07 gsxr 600 slow to start - GSXR.com
  • 1 Post By jorion
  • 1 Post By jorion
post #1 of 9 (permalink) Old 08-20-2019, 03:55 AM Thread Starter
jorion's Avatar
I just bought a 07 600. Once it sits and get cold it takes a while to start up. It just spins and spins then fires up. Battery is full charge. I did a search. Couldn’t really find my problems.
jorion is offline
post #2 of 9 (permalink) Old 08-20-2019, 05:03 AM
Do you hear the fuel pump "prime" for about 3 seconds when you first turn the ignition key on with the kill switch in the "run" position?
Are the secondaries throttle plates still installed and working?
post #3 of 9 (permalink) Old 08-20-2019, 06:05 AM Thread Starter
jorion's Avatar
Yes fuel pump sounds normal. Plates opening. When key is turned on. After about 10-15 seconds of motor spinning. It will fire up and run.
jorion is offline
post #4 of 9 (permalink) Old 08-20-2019, 06:40 AM
How does the inside of the gas tank look and how does the fuel smell? Do you know was the bike sitting around a while not driven before you bought it ? I would pull the spark plugs and see how they look. Your bike also has a crank sensor I’d look up if you can clean it or how to test it.
post #5 of 9 (permalink) Old 08-20-2019, 07:42 AM
^ Good thought.
Try fresh fuel and some fuel injector cleaner first.
post #6 of 9 (permalink) Old 08-20-2019, 07:52 AM
Lucas fi cleaner has a good reputation I personally like sea foam, I’ve seen it work miracles.
post #7 of 9 (permalink) Old 08-20-2019, 07:57 AM Thread Starter
jorion's Avatar
Thanks guys. Was thinking of trying fresh fuel and cleaner tonight.
Spyder13 likes this.
jorion is offline
post #8 of 9 (permalink) Old 09-02-2019, 06:41 AM Thread Starter
jorion's Avatar
Update. Drained tank put fresh fuel and injector cleaner. Seemed to work so far. Thanks for the help
jorion is offline
post #9 of 9 (permalink) Old 09-02-2019, 06:06 PM
Awsome I’m happy it worked . That was a easy fix!
