battery recharge : GSXR.com Forum : Suzuki GSX-R Forums
» Insurance
» Suzuki GSX-R Prices
» Sponsors
Thread Tools Display Modes
Old 09-04-2006, 05:28 PM   #1
newbie
Default battery recharge
I think my battery is dead, because I tried to turn my bike on and all I hear is like a clicking under the seat. At first it tried to start and then nothing on the next try. Are motorcycle batteries like car batteries in that I can take it to Autozone and get it recharged? Please let me know because I need to take this bike to the shop and it can't move right now.
newbie is offline   Reply With Quote
Old 09-04-2006, 08:21 PM   #2
Gixxer clutch
Gixxer clutch's Avatar
Default
okay here is how you get it started.
You must do this as it is written:
okay
1) put the bike in netural
2)get someone to push you as you are on the bike. You need to pushed enough that you can coast yourself.
3)get ready (after the person lets you go) to pull in the clutch, put in first, push the start button then pull throttle ALL AT THE SAME TIME!!!!!!!!
The speed will jump start the bike, just be ready for it to take off and get ready to brake. Drive over to the bike shop and buy a Battery charger its only like maybe $60. If you jump it by car or higher AMP charger like the one you said, It will either mess up your battery or your bike electronics.
__________________
Gixxer Clutch
2006 GSXR 600
Past Bikes
2006 Honda F4i
www.myspace.com/agrownman
www.cyclespace.com/735
Gixxer clutch is offline   Reply With Quote
Old 09-04-2006, 08:28 PM   #3
newbie
Default ...
what kind of recharger is good? I have a yuasa (sp.?) battery if that matters and where could I get this. Sorry for the questions but I am new to this bike thing and always ask questions so I can learn the ins and outs the first time around. thanx
Old 09-04-2006, 08:45 PM   #4
Gixxer clutch
Default
no problem, well you should get the charger for the motorcyle. Its actually for motorcycle batteries and it has little clamps
__________________
Gixxer Clutch
2006 GSXR 600
Past Bikes
2006 Honda F4i
Old 09-04-2006, 09:07 PM   #5
newbie
Default ..
if you don't mind one more question. Could you tell me what the heck fairing stays are and where could I look if I need them or not. I bought this bike from some guy who I think got me alittle and I am gradually finding more and more wrong with this bike and its starting to get super frustrating. I am going to need a shit load of stuff done to it and now it's getting scary money wise and labor cost wise.
Old 09-04-2006, 09:41 PM   #6
Gixxer clutch
Default
I dont understand the question about the fairing make sure you are asking correctly
__________________
Gixxer Clutch
2006 GSXR 600
Past Bikes
2006 Honda F4i
Old 09-05-2006, 10:50 AM   #7
SILVERK5
Racer
SILVERK5's Avatar
Default
okay
There is something I don't understand in there in your number 3)....
If you pull in the clutch, how can the speed jump start the bike since the rear wheel is not engaged to the engine ???
And if you let go of the clutch and you're in gear, the starter won't operate ...
I always wondered about jumpstarting a FI bike...
Jump starting Carburated bikes: put it in 2nd gear, turn ignition on, pull the clutch in, push the bike, dump the clutch, the bike starts....
Would that procedure work on a FI bike which needs to pressurize the fuel system/injectors ???
__________________
GSX-R1000 K5 (So fast)
VFR750 1990 (So smooth)
TwinStar 185 1978 (So old... It's my 1st bike!)
SILVERK5 is offline   Reply With Quote
Old 09-05-2006, 11:13 AM   #8
04GSXR750
04GSXR750's Avatar
Default
Silverk5, yes it will work. I usually do it in 1st gear. never tried it in 2nd.
04GSXR750 is offline   Reply With Quote
Old 09-13-2006, 09:38 AM   #9
Gixxer clutch
Default
I never tried it in 2nd gear either.
__________________
Gixxer Clutch
2006 GSXR 600
Past Bikes
2006 Honda F4i
Old 09-13-2006, 09:59 AM   #10
whtthundysc
Racer
whtthundysc's Avatar
Talking
2nd is easier, you dont have to push it as hard---and dont worry about hitting the start button---that wont help you---it dosent matter---you could allways drive your bike around a couple miles to recharge the battery by it self, so then there would be no reason to go buy a charger---
also you can use a car battery or charger to jump your bike, it will not hurt anything at all, due to your bike runs off a 12v system-just dont keep the charger on the bike for to long because it will back feed into your alternator and cause it to not charge your battery.
your bike might have such a bad battery that after removing the cables from either a charger or a jump from another battery it will cause the bike to die and not stay running-if this is the case you have a bad battery.
the longest i would keep a charger, or jumper cables on would be about 2 minutes---to try to help charge that battery!!
whtthundysc is offline   Reply With Quote
Old 09-13-2006, 10:55 AM   #11
Gixxer clutch
Default
But You should not start the car at all. when charging to a car battery it will mess up the electronics.
__________________
Gixxer Clutch
2006 GSXR 600
Past Bikes
2006 Honda F4i
Old 09-14-2006, 06:44 AM   #12
whtthundysc
Racer
Default
no it wont---
Old 03-10-2007, 08:05 PM   #13
gixxer1000
gixxer1000's Avatar
Default
Sorry to bring up an oldie, but just wondering if our stock batteries that come in the bike are 'gel' cell or regular?
I checked in my owners manual and it wasn't too detailed about it, just said it's a sealed type and requires no maintenance.
gixxer1000 is offline   Reply With Quote
Old 04-09-2009, 10:17 AM   #14
apostille
Squid
Batteries store electrical energy. Some, like conventional flashlight batteries, are used then thrown away. Others are rechargeable. On the island, we had a car battery which was used to power various pieces of Rough Science apparatus but over time the battery became discharged. We were given the challenge of recharging it.
apostille is offline   Reply With Quote
Old 04-09-2009, 10:36 AM   #15
oldfart
oldfart's Avatar
Default
Originally Posted by whtthundysc View Post
no it wont---
Yes it will..
The donor vehicle should be OFF when doing a jump start and remove the cables as soon as the target vehicle fires up.
Other wise YES you will do electical damage to one or both vehicles.
oldfart is offline   Reply With Quote
Old 04-09-2009, 11:20 AM   #16
Raqiib
Raqiib's Avatar
Default
check your cable connections...it might just be a loose connection...mine's made the clicking sound and didn't start last night...pulled the seat off this morn to find the negative cable was loose....your's might just be loose or dirty...
Raqiib is offline   Reply With Quote
Old 06-16-2009, 09:16 AM   #17
divorce certificate
Squid
How does a battery work?
Every atom consists of a positively charged nucleus called a proton surrounded by a number of smaller, negatively charged particles called electrons. If atoms lose or gain electrons, they are left with a positive or negative charge and they are then called ions. In an electrically conducting solid such as a wire, some of the negatively charged electrons are able to move around fairly freely around the fixed array of positively charged protons. Although these 'free' electrons can move, there is a force which keeps the electrons — and so the charge — evenly spread along the length of the wire.
__________________
no advertising allowed
divorce certificate is offline   Reply With Quote
Old 06-16-2009, 11:17 PM   #18
LeDucRacing
Squid
Default
To make it easy buy a new battery!
LeDucRacing is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
