thinking of gettin that as a replacement for the last 2 months left in this season in my area....anyone used it before?? its either this or store the bike because i dont have enough money for a better one..
reasoning is it just a that bad? theres multiple brands on motosuperstore for under 40 bucks....
Experience has shown me you get what you pay for...
If this is your only transportation and you need a chain to get buy is one thing but to buy a cheap ass chain that could damage the bike or the rider if it fails, I just can't do it....
The one review from the link: "Had to replace it with a DID" and the facr that it costs $30..Hello red flags! It may be safe to use on your Mongoose tho. Good luck with your decision!
__________________
Originally Posted by JohnPaul
buncha fat fawks in here...you dont need a liter bike, you need jenny craig
Holy geezus! I'd be affraid to put that thing on a pedal bike. Imagine it comming off at 200km/h and doing something fun like attaching itself to your foot.
Dont forget youre also going to need some chain tools. . . I did mine without, like a filthy mcguyver . . . but it was a PITA
Chain started clunking lightly after a 300 mile ride all day. it started after getting off the highway. anyway, i thought it was just loose so i tightened it up and the clunking stopped...
the clunk came back a month n a half later, so i decided to clean, lube and retighten the chain again. there is a certain spot where the chain is very tight, and another spot where it gives me over an inch of slack...so i loosed it to the point where the very tight spot gave 3/4" or so slack and the loose spot now had almost 2" so im assuming its over stretched.. the rear sprocket is good, the front might need to be changed too tho.
should i jus swap the front sprocket which i can get locally very cheap $20...im pretty sure the slack is telling me the chain is shot too...
Well I thought about it and just bought a chain/sprocket set off a totalled motorcycle spot. 45 bucks for used chain and both sprockets with 1 month guarantee. itll hold me off for the rest of the season
