Putting HID's in a 04 GSX-R 600 : GSXR.com Forum : Suzuki GSX-R Forums
» Insurance
» Suzuki GSX-R Prices
» Sponsors
Go Back   GSXR.com > Chat > General GSXR Chat
Thread Tools Display Modes
Old 01-04-2007, 03:34 PM   #1
bjelder
bjelder's Avatar
Default Putting HID's in a 04 GSX-R 600
So I want to put some HID's in my gixxer.
Problem is, I'm not sure which headlights are which. I just got this bike a few days ago and am still mad confused as to which light comes out of which place on the bike.
Heres the front end:
So I want to make the low beam HID come out of that bottom projector housing (the circular thing), and I guess the high beam come out of the top. But I noticed with regular headlights, both of them light up at the same time? I'm super confused.
Any help, and links on to where to buy these would be greatly appreciated.
Thanks.
bjelder is offline   Reply With Quote
Old 01-04-2007, 04:14 PM   #2
Leonwho
Banned
Leonwho's Avatar
Default
I'd HID the low beam, no point in making both HID.
Unless you plan to make someone blind for the rest of their life.
Leonwho is offline   Reply With Quote
Old 01-04-2007, 04:51 PM   #3
lama
lama's Avatar
Default
low beam is the bottom projector. the bulb size is h7
__________________
2005 GSXR-600/750 - 2003 Greddy TT 350z
lama is offline   Reply With Quote
Old 01-04-2007, 05:15 PM   #4
bjelder
bjelder's Avatar
Default
Awesome. Then why does light come out of both (upper bowl and lower projector)?
Old 01-04-2007, 05:26 PM   #5
lama
lama's Avatar
Default
because the top reflector is also low beam, its a dual filament bulb. one filament is for low beam and the other is for highbeam. i would not put hid's on the top though
__________________
Old 01-04-2007, 05:51 PM   #6
bjelder
bjelder's Avatar
Default
ok so there are basically 3 headlights.
low beam - in projector
low beam - in top bowl \---both these two are the same bulb
high beam - in top bowl /
Old 01-04-2007, 06:03 PM   #7
lama
lama's Avatar
Default
thats basically it. although the reflector low beam acts more like a running light, you wouldnt even notice it if you removed it at night.
__________________
Old 01-04-2007, 07:21 PM   #8
UDLUZE
UDLUZE's Avatar
Default
I've got HIDs top and bottom. I've got the bottom projector as the low beam, and both are on for the high beam. It is extremely bright. I can see so much better riding at night. I have a dark smoke shield on my helmet and have no problems seeing at night. Oncoming traffic doesn't appreciate it as much as I do and my friends refuse to ride out in front of me if I have the high beam on.
UDLUZE is offline   Reply With Quote
Old 01-04-2007, 09:20 PM   #9
Jbranzgsxr
Jbranzgsxr's Avatar
Default
hey UDLUZE, could you pm me how you did the HID stuff cuz i too have an 05 and i would like to get more light and i wanna know how much customization (cutting type stuff) you had to do and how hard it was... thanks brah
__________________
05 yellow gsxr. metzler m3's, yoshimura slip on, puig db windscreen
Jbranzgsxr is offline   Reply With Quote
Old 01-08-2007, 11:28 AM   #10
SamIamNYC
SamIamNYC's Avatar
Default
haha thats true!
SamIamNYC is offline   Reply With Quote
Old 06-09-2011, 06:45 PM   #11
patslick09
Squid
Default
How do u get to the bulbs easier tho
patslick09 is offline   Reply With Quote
Old 06-09-2011, 06:46 PM   #12
patslick09
Squid
Default
Also do u need a spacer I'n the low high beam on 05 should be same as 04
Old 06-09-2011, 07:16 PM   #13
henwon
Squid
Default
has anyone done a how to for the k5 gsxr? i'm the same situation right now, i have the kit but haven't installed yet. i haven't been able to find anything for the 04-05 gsxr's.
henwon is offline   Reply With Quote
Old 06-29-2011, 07:08 AM   #14
SoccerDad
SoccerDad's Avatar
Default
I'm finding that HIDs on the K5 is very frustrating. Inside the projector is a peice of metal with two squares cut into it. When the HID bulb is on, it makes a very weird light pattern. The best way I can describe it is it looks like the eyes and mouth of jack o lantern. I have headlight housing in two peices to try to get that out of there, but I cannot get to it to cut it out. :(
__________________
K5 600
SoccerDad is offline   Reply With Quote
Old 06-29-2011, 07:12 AM   #15
cooper232
Default
H7 Low beam
H4 Low/High beam
Slim ballasts (make sure one has 2 wires and the other has 3 wires)
No cutting or splicing.
Plug your original harness into the ballast, then plug the ballast into the new bulbs. Use some good 3m double sided tape to mount the ballasts inside the fairings. Most people mount them on the left side fairing behind that little splash guard.
SUPER EASY job!!!
Good luck!
cooper232 is offline   Reply With Quote
Old 06-29-2011, 10:47 AM   #16
GixxerFace
Squid
Default
This is a really easy job. If you can screw a lighbulb into your lamp at home, you're more than qualified to install HID's hahaha.
__________________
no advertising in signatures, thank you..JP
GixxerFace is offline   Reply With Quote
Old 04-21-2012, 06:33 PM   #17
dimmick23
dimmick23's Avatar
Default
Is there a way to stop the lo beam from shining on the top bulb? Would I get a single bulb or what? Or do I just keep it because they wont notice it with my HIDs on?
dimmick23 is offline   Reply With Quote
Old 04-21-2012, 07:28 PM   #18
euroids
Default
Haha i wouldnt go that far, there are things to plug in and such.
euroids is offline   Reply With Quote
Old 04-23-2012, 11:48 AM   #19
dimmick23
dimmick23's Avatar
Default
It is definitely easy as hell to do this. It is truly plug and play. It took me a matter of 30 min tops and that may be over exaggerating. Also that is taking the top fairing off, windshield and speedo just to make sure I had room to work.
Old 04-23-2012, 11:50 AM   #20
dimmick23
dimmick23's Avatar
Default
I'm also still wondering if I can replace the dual filament bulb with a single filament bulb to work with just my highbeam.
Old 05-04-2012, 01:15 PM   #21
dimmick23
dimmick23's Avatar
Default
If anyone can help me with the above question I would love it. Thanks.
Old 05-04-2012, 01:26 PM   #22
1detroitryder
1detroitryder's Avatar
Default
i have a k5 and i've installed my HID kit H4 is the top bulb it has a smaller bulb attached that acts like the High beam.So Dimmick if you get the H4 bulb there's nothing to worry about mine works great .. ive attached a image to explain
1detroitryder is offline   Reply With Quote
Old 05-05-2012, 07:06 AM   #23
dimmick23
dimmick23's Avatar
Default
But this will eliminate my 2 low beams from shining all the time? I want the top bulb off unless I put my high beams on. Basically my low beam is the projector on the bottom and I just want the top bulb to only be my high beam. I was wondering if just pluging in a high beam bulb if that would make that happen.
Old 07-30-2012, 07:28 PM   #24
Seansgsxr06
Default
Do you have a problem with them flickering on an off? I have hids in my highs n lows n at night they shut off on me an it gets kinda scary..lol
Seansgsxr06 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
