Please help, L1 600 performance issue - Page 2 - GSXR.com
post #41 of 50 (permalink) Old 09-04-2019, 04:21 PM
If you mean back-flushing, if it works at all, it will only be for a short time. The filter should be OK if it passes the flow test.
Other's here should know better about symptoms associated with out of spec valves on 600's. But I think they're hard starting, low compression, and poor idling.
post #42 of 50 (permalink) Old 09-04-2019, 06:21 PM
I've backflushed mines & Ive got 2000 km on it. I connected a rubber tubing to the nozzle of an air gun & let it rip. Pressure at 90 psi & run some throttle body cleaner & carb cleaner. Run until clear.
I can redline my bike now under load.
RockerGuy is offline
post #43 of 50 (permalink) Old 09-05-2019, 04:13 PM Thread Starter
New2Street's Avatar
Today I got exhaust pipe temps and CAT temps where the pipes enter and exit the CAT. A while ago rv6john hade do the spray test on the pipes, and I reported that the two middle pipes heated up quicker than the outer two. Dont take the temps to the exact degree, but here is a pic of the findings I got with my $20.00? Radio Shack IR thermometer. It worked great for my nitro RC truck.
I started taking exhaust pipe temps when my display hit 85 degrees. Cylinder 1 is left side of bike.
New2Street is offline
post #44 of 50 (permalink) Old 09-06-2019, 06:21 AM Thread Starter
New2Street's Avatar
I'm not an expert on how CAT's work, other than I know they create some back pressure. Would it be normal for the temp to be so high in the 2" between the SET valve and CAT, or would that be because there may be a restriction as the gasses enter the CAT? The temp as the gasses enter the slip-on seemed fine to me.
post #45 of 50 (permalink) Old 09-06-2019, 10:12 AM Thread Starter
New2Street's Avatar
UPDATE:. Anyone following my posts should know this bike has me sick to my stomach! I retired and bought a bike I thought would last for years, and lately feel like the engine was going bad. After even more searching the web I keep reading about people with similar power loss problems and the O2 sensor. Simply unscrewing the O2 sensor in an attempt to relieve back pressure did nothing. Today I took a chance and actually unplugged the O2 sensor and went for a ride (no codes for an unplugged O2 sensor??) Holy Crap!!!!!! I almost have my bike back! So much more acceleration off the line and up in the power band!
I'm not going to say everything is fixed, but it runs so much better.
Any input from all of you that know more than I? Thanks!
post #46 of 50 (permalink) Old 09-06-2019, 10:23 AM
Well, if it was reading wrong from the O2 it would cause the ecu to run it either too rich or too lean. If it runs good I'd just leave it unplugged as it should default to the standard fueling settings which should be good.
post #47 of 50 (permalink) Old 09-06-2019, 11:03 AM Thread Starter
New2Street's Avatar
Ok. Thanks. It did smell just a little rich to me, especially while warming up. Never enough for smoke or anything. I'll ride it for a day or two and report back on how it's running.
post #48 of 50 (permalink) Old 09-06-2019, 12:44 PM
Nice find if it turns out that it was the problem.
My bike doesn't have one of those newfangled sensors so I don't know much about them. The service manual seems to focus on the integral heater, which will produce a C44 error if it fails. You don't have that but I don't see why the rest of the sensor couldn't fail. You might look into a new sensor, but I see that they aren't cheap.
P.S. There's a good explanation of the interaction between the sensor and the ECM in post #3 here. That's from one of the very few people who actually spent time disassembling and inspecting the ECM's binary code. I generally hold his opinions in high regard.
post #49 of 50 (permalink) Old 10-09-2019, 02:20 PM Thread Starter
New2Street's Avatar
Engine still runs sluggish most of the time. Extra sluggish if I put it in "B" mode. The bike ran better for a little while after I disconnected the oxygen sensor. Once I thought that was the issue I tried cleaning the sensor and plugging it back in. That didn't help so I unplugged it again. Bike has been running rough/ as in not as peppy as it should most of the time since. Right now oxygen sensor is unplugged and the motor for the set valve in the exhaust is unplugged and the wire pulled from ECU so no code. Valve is wired open.
How the heck could the bike run so well and then be sluggish? Seems like it has to be either a fuel or air issue and not something like a bad ground.
post #50 of 50 (permalink) Old 10-12-2019, 02:00 PM Thread Starter
New2Street's Avatar
Still hoping someone can help me out with this because I'm not getting top performance out of the bike. I went back to plugging the oxygen sensor back in because it seemed like it was running a little bit rich with it unplugged. Not sure if this helps or not, but when I just refilled the bike I only got 30 miles to the gallon.
Normally my worst mileage has been around 38 miles to the gallon and best around 48 miles to the gallon if I've done a bunch of highway riding. Something's going on but no codes and I'm really banging my head against the wall trying to figure this out.
For a little while I was getting a pop when I shifted above 10k or so. (I was told it was because of the slip-on and less back pressure) (BUT, I didn't notice it when I first got the bike, and the slip on was on it then). Right now I am not.
