Front sprocket change question - GSXR.com
post #1 of 12 (permalink) Old 03-13-2008, 04:46 PM Thread Starter
How exactly do you remove the front sprocket? I took the cover off and saw that wierd nut and gave up because it was getting dark.
Does the allen bolt need to come out? Once that is out does the square part come off so you can access the big nut?
This is on a k7 600. Trying to swap the stock sprocket back on. Shop changed it last time.
2007 GSXR-600- SOLD
k7 GSXR- 750 grey/black
AR15 guy is offline
post #2 of 12 (permalink) Old 03-13-2008, 04:50 PM
gsxr60007's Avatar
if you take out the Allen key you can get to the main bolt. its just like a safety lock thing.
just get a long allen key or a small pipe on the end of a short one so you can get some leverage, they are sometimes a bitch to get out.
Good luck!
2006 Suzuki GSXR 600
2004 Nissan Titan SE off-road
2000 Polaris Sportsman 500
2001 Yamaha Banshee
gsxr60007 is offline
post #3 of 12 (permalink) Old 03-13-2008, 05:48 PM
GSX-R..ider's Avatar
Your going to have to take out the speed sensor rotor (the allen nut your referring to), then when taking the bolt holding the sprocket on, you will need to run a bar through your rear wheel against the swing arm to keep the wheel from spinning. You may need a breaker bar. The Sprocket nut is on VERY well. Make sure you retorque everything back to specs. Why are you going stock?
2006 GSXR750
PC3
R1Throttle
TRE
K&N
-1
Velocity Stacks
GSX-R..ider is offline
post #4 of 12 (permalink) Old 03-13-2008, 06:00 PM
gsxr60007's Avatar
if you use an impact wrench to take the sprocket bolt out you wont need to put a bar inbetween the swingarm and rim.
2001 Yamaha Banshee
post #5 of 12 (permalink) Old 03-13-2008, 07:34 PM
SVT600's Avatar
+1 do it that way and get a long braker bar to help you out cuz it is on there very tight!! dont waist your time with an impact wrench!
My new:k7 GSXR 600
My old: 2004 Sonic Blue SVT Lightning
My stunt bike: 94 cbr600 f2
SVT600 is offline
post #6 of 12 (permalink) Old 03-13-2008, 09:32 PM Thread Starter
I have a Snap on electric impact. 800ft lbs of torque anyone?
I am trying to sell the bike so I want the speedo to be correct again. Or if I keep it I am tired of the speedo being so messed up. Plus I want to keep the mileage down some. Its already to 7600 since last March.
2007 GSXR-600- SOLD
AR15 guy is offline
post #7 of 12 (permalink) Old 03-14-2008, 01:13 PM
GixxerDave's Avatar
good luck with getting the sprocket off. I also have a question
i thought i would post here. I need opinions from people who own
a 1000. i own a 2006 1000 i'm wanting to change the gearing
does the -1 on the front change the gearing that much. is what
i'm looking for is lower quarter mile time but also i want to
clutch third easier for wheelies or is the -1+2 a better option just wanting opinions before i spend the money.
06 GSXR1000
GixxerDave is offline
post #8 of 12 (permalink) Old 03-14-2008, 02:10 PM
pimppapa1977's Avatar
Here you go complete tutorial wit pics!
http://www.gixxer.com/forums/showthr...front+sprocket
pimppapa1977 is offline
post #9 of 12 (permalink) Old 03-14-2008, 04:19 PM
SVT600's Avatar
go down 1 if the front 1st!! then if you still want more go for the up 1 or 2 in the back!! dont do -1 +2 at the same time!!!
My new:k7 GSXR 600
SVT600 is offline
post #10 of 12 (permalink) Old 03-14-2008, 05:02 PM
A speedo healer would have solved all your problems.
2006 GSXR750
PC3
R1Throttle
TRE
K&N
-1
Velocity Stacks
post #11 of 12 (permalink) Old 04-02-2011, 04:24 AM
everclear1984's Avatar
How much does it throw your speedo out by? Are you only -1 on the front or +2 on the rear too? I am thinking about doing this myself but probably won't be able to get a speedo healer til next month at least :(
GSXR 750 K6
everclear1984 is offline
post #12 of 12 (permalink) Old 04-02-2011, 04:25 AM
Just realised how old this thread is :S
GSXR 750 K6
