07 gsxr 600 c29 - GSXR.com
post #1 of 3 (permalink) Old 05-23-2019, 07:57 PM Thread Starter
07 gsxr 600 c29
Can i still ride my bike with this code? instead of spending money and more time, i was just thinking of putting a switch for the dealer code just so i can make sure there arent any other FI codes im not aware of. Will running a bike with the FI hurt the bike?
tea82 is offline
post #2 of 3 (permalink) Old 05-23-2019, 08:14 PM
Running the bike in dealer mode isnít going to hurt the bike in itself. You wonít have a temperature read out on the dash so as long as overheating isnít a problem then go for it.
Isnít the C29 the code for the secondary throttle position sensor? Not sure if running the bike with this code would cause any damage or not.
Have you checked the connectors going into the ECM for signs of corrosion? Might be worth a shot.
post #3 of 3 (permalink) Old 05-24-2019, 05:04 AM
Won't really cause damage. You'd have to unplug your STVA and turn the secondary throttle plates full open. You'll then have to back the fast idle off so it doesn't fast idle all the time. You'll have codes C28 and C29, but it will run fine. Just avoid quick throttle openings.
Help please- 05 600- c13,c14, c21, c29 codes gixxer996 Tech and performance chat. 39 07-02-2018 09:32 AM
07 gsxr600 fi code c29 KonviK Tech and performance chat. 0 04-04-2015 06:36 PM
01 gsxr 600 c29 badkawrma Tech and performance chat. 6 09-03-2014 07:18 PM
04 gsxr 600 FI codes c21 c29 and c41 ATL_gsxr Tech and performance chat. 5 08-01-2014 10:11 AM
HELP!! 07 Gsxr 600. Won't start c21 and c29 jessejames7575 Tech and performance chat. 8 02-28-2013 09:29 AM
