TPS/STVA no clue at this point - GSXR.com
post #1 of 11 (permalink) Old 05-21-2019, 09:51 PM Thread Starter
Rain77's Avatar
When I am accelerating hard like entering the freeway or passing or racing when I get to around 10k rpm my bike blips or sputters causing a quick jerking during hard acceleration with higher rpm. Once I let off the throttle or level out my acceleration it stops. My tps is adjusted in the correct spot the only F1 code is for my exhaust actuator cuz I have aftermarket on there. Any ideas thoughts brainstorming would help!!
Rain77 is offline
post #2 of 11 (permalink) Old 05-22-2019, 12:56 AM
I’d start with a bench test on the tps with a multi meter for dead spots. Next I’d clean my gas tank fuel pump/filter.
post #3 of 11 (permalink) Old 05-22-2019, 05:19 AM
Sounds more like fuel starvation. The most common cause are dirty fuel filters.
The pumps are pretty robust, but if the filter/s are clean there is a pressure and flow test in the service manual that should be done.
rv6john is online now
post #4 of 11 (permalink) Old 05-22-2019, 07:05 AM
If there's no code, the STVA and STPS are fine. You need to do a fuel delivery test:
post #5 of 11 (permalink) Old 05-22-2019, 06:22 PM Thread Starter
Rain77's Avatar
thank you chuckster for your feedback
The fuel pump and filter are brand new but will definitely do a delivery test and keep you posted
Rain77 is offline
post #6 of 11 (permalink) Old 05-22-2019, 06:25 PM Thread Starter
Rain77's Avatar
fuel pump and filter are new gas tank clean, I will look up how to do a bench test on the tps thank you.
Rain77 is offline
post #7 of 11 (permalink) Old 05-22-2019, 06:54 PM
I would do the fuel pump pressure and flow check. If you nicked the fuel pump 0-rings when you replaced the pump, it will cause the same issue.
You did use new O-rings?
post #8 of 11 (permalink) Old 05-22-2019, 07:22 PM
I have nicked the 0 ring before where the pump connects to the housing, I could not beleive I did it when I took it apart the 2nd time! Turns out the nicked 0 ring or the pump was not my issue in the first place but it’s not hard to nick a 0 ring .
post #9 of 11 (permalink) Old 05-22-2019, 07:26 PM
Just curious when u first turn your key on and ur pump and stva turns on do u here any strange clicking at all?
There are some great vids on you tube to bench a test a tps with a multi meter it’s not hard, it does not have to be on a gsxr I think the vid I learned how to do it from was a ford van they all pretty much work the same.
post #10 of 11 (permalink) Old 05-24-2019, 10:55 PM Thread Starter
Rain77's Avatar
I used new o ring but this issue was happening last season before the new motor but still here after new motor
Rain77 is offline
post #11 of 11 (permalink) Old 05-24-2019, 10:56 PM Thread Starter
Rain77's Avatar
Sometimes it does make a strange clicking sound but usually after a longer ride when it's still hot
Rain77 is offline
Tried to adjust TPS and destroyed STVA..... bsvaton Tech and performance chat. 5 07-18-2015 06:20 AM
I have no clue. Please Help dann0 Tech and performance chat. 23 05-23-2011 09:11 AM
Roaring Toys chrome billet arrow point bar ends and winshield chrome point bolts greensbusa For Sale 0 02-04-2010 10:10 PM
High Point....near point jervis casey749 New York/ New Jersey/ Connecticut 6 10-23-2007 05:06 AM
I Have No Clue What's Happened XxGSXR600xX Tech and performance chat. 5 06-28-2007 11:08 PM
