hi im recently got a gsxr 600 2007 without a dash and some fairings the other day was doing some cleaning and found out that the oil pressure switch (located at the left bottom of the engine) cable (green) is cut and i have no clue where does connect to
any clue?
i ordered a new gauge for my bike and should arrive in few days to check any "red" light
Search Google for the PDF service manual for your bike.
I think its on the left side somewhere near the sprocket cover or under the fuel tank below throttle bodies.
Manual should tell you if you look thoroughly.
The wire goes back from the sender, under the stator cover in a black plastic sleeve.
The wire goes to a single connector off the harness underneath the airbox and behind the throttle bodies. Both sides of the connector are Green/Yellow striped wire.
For reference, the second picture is through the frame and the gold screw at the top left is the idle speed set knob.
Post an intro, with pics of your project, in the "new riders and members" section when you get a chance.
