Just installed a PCV on my k8. Fuel module only. No other mods, just a slip on and filter.
I noticed right away that the acceleration smooths out. Meaning when you hit the gas it doesn't jerk on you as much, or at all. At lower RPMs the rev's go up smoothly. I felt more mid power. Traffic was no good so I didn't et to see what happens up top. Also note I downloaded a map that was just for slip on and drop in filter.
Over all I think it's money well spent. If you can find one of these you should grab it. install was easy, and management on the PC is easy to use and is pretty straight forward.
Thanks.
Thanks.
