F1 code? what is that? : GSXR.com Forum : Suzuki GSX-R Forums
» Insurance
» Suzuki GSX-R Prices
» Sponsors
Thread Tools Display Modes
Old 02-01-2008, 04:51 PM   #1
whitegsxr
Default F1 code? what is that?
so i bought a 2004 gsxr 600 and didnt notice that red light and the flashing F1 in the temp area.. Question is what is that and how do i get rid of it? can i still ride with it on like that without messing up the bike?
2004 gsxr stock with yosh pip...
whitegsxr is offline   Reply With Quote
Old 02-01-2008, 06:01 PM   #2
johnnylovely
johnnylovely's Avatar
Default
fix it
__________________
master moto tech...fire away.
johnnylovely is offline   Reply With Quote
Old 02-01-2008, 10:32 PM   #3
whitegsxr
Unhappy
Originally Posted by johnnylovely View Post
.....but i dont know how.
Old 02-02-2008, 12:38 AM   #4
illest
illest's Avatar
Default
use the search feature on this site. you'll find instructions on how to put the bike in dealer mode which will give you the FI code, like C(some#). This code corresponds to what the issue is on the bike. Find out what the code is and again use the search feature to find it out. It most likely has something to do with your exhaust, but you never know.
Like I said, do some searching on how to put the bike in dealer mode and pull a code.
Good luck!
__________________
06 GSXR600 Black and Grey
illest is offline   Reply With Quote
Old 02-02-2008, 04:40 AM   #5
ianbis
Default
think of it as your "Check engine light"
ianbis is offline   Reply With Quote
Old 02-02-2008, 06:06 AM   #6
WoodShoe
Racer
WoodShoe's Avatar
Default
This thread shows all the fault codes and how to pull them, zereU go
http://www.gsxr.com/showthread.php?t=1234
__________________
KSIX600 w/ K7750 swap -- PCIII + LCD + WIDEBAND02, K&N, -2 / + 1
WoodShoe is offline   Reply With Quote
Old 02-02-2008, 06:38 AM   #7
06gixx1000
06gixx1000's Avatar
Default
It is a FI not F1 light fyi.....i had the same problem when i change my pipe. Just have it re-mapped and you will be good to go!!
__________________
'06 GSXR-1000 (SOLD)
New Toy:
'11 GSXR 1000
Black/Gold
M4 Street Slayer Carbon
Bazzaz ZFi
ASV's
VHT Signals
06gixx1000 is offline   Reply With Quote
Old 02-02-2008, 08:45 AM   #8
ScottySev23
Squid
Default FI light
I have an '06 600 and I'm in Jersey. Riding time is limited so in the winter I start it up every 2 - 3 weeks. The FI is for Fuel Injection on the '06's. I would assume it's the same for all. My red light and indicator came on this morning, I let it run for 15 mins. I shut the bike off, then restarted it, and now it's off. Try to same and when the bike gets up to a good temp, rev the throttle to 7 or 8 rpms. If all else fails, call the dealer first before taking it there so you don't waste a ton of $$.
ScottySev23 is offline   Reply With Quote
Old 02-02-2008, 08:55 AM   #9
whitegsxr
Default
i just found out the code was C46,sorry iam a noob to this.. how do u re-mapped?
Old 02-02-2008, 09:01 AM   #10
M_Easy
Easy duz it.
M_Easy's Avatar
Default
That's your SET Valve. This should help.
EDIT: You'll have to click on SET Valve, not a direct link.
__________________
GSXR.com Super Moderator
Email me | k6 1k Manual | Search on steroids.
K6 1000 | K1 1000
Sl_Easy does it....
If someone gets a job manufacturing Blackberry's, did they get a RIM JOB?
M_Easy is offline   Reply With Quote
Old 02-02-2008, 10:03 AM   #11
whitegsxr
Default
sorry my friend told me wrong about the code C46, Does any one know where i can locate the dealerswitch so i can find out the code?i looked allover the plac e on my 2004 but i cant find it....
Old 02-02-2008, 03:50 PM   #12
johnnylovely
Default
Sorry, I guess its a little hard to tell from the post but if you would have clicked on the "fix it" in the original post it would have taken you to a page with more a indepth discription of your problem and a way to test it.
__________________
Old 02-02-2008, 04:15 PM   #13
gon2fast
gon2fast's Avatar
Default
Incase you didn't find it. There is no dealer switch on your bike. You have to find two wires on a blank pigtail and put a jumper between them. Or better yet, install a rocker switch somewhere on your bike. The wires on all the bikes I've seen are on the left side under the rear fairing. The switch is the way to go because this is a pain to do everytime you have a code.
__________________
07' GSX-R750 , Shortened Scorpion Flame Titanium Exhaust, PCIII USB, Ignition Module, Dynotech Wide-Band kit, Vortex Frame Sliders and Swingarm Spools, Sportech windscreen, Pazzo Levers, Pilot Power 2CT's, -1 Front sprocket, Speedo-healer, R1 Throttle Mod, GPR stabilizer, Sato rearsets, Galfer stainless brake lines, Ohlins front and rear suspension
gon2fast is offline   Reply With Quote
Old 02-02-2008, 05:27 PM   #14
Gix1078
Gix1078's Avatar
Default
There is a plug in the tail section, you can buy "dealer switch" and connect to it, if ever "F1" code shows, you simply click the switch, and get the code on your dash...
if C46 is the code, i would check the exhaust control valve.
Does your bike have aftermarket exhaust?? if so, then thats probable the reason. if the one who changed the exhaust, removed the control valve, you need to get one, plug it in, and fasten it somewhere where it´s save.
__________________
"Bikes don’t fall down, riders drag them down,"
Gix1078 is offline   Reply With Quote
Old 02-02-2008, 05:48 PM   #15
whitegsxr
Default
Do happen to have a pics of that the plug looks like and where its located or sitting by?
Old 02-02-2008, 06:05 PM   #16
Gix1078
Gix1078's Avatar
Default
No pix, sorry..
but on my 1000, it´s located in the left side of the tail section, has a rubber cover over it.
I´m not sure where exacly it is on the 600, but it is there in the tail section.
Call 001-803-285-8093 on monday, ask for Dwayne, he´ll help you, i think he can even get you this dealer switch.
__________________
Old 02-03-2008, 07:06 AM   #17
WoodShoe
Racer
WoodShoe's Avatar
Default
On the k6six, its a 6pin female connector. has a black rubber cap on it. Sits near the negative terminal of the battery. Its prolly jammed into the crack in there somewhere...There is a pic of it in the manual, if you go to the Technical FAQ section, and look for the manual for your bike, im sure u will find it.
__________________
Old 02-03-2008, 07:56 AM   #18
Gix1078
Gix1078's Avatar
Default
You should find it here.. http://www.carlsalter.com/.manuarlz/...ice_Manual.pdf
__________________
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2007 — 2008 GSXR.com
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
