replaced sprocket and chain but have a question - GSXR.com
  • 1 Post By Vader225
post #1 of 12 (permalink) Old 04-20-2019, 11:35 PM Thread Starter
I might have tightened the master link a little too tight. I used a vernier caliper to measure and the master link is 2-4mm less compared to the other links. it doesnt kink but i can tell it doesnt move as freely as the others. do i need to redo it with a new master link? what do you all think?
gixxer6002007 is offline
post #2 of 12 (permalink) Old 04-21-2019, 10:12 AM
What measurement are you getting 2-4mm less on? The width of the chain? That sounds like a lot. It doesn't kink? On a rear stand it rulls freely w/o one one or more of the links staying at an angle? Did it move freely by hand.
We may need some more info and the experts on here will be able to help I'm sure.
Todd_Sails is online now
post #3 of 12 (permalink) Old 04-21-2019, 10:12 AM
Sounds like you got the wrong link up there. I'd get a new one and redo it.
busdriver likes this.
post #4 of 12 (permalink) Old 04-21-2019, 01:27 PM
coreyyok's Avatar
What did you use to crimp the link? The 2-4mm sounds like alot if difference unless you crushed the link. If you plan on doing much bike mantinace I would look into investing in a chain tool to brake/rivet masterlinks. You can get them for little money and they make things much easier. I would check with calipers the link widths and your master and if it's binding can cause sprocket or chain damage. That could be dangerous for you and others around you if something fails. So, at the very least I would get a new link and ty again.
Work Hard, Play Harder
coreyyok is offline
post #5 of 12 (permalink) Old 04-21-2019, 03:01 PM Thread Starter
ooops sorry, the different is about .4mm but its hard to move by hand and it does stay a little kinked. Will it be ok to ride for a little bit till i get a new master link? I'll probably be changing it next week or so.
post #6 of 12 (permalink) Old 04-21-2019, 09:28 PM Thread Starter
never mind, i put it on a stand and put it in gear and doesnt sound right. since i already have the chain tensioned to specs, can i just put the master link on the rear sprocket, pop the old master link it out and put and rivet the new master link?
post #7 of 12 (permalink) Old 04-21-2019, 10:48 PM
never mind, i put it on a stand and put it in gear and doesn't sound right. since i already have the chain tensioned to specs, can i just put the master link on the rear sprocket, pop the old master link out and put and rivet the new master link?
Yes, that's what I would do, other thing I recommend is using this chain lubricant. I've found it works a lot better than anything else I've used. Remember it's better to be a little bit loose than too tight.
post #8 of 12 (permalink) Old 04-22-2019, 07:17 AM
Does your chain tool have spacer plates to prevent crushing an o=ring?
post #9 of 12 (permalink) Old 04-22-2019, 07:43 AM
This too is what I use.
I got it shipped from Wal Mart- of all places!
I got 6 cans so I got free shipping.
Definitely has less chain lube fling off on the bike anyways.
post #10 of 12 (permalink) Old 04-22-2019, 03:00 PM
stunter's Avatar
I use the same stuff... so far I like it... as for link I replace chain and sprockets a couple week ago and don’t have a tool for master link so I ordered the screw type and it was easy to install with no issues
stunter is offline
post #11 of 12 (permalink) Old 04-22-2019, 09:19 PM Thread Starter
I dont have any spacer. Thanks for responding guys. I should be getting the new master link this wed so hopefully i can ride this weekend. Can i use the screw type link on D.I.D chain or just Ek?
post #12 of 12 (permalink) Old 04-23-2019, 06:27 AM
Pressed links don't back out, ever.
Replaced Stator and Rectifier but no start tbirdette Tech and performance chat. 13 06-27-2013 03:22 PM
replaced high beams and position light bmstyle71 General GSXR Chat 20 09-15-2010 10:19 AM
just replaced clip ons and.... Mickey305 Tech and performance chat. 6 05-13-2009 08:06 PM
Anyone replaced cam chain tensioner? Emrys Tech and performance chat. 0 11-23-2004 07:23 PM
