Material of con and crank shells - GSXR.com
post #1 of 9 (permalink) Old 09-16-2019, 06:32 AM Thread Starter
dany1000's Avatar
Hi guys
What material are shells? Normally steel I suppose, I have seen replacement In aluminum...what do you think of these?
Cheers
Sent from my Mi A1 using Tapatalk
dany1000 is offline
post #2 of 9 (permalink) Old 09-16-2019, 07:29 AM
Are you talking about the big end bearings?
post #3 of 9 (permalink) Old 09-16-2019, 07:33 AM Thread Starter
dany1000's Avatar
Yes, main crank and cons
dany1000 is offline
post #4 of 9 (permalink) Old 09-16-2019, 11:38 AM
I'm pretty sure the factory bearings are aluminum. Are you looking for something specific? If you want something obscure, you might give APE a call and ask what they use in their race engines.
post #5 of 9 (permalink) Old 09-16-2019, 11:44 AM Thread Starter
dany1000's Avatar
Thanks for reply Chuckster
I am looking for a total rebuild, and starting to source parts but I have read some shops and one say they are steel and other alu... confusing.
I will to the replate job as the nikasil is coming of one of.the cylinders,
Pistons I will have to measure tolerance and might go for wiseco or wosner with STD rings, have also thought of rods...have seen a uk shop called maxspeeding and they sell them too cheap to be true.
Once fitted even checked with micrometer, plastigauge will be my tool of choice...
dany1000 is offline
post #6 of 9 (permalink) Old 09-16-2019, 12:08 PM
Are you going to have the journals polished?
post #7 of 9 (permalink) Old 09-16-2019, 12:21 PM Thread Starter
dany1000's Avatar
What would you suggest and proceed?
dany1000 is offline
post #8 of 9 (permalink) Old 09-16-2019, 01:19 PM Thread Starter
dany1000's Avatar
Kinda missed there....most probably, depending on how they are I do it myself or will send it to be done....
Will be quite some work....
dany1000 is offline
post #9 of 9 (permalink) Old 09-18-2019, 02:39 AM Thread Starter
dany1000's Avatar
What grit would be good to clean them ?
Crank on lathe and 400 grit?
dany1000 is offline
