Help!! type of brake fluid to use : GSXR.com Forum : Suzuki GSX-R Forums
» Insurance
» Suzuki GSX-R Prices
» Sponsors
Thread Tools Display Modes
Old 10-27-2009, 02:10 PM   #1
tomgunz13
Squid
Default Help!! type of brake fluid to use
New to the bike world, trying to find out what kind of brake fluid i can use in my 2000 gsxr 600, DOT 3 or DOT 3 full synthetic??
tomgunz13 is offline   Reply With Quote
Old 10-27-2009, 03:02 PM   #2
jtownthug
jtownthug's Avatar
Default
The lid should say dot 4 only. And you should use dot 4 or higher. If you put dot 3 in there you might have to drain it all out and flush/ bleed the brakes. It wont handle the high temps of a sport bike. You don't want your brakes to fail.
jtownthug is offline   Reply With Quote
Old 10-27-2009, 03:09 PM   #3
oakleyspatz
Racer
oakleyspatz's Avatar
Default
Dot 3 brake fluid is the lowest quality you can get, synthetic or otherwise and was really designed for older vehicles. It has a very low boiling point and in a high performance motorcycle your fluid could get very hot. Also it is very hydroscopic (absorbs water).
Suzuki recommend Dot 4 fluid and they also recommend never to mix fluids ( although Dot 3, Dot 4 and Dot 5.1 can in theory all be mixed). Dot 5 is not recommended and should never be mixed with other Dots) Dot 4 has a higher boiling point and is slightly less hydroscopic. Assuming your current fluid is Dot 4 non-synthetic, then if you are going to a full synthetic, you should completely flush the system before changing. But full synthetic isn't really that critical. It is recommended for ABS braking systems as it has a lower viscosity (is thinner) than non-synthetic.
I would buy a good quality Dot 4 standard fluid or if you wish, a synthetic Dot 4 but as you cannot be 100% sure what type is already in there, it would be a good idea to flush the system anyway. I'm sure the fluid you already have in there will have collected some water moisture anyway which can corrode the brake lines over time so a change as opposed to a top-up is probably best.
__________________
www.alstarereplica.co.uk
oakleyspatz is offline   Reply With Quote
Old 10-27-2009, 05:34 PM   #4
you da man
Anti-squid moderator
you da man's Avatar
Default
Motul RF600 is the shizzle by far.
__________________
GSXR.com Super Mod
"Motorcycle racing is a dangerous hobby for those who've never done it." - Jean Alesi
When I stand before God at the end of my life, I would hope that I would not have a single bit of talent left, and could say, "I used everything you gave me."
CMRA #599
you da man is offline   Reply With Quote
Old 10-27-2009, 05:40 PM   #5
DIABLOGSXR
Racer
DIABLOGSXR's Avatar
Default
just go with good ole DOT 4
DIABLOGSXR is offline   Reply With Quote
Old 10-27-2009, 05:45 PM   #6
oakleyspatz
Racer
Default
Motul RBF600: Excellent Dot 4 fully synthetic fluid. Used by many racers and has an extremely high boiling point and very low hydroscopic properties. Some may say it's overkill on a road bike but I agree with you da man.....Anything else is a compromise!!
__________________
Old 11-02-2009, 06:01 PM   #7
tomgunz13
Squid
Default
Thanks everyone, I went with the DOT 4 synthetic.
Old 11-04-2009, 10:06 AM   #8
JETMECHANIC
ATTITUDE COUNTS
JETMECHANIC's Avatar
Default
I use Super Blue In the bike and in the IS
__________________
INTEGRITY . Doing the Right thing even when no one is looking
JETMECHANIC is offline   Reply With Quote
Old 11-04-2009, 02:11 PM   #9
yakitori
yakitori's Avatar
Default
I used a DOT3 and 4 fluid. The container says its both 3 and 4 compatible. Should I flush and switch to 4 only?
yakitori is offline   Reply With Quote
Old 11-04-2009, 02:27 PM   #10
oakleyspatz
Racer
Default
I would say yes...Your brakes are probably the most important item on a high performance motorcycle, it's prudent to make them as good as possible. Dot 3 is,to be honest, crap and not really any good for a sportsbike. Suzuki recommend Dot 4 and not to mix different Dot fluid. Although this isn't essential, Suzuki recommend it to ensure maximum performance and remove any chance of compatibility issues between different Dot fluids.
It's up to you at the end of the day and carrying on as you are, you may never have a problem with the brakes, but wouldn't you feel safer knowing your brakes are as good as they can be?
__________________
Old 11-04-2009, 02:49 PM   #11
SlowSteve
Default
Motul RBF 600 is one of the better racing brake fluids for track and hard street application. Though it should be changed with some frequency, depending on usage. Fluids with high dry/wet boiling points tend to be more hydroscopic. When in doubt, flush the old and refresh.
__________________
SlowSteve is offline   Reply With Quote
Old 11-05-2009, 10:01 AM   #12
jayski
Squid
Default
I would stick to the same brake fluid rating. Be it DOT4 or full synthetic. Don't mix em together at all. I'd recommend doing a full brake bleed at the end of each season or at some point during a given year. I mean it's fairly cheap to do!
jayski is offline   Reply With Quote
Old 11-05-2009, 11:19 AM   #13
Chad Allen
Chad Allen's Avatar
Default
Use DOT 4 or higher because of the heat build up.
__________________
03 1000
Chad Allen is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
