1999 GSXR 750 Headlight Issues : GSXR.com Forum : Suzuki GSX-R Forums
» Insurance
» Suzuki GSX-R Prices
» Sponsors
Go Back   GSXR.com > Chat > General GSXR Chat
Closed Thread
Thread Tools Display Modes
Old 05-11-2008, 08:42 PM   #1
N473
Squid
Default 1999 GSXR 750 Headlight Issues
I am relatively new to motorcycles and I just bought a used GSXr 750 and I noticed that the headlights don't seems to work. They worked when I originally bought the bike but now they seem to not be working. They are dual headlights and I'm not really sure what to do any suggestions for this newbie would be great.
Thanks,
N473
N473 is offline
Old 05-11-2008, 08:44 PM   #2
lushbaugh
Default
theres a fuse box below and in front of the cluster check there if that dont show a bad fuse then check the bulbs .....if that isnt that let me know
lushbaugh is offline
Old 05-11-2008, 09:26 PM   #3
N473
Squid
Default
This is probably a stupid question how do I check the bulbs?
N473 is offline
Old 05-11-2008, 09:32 PM   #4
flipcyder
Racer
flipcyder's Avatar
Default
If your high beams work, then it's most likely a loose wire within the light switch. I had the same problem on my 98 600 srad. I took it to a shop and all they did was solder it back on.
__________________
http://671metricunit.com/
flipcyder is offline
Old 05-12-2008, 07:18 AM   #5
N473
Squid
Default
Yeah the lights don't turn on at all the high or low beams don't work. How do I check the lights?
N473 is offline
Old 05-12-2008, 08:48 AM   #6
Jondough
Default
You can check the bulbs by buying a new one and trying that, if it works your old bulbs are bad. Or you can get a multimeter and put on the wires to see if your getting power to the bulb. Or you can get a light tester and see if your getting power to the bulb. If your not getting power to the bulb check and see if your getting power to your switch. If your not getting power to your switch its probably a fuse which you should probably check first.
Jondough is offline
Old 05-12-2008, 09:06 AM   #7
N473
Squid
Default
I checked the fuses last night and they seemed to look fine. It has to be something with the wiring because both of the lights are not working anyways. I'll just have to play around with it and report back when I get the solution.
N473 is offline
Old 05-12-2008, 09:10 AM   #8
JohnPaul
Pro Crastinator
JohnPaul's Avatar
Default
a test light is your best friend with these kind of issues. bulbs ok, test to be sure they are getting juice etc. then start testing wires back to origin point etc. will save alot of frustration...imo
JohnPaul is offline
Old 05-12-2008, 09:28 AM   #9
gixxer32404
gixxer32404's Avatar
Default
Were both bulbs originally working? bulbs went in probably same time...so both could've blown. Generally u can shake and it will rattle if blown,. always could buy 1 if not the problem, u will have a spare. DON"T touch the bulb oil from your skin will cause it to blow. Also, if u are new a 750 is probably too big to start on. I rode a 500 for 4 years b4 getting a 750.If u are abdamant, then u will want to take it easy on the 750.
gixxer32404 is offline
Old 05-12-2008, 10:53 AM   #10
Jondough
Default
Well, now that he owns it, its gonna be hard to keep him from riding it.
Jondough is offline
Old 05-12-2008, 11:02 AM   #11
ZOOK750
Default
I am having the same issue and i traced it down to the harness in the left fairing cover. It is a yellow connector with 10 to 12 wires in it and if i wiggle the connector my lights come on. The connector comes from your light switch on your left bar. i zipped tied mine into place above the horn and they seem to be working fine now, but will have the connector replaced soon. Might want to try that.
ZOOK750 is offline
Old 05-12-2008, 11:24 AM   #12
gixxer32404
Default
on a side note, wish people would list their city and state. u may have someone who can help u right there. imo
Old 05-12-2008, 08:09 PM   #13
plytymgixr
plytymgixr's Avatar
Default
+1
__________________
you will forget about how bad it is by the time you hit 3rd gear: www.playtimeriders.com
plytymgixr is offline
Old 05-12-2008, 09:41 PM   #14
gixxer32404
Default
Originally Posted by plytymgixr View Post
+1
LOL I'm former LEO and I guarantee some stalker won't find me in the phone book under my name or gixxer32404 in my city and state.
Old 10-13-2008, 03:18 PM   #15
rgaf019
Squid
Default
I was having the same problem. Also, when I was turning my haddlebar completely to the right, the lights turned on. My problem was that yellow connector under the left fairing cover. I disconnect it and connect it back tight and it work good so far. I figured the reason for the lights to turn on when I turn right was that it pull the wire just enough for the electric current to pass.
rgaf019 is offline
Old 09-30-2010, 09:40 AM   #16
Jvasquez
Squid
Default
Try the relay in the ignition switch. Most likely a loose wire
Jvasquez is offline
Old 09-30-2010, 11:07 AM   #17
sradmad
Squid
Default
It happened the same on 600 srad.The yellow block l\h\s removed each connector from the block and cleaned.Cured the problem.There is also a headlight relay on some usually near the fuse box and similiar in size.
sradmad is offline
Old 10-20-2010, 09:00 PM   #18
carjunkie80
Squid
Default
Originally Posted by N473 View Post
I am relatively new to motorcycles and I just bought a used GSXr 750 and I noticed that the hid bulbs don't seems to work. They worked when I originally bought the bike but now they seem to not be working. They are dual headlights and I'm not really sure what to do any suggestions for this newbie would be great.
Thanks,
N473
Correct me if I'm wrong but I do believe the bulbs you're looking for are the 1157.. If I was you I would get someone who knows about bikes to install it or else it's just not going to work.. Good luck buddy.
carjunkie80 is offline
Old 12-13-2011, 08:33 PM   #19
iitz j roc
Squid
Default
I'm having the same problem on my 97 SRAD 600, have had to mess with the wires under my left faring to get my headlights to come on.
If you zip tie the wire in a ceartian position it stays on till i hit a bump or tun off the bike.
My switch is broken to change from bight to dim but that hasn't given me a issue.
I'm gunna look at this yellow connector and to see if it solves my problem.
iitz j roc is offline
Old 12-21-2011, 11:39 AM   #20
iitz j roc
Squid
Default
still no luck, where is this yellow connector? in the left faring? or under the headlights
Closed Thread
You may not post new threads
You may not post replies
Forum Jump
