- C14 - THROTTLE POSITION SENSOR
- C15 - ENGINE COOLANT TEMPERATURE SENSOR
- C21 - INTAKE AIR TEMPERATURE SENSOR
- C22 - ATMOSPHERIC PRESSURE SENSOR
- C23 - TIPOVER SENSOR
- C24 - IGNITION SIGNAL #1
- C25 - IGNITION SIGNAL #2
- C26 - IGNITION SIGNAL #3
- C27 - IGNITION SIGNAL #4
- C28 - SECONDARY THROTTLE VALVE ACTUATOR
- C29 - SECONDARY THROTTLE POSITION SENSOR
- C30 - SECONDARY THROTTLE CONTROL UNIT
- C31 - GEAR POSITION SENSOR
- C32 - INJECTOR SIGNAL #1
- C33 - INJECTOR SIGNAL #2
- C34 - INJECTOR SIGNAL #3
- C35 - INJECTOR SIGNAL #4
- C41 - FUEL PUMP CONTROL SYSTEM
- C42 - IGNITION SWITCH SIGNAL
- C46 - EXHAUST CONTROL VALVE ACTUATOR (01-02 1000 and 06-07 600/750/1000 ONLY)
Location of dealer mode switch and how to get the codes.
The dealer mode connector is under the tail cowling on the left side of the bike, near the regulator/rectifier. It will have only two wires going to it. It is is small white connector that does not plug into anything, and has a rubber cap on one end.
BLACK W/ GREEN BAND Wire with a WHITE STRIPE and a
WHITE W/ GREEN BAND Wire with a RED STRIPE
you just use a paper clip to jump the two wires together in the connector. this is for models with 16 bit ECM's
or you can buy ONE OF THESE (16- bit has 2 wires at thh plug/ 32 bit has 4 wires at the plug)
05/06 1000
__
