can someone tell me if this is normal - GSXR.com
post #1 of 4 (permalink) Old 04-22-2019, 10:45 PM Thread Starter
2007 gsxr 600. when i start my bike, i noticed the headlights and other lights dim and normal. Its not bad but noticeable . is this suppose to be normal if not, what could be the issue. I have brand new battery probably a few weeks old. i have really ran my bike for long, several starts running it less than 5-10 mins.
gixxer6002007 is offline
post #2 of 4 (permalink) Old 04-23-2019, 12:55 AM
Are you saying that the headlight is dimmer with the engine running compared to before you start the bike, or that the headlight dims when starting/cranking the bike?
If itís the former, check your battery voltage at idle and 5k rpm with a digital multimeter set to DC volts. Should be 14 to 15.5V. With the ignition off, should be 12.8V.
If itís the latter, thatís normal.
Ozsyd600 is online now
post #3 of 4 (permalink) Old 04-23-2019, 10:58 AM Thread Starter
Ok cool. After i already started my bike it does that.
post #4 of 4 (permalink) Old 04-23-2019, 01:00 PM
Does the headlight change in brightness as you increase the revs?
Iíd be checking the battery voltage as I mentioned before.
Can someone tell me if this is normal? (Pic) Louisville88 Oil and Lubrication 33 09-03-2013 07:54 PM
Can someone tell me if i have K6/7 rims on my K8?? Bugeyes Suspension and Tire Tech 5 08-13-2013 07:43 PM
Fairing Fix?? Someone tell me how I can fix this.. M_Easy Tech and performance chat. 4 06-23-2007 06:11 PM
