Case Cracked - GSXR.com
  • 1 Post By hyaline
post #1 of 8 (permalink) Old 05-03-2019, 03:18 PM Thread Starter
Case Cracked
Hey all,
Been gone for awhile. Got my hands on a new engine approx 7k miles on it. The only gripe I have is this hole in the case near the stator. Not sure oil flows to that area but I'd rather ask y'all before I coat my garage in oil and upset the wife. What do you all think?
IMG_20190503_181057.jpg   IMG_20190503_181128.jpg   IMG_20190503_181119.jpg   IMG_20190503_181052.jpg
hyaline is offline
post #2 of 8 (permalink) Old 05-03-2019, 03:23 PM
Iím sorry to be the bearer of bad news but I believe oil will pour out of there with abundance, and upset the wife no end.
post #3 of 8 (permalink) Old 05-03-2019, 03:30 PM
^What he said.
It will pour out as soon as you put oil in it. There is not oil pressure on it, but the oil level is just about at the damage plus you have crankcase pressure.
The worse news is that is a chunk out of the lower part of the crankcase.
Anything is repairable, but that will be difficult. About the only method that would be anyway reasonable would be to build that area up with JB Weld and then file down the cover mating service.
It is a major rig, but doable.
Can you bring this prize back?
post #4 of 8 (permalink) Old 05-03-2019, 03:40 PM Thread Starter
I went back to the guy to show him this today. Unfortunately he stated that since it was a used engine its sold as is. And he "couldn't" remember seeing that before. He wanted to do the same thing that you suggested john. I may let him. Issue is that he takes long months to do any type of project and I don't want to wait that long. So I asked him to return it and he has to "ask" his boss. At this point im fully discouraged but the engine is only 7k miles! I'm hoping that he will take it back.
Thanks for your insight, I figured as much but wanted to be very sure before I did anything stupid.
hyaline is offline
post #5 of 8 (permalink) Old 05-04-2019, 04:29 AM
I'm not sure I'd trust JB Weld or silicone there. It's a pretty big hole. For that, I'd recommend splitting the cases and having a machine shop build it up with weld and then machine it to match the mating surfaces. Take a couple more pictures, but put a tape measure in there to give some scale. Take it around to some shops, tell them it's cast aluminum. Depending on cost, if you could get them to build it up with weld, you could file it down so that there's a 1/16" short of the mating surfaces. Then just fill it with silicone. That I would trust.
The good news is that it's not structural. A good welder could have that filled in under an hour. Drain the fluids, pull the rotor, and clean it really well. As long as they don't weld the cases together (which would be very easy to correct), it'd be good as new.
The bad news is that this is an indication that there could be more damage. Something like this could be from a crash or a really shitty mechanic. If it's a crash, I'd pull the spark plugs and have someone crank the engine while I watched the rotor. If that shaft is bent, you're f-ed.
post #6 of 8 (permalink) Old 05-04-2019, 05:31 AM
Good point. There was a real good chance the cover got destroyed in order to cause that case damage.
I had a friend with an F4I that laid it down pretty slow on an oil patch in the rain. Unfortunately, it slid into a curb. He found the crankshaft bent when he removed the cracked cover and then he found the crankcase bearings web cracked behind the rotor.
post #7 of 8 (permalink) Old 05-05-2019, 12:19 PM
I think you should pull the plugs and turn the motor over before even thinking of repairing the case. Assuming that the motor isn't in the bike, use jumper cables, positive to the lug on the starter, negative to anywhere on the motor for ground. Watch the rotor, if it isn't true, i.e., it wobbles, then the next step would be to remove the rotor and check the end of the crankshaft the same way. If the rotor runs true, then repair the case. I would take it to someone that does heli-arc welding, fill it in and file down flush. If the crank is bent, bad news.
bobl is offline
post #8 of 8 (permalink) Old 05-15-2019, 07:28 AM Thread Starter
So I was able to turn the crankshaft by hand. (wrench on stator rotor bolt.) All the pistons move without much effort. Will take the case for repair and inspect the shaft while thats happening. Thanks for all your input. i'll keep this thread update once its resolved or I just give up.
hyaline is offline
cracked the case. alex2008gsxr Tech and performance chat. 2 06-06-2016 03:55 PM
left crank case cover (left stator) cracked.... R750Rider Tech and performance chat. 6 01-03-2008 07:39 PM
cracked frame need advice Grip&Twist187 General GSXR Chat 27 05-29-2007 09:50 PM
Cracked oil pan gsxr_dude Tech and performance chat. 17 02-18-2007 05:57 PM
Can you fix a cracked fairing? TelefonicaGSXR Tech and performance chat. 11 05-24-2006 05:57 PM
