K&N Oil filter leaking.. - GSXR.com
  • 1 Post By Last Week
post #1 of 20 (permalink) Old 10-26-2019, 02:10 PM Thread Starter
So I was pretty annoyed to stop by the garage today to work on my car, only to see a small amount of oil underneath my beautiful k9 1000. Reached up under there and there isn't any oil anywhere except for on the actual filter where the nut is. Isn't dripping really but after about 5 days since my last ride there is about a 5 by 7 inch mark on the floor.
Just put the filter on 1200 miles ago. I change the oil every 1500 and filter every 4500. This is my 3rd filter of theirs I've used and was very satisfied. Now after reading this seens to be a fairly common issue other people have had. Should note I only hand tightened it. I just like the nut on the end for ease of removing it since that year is such a pain in the ass to reach in there.
Jon Willette is offline
post #2 of 20 (permalink) Old 10-26-2019, 03:36 PM Thread Starter
Here's a couple of the reviews. Same issue.
post #3 of 20 (permalink) Old 10-26-2019, 04:57 PM
They're expensive & they leak. Time to look for a new filter.
RockerGuy is offline
post #4 of 20 (permalink) Old 10-26-2019, 05:13 PM
+1
Celinedeso is offline
post #5 of 20 (permalink) Old 10-26-2019, 07:00 PM
coreyyok's Avatar
No way I would run a K&N oil filter on a motorcycle.
Work Hard, Play Harder
coreyyok is offline
post #6 of 20 (permalink) Old 10-26-2019, 07:13 PM
I never had an issue with the k&n oil filter on my k7 600. I did tighten it beyond hand tight though as per the instructions. It has been a long time since I sold the bike so canít remember the exact details.
Yes, the nut makes it easy to remove. Thatís why I used that particular filter.
post #7 of 20 (permalink) Old 10-26-2019, 08:40 PM
I'm currently using the Hi-Flo filters. Made by, or for K&N. Not sure which.
However, I'm pretty sure the OEM manual states that when the filter seats-
Turn it Two complete turns.
I use the wrench to tighten mine. YMMV.
Sounds like you just need to snug it up a bit.
I've had one drip once too, snugged it some more- no problem.
post #8 of 20 (permalink) Old 10-26-2019, 09:06 PM
A strap wrench like this or this might work on your K9.
AFAIK the K&N KN-138 is made in Thailand by HiFLoFiltro. A bit iffy IMO.
post #9 of 20 (permalink) Old 10-28-2019, 09:28 AM Thread Starter
Oil filter isnt leaking from the seal, but from the actual filter itself. The base of it is bone dry. And if you looked at the reviews or goodle search you will see this has been a problem recently them leaking from the nut. I was taught to tighten an oil filter to the base and then turn it 3/4 inchs further by hand. Never had one leak before.
post #10 of 20 (permalink) Old 10-28-2019, 09:31 AM Thread Starter
I actuallt
I have a similar one. Likely going back to OEM. And ya I was unaware they stopped making then in america.
post #11 of 20 (permalink) Old 10-28-2019, 09:33 AM Thread Starter
Because of this reason?
What filter do you run? Ive had luck with fram on my other bike.
post #12 of 20 (permalink) Old 10-28-2019, 10:53 AM
I have never had any issues from Suzuki or K&N filters on my bike or any of my other ones. My 02 GSXR has 80K miles on it and I change the oil every 6k miles and filter every 2nd oil change, same for all the other bikes I have had. Just go back to the OEM filter.
EVL 750 is offline
post #13 of 20 (permalink) Old 10-28-2019, 11:14 AM
coreyyok's Avatar
I use an OEM honda filter on my CBR and a reusable FLO oil filter on my GSXR track bike that gets more frequent oil changes.
OEM is generally fine. Alot of the Taiwan filters with the nut could potentially leak at the spot welds on the nuts. This can be catastrophically bad in use with pressured oil running through the filter. Chances are low that the filter could leak or rupture but it's not a chance I want to take. If I was using a Hi-flo or K&N oil filter I would tighten it with a strap wrench only and use the nut to loosen and remove the filter.
coreyyok is offline
post #14 of 20 (permalink) Old 10-28-2019, 02:57 PM
There's a reason they're banned from several race and trackday organizations. I've used a couple before with no problems but now it's OEM only for me.
post #15 of 20 (permalink) Old 10-28-2019, 03:34 PM
I used to use Fram filters on all of my cars and truck, until they started making them REALLY cheap. China? Don't really care where they are made. Used to be a good filter. Now I have to stop using K&N as well? That sucks. Been using them on my bikes for decades.
post #16 of 20 (permalink) Old 10-28-2019, 07:38 PM
Fram tends to have a worse reputation than K&N nowadays. For me it's the OEM or Mobil-1.
post #17 of 20 (permalink) Old 10-28-2019, 08:25 PM
CCS/ASRA Expert #77
Last Week's Avatar
Dont use the nut to tighten it, this breaks the weld on the cheap piece of crap. Like said above it's been banned from most race and track orgs, and even the track itself.
Sent from my SM-N950U using Tapatalk
K7GsxR600 Race 2012 BOTY https://www.gsxr.com/42-gsxr-news/981...last-week.htmlSold
K6GsxR750 Track 2015 BOTY https://www.gsxr.com/44-gsxr-ride-mon...bike-year.html
2012 Ducati Panigale S Race
Last Week is offline
post #18 of 20 (permalink) Old 10-29-2019, 12:17 AM
Sounds like the quality has dropped off since I last used a k&n oil filter. Good to know of the issues folks are having.
post #19 of 20 (permalink) Old 11-06-2019, 10:05 PM
CCS/ASRA Expert #77
Last Week's Avatar
Its mostly from people using the nut to tighten it which leads to it being overtighten. If they would tighten it like normal it would eliminate 90% of the issue. The version for the R6 is actually faulty, blows out right at the seal ring.
JCW likes this.
post #20 of 20 (permalink) Old 11-07-2019, 07:08 AM
+1
I'll use HiFlo without hesitation, too. German TUV tested for what that's worth.
The racing version has the crossdrilled nut on it, too. Advised to be used only for removal just like K&N.
