMARY FUEL INJECTOR CIRCUIT MALFUNCTION
C33 (P0202), #2
C34 (P0203) #3
C35 (P0204) #4
C36 (P1764), # 1 SECONDARY FUEL INJECTOR CIRCUIT MALFUNCTION
C37 (P1765), #2
C38 (P1766) #3
C39 (P1767) #4
C41 (P0230-H/L) FP RELAY CIRCUIT MALFUNCTION
C42 (P01650) IG SWITCH CIRCUIT MALFUNCTION
C44 (P0130/P0135) HO2 SENSOR (HO2S)
CIRCUIT MALFUNCTION (For E-02, 19)
C46 (P1657-H/L or P1658) EXCV ACTUATOR
CIRCUIT MALFUNCTION
C49 (P1656) PAIR CONTROL SOLENOID VALVE
CIRCUIT MALFUNCTION
C60 (P0480) COOLING FAN RELAY CIRCUIT MALFUNCTION
210 bhp @ the rear wheel is easy with traction control..
...BUZZ... is offline
post #52 of 59 (permalink) Old 07-14-2009, 05:38 PM
Red face k5 GsxR 1000
could sum one dat owns any k5/k6 GsxR 1000 tell me if they found the plug for the codes n wat color r the wires...
i have read the whole topic on this forum n no one specified were they found the plug.
pls guys.
thanks
DJAR19 is offline
post #53 of 59 (permalink) Old 07-14-2009, 08:01 PM
c46 exhaust control valve actuator on K5/K6 1000
ok, im going to clear this up...
we all looking for the plug to jump the wires to get the f1 codes.
on the K5/K6 1000 its not a 2 wire plug, its a 6 wires plug.
the colors r, black/white trace, white/red trace.
its locate by the negative pole of the battery, its a white plug n it has a black rubber cover on it.
now, i got all this.
but i dnt kno how to fix the problem i have on my bike.
i have the code C46.
wat i have to do, or wat it could b done to fix this???
DJAR19 is offline
post #54 of 59 (permalink) Old 09-23-2009, 09:53 PM
2005gsxr's Avatar
Check the fuse box on the right side of the bike as you are sitting on it. You have to take off the faring. On my 05 1k there is a black box that says fuses. Eight fuses or located there. I blew one of those when i jumped the wrong wires.
2005gsxr is offline
post #55 of 59 (permalink) Old 01-25-2010, 12:48 PM
Michal's Avatar
k guys im new to the site and im hoping youll be able to help me out. i just bought a 07 750 from an auction. the bike has a erion pipe on it. The problem is that i have the red light on when i start the bike i did the dealer mode and its code 46 so according tto the code list its EXHAUST CONTROL VALVE ACTUATOR , how do i go about fixing the problem? also where the temperature is it goes f1 then goes to the temp then f1 and then the temp basically it flashes the f1 where the temp is. im more of a car mechanic and dont know much about bikes. hope someone can help out.
thanks anyway
Michal is offline
post #56 of 59 (permalink) Old 01-25-2010, 01:25 PM
I agree this should be a sticky.nice post
OUTINFRONT is offline
post #57 of 59 (permalink) Old 01-25-2010, 02:08 PM
rotaredom
JohnPaul's Avatar
this is the FAQ section, all threads here are consolidated and considered stickies..
JohnPaul is offline
post #58 of 59 (permalink) Old 01-25-2010, 02:14 PM
Sorry
post #59 of 59 (permalink) Old 01-25-2010, 02:19 PM
rotaredom
JohnPaul's Avatar
Originally Posted by OUTINFRONT View Post
Sorry
No biggie
JohnPaul is offline
You may not post new threads
You may not post replies
