Your going to have to take out the speed sensor rotor (the allen nut your referring to), then when taking the bolt holding the sprocket on, you will need to run a bar through your rear wheel against the swing arm to keep the wheel from spinning. You may need a breaker bar. The Sprocket nut is on VERY well. Make sure you retorque everything back to specs. Why are you going stock?
__________________
2006 GSXR750
PC3
R1Throttle
TRE
K&N
-1
Velocity Stacks
+1 do it that way and get a long braker bar to help you out cuz it is on there very tight!! dont waist your time with an impact wrench!
__________________
My new:k7 GSXR 600
My old: 2004 Sonic Blue SVT Lightning
My stunt bike: 94 cbr600 f2
I have a Snap on electric impact. 800ft lbs of torque anyone?
I am trying to sell the bike so I want the speedo to be correct again. Or if I keep it I am tired of the speedo being so messed up. Plus I want to keep the mileage down some. Its already to 7600 since last March.
__________________
2007 GSXR-600- SOLD
k7 GSXR- 750 grey/black
good luck with getting the sprocket off. I also have a question
i thought i would post here. I need opinions from people who own
a 1000. i own a 2006 1000 i'm wanting to change the gearing
does the -1 on the front change the gearing that much. is what
i'm looking for is lower quarter mile time but also i want to
clutch third easier for wheelies or is the -1+2 a better option just wanting opinions before i spend the money.
go down 1 if the front 1st!! then if you still want more go for the up 1 or 2 in the back!! dont do -1 +2 at the same time!!!
__________________
My new:k7 GSXR 600
A speedo healer would have solved all your problems.
__________________
2006 GSXR750
PC3
R1Throttle
TRE
K&N
-1
Velocity Stacks
How much does it throw your speedo out by? Are you only -1 on the front or +2 on the rear too? I am thinking about doing this myself but probably won't be able to get a speedo healer til next month at least :(
