GSXR 600 Dies at Idle @ stops - GSXR.com
post #1 of 15 (permalink) Old 05-23-2008, 09:23 PM Thread Starter
Hey guys, I just picked up a 2005 GSXR 600 with 700 miles on it. When I start up the bike in the morning it runs fine until the bike warms up to around 130 degrees. Once the bike is warmed up, it seems to idle really rough until it dies. Also, when I take it out and go to push the clutch in, or stop, the bike dies.
This bike had been sitting around for a year or so before I bought it. I replaced the old gas with 91 octane, and I drained some of the oil out of the engine since it was around half a quart over. Keep in mind this bike only has 700 miles on it. Still barely broke in. Any help would be great! Thanks
gsxrguy1 is offline
post #2 of 15 (permalink) Old 05-23-2008, 09:29 PM
gon2fast's Avatar
Sounds like a sticking Idle Air Control to me.
07' GSX-R750 , Shortened Scorpion Flame Titanium Exhaust, PCIII USB, Ignition Module, Dynotech Wide-Band kit, Vortex Frame Sliders and Swingarm Spools, Sportech windscreen, Pazzo Levers, Pilot Power 2CT's, -1 Front sprocket, Speedo-healer, R1 Throttle Mod, GPR stabilizer, Sato rearsets, Galfer stainless brake lines, Ohlins front and rear suspension
gon2fast is offline
post #3 of 15 (permalink) Old 05-23-2008, 09:43 PM Thread Starter
Where would I find this idle air control unit? I have been told it might be a throttle position sensor, coil, or IAP sensor. This bike barely has any miles on it. It just baffles me that something could go wrong already.
2005 GSXR 600
gsxrguy1 is offline
post #4 of 15 (permalink) Old 05-23-2008, 09:58 PM
Shot Caller
Or it could be the warm idle adjustment - should be 1,300 rpm +/- 100. Adjustment procedures are in the manual.
also,
1. A three year old bike with only 700 miles has been sitting around for probably about three years. You should drain the oil completely and change it.
2. You don't need (or want) 91 octane. Your 600 is designed to run on 87.
Mister Tee is offline
post #5 of 15 (permalink) Old 05-24-2008, 08:39 AM Thread Starter
The idle has been adjusted, but trust me it is not that. I can drain the oil out and see if that works. I hate to take it to the stealership to have them look at it. They charge 89.95 an hour.
2005 GSXR 600
gsxrguy1 is offline
post #6 of 15 (permalink) Old 06-01-2008, 06:26 PM
gsxrguy1,go get a can of Seafoam from your local Napa store. Then add a small splash to the fuel tank and run the bike out on a smooth long road.Give the bike roll ons with throttle. Let it pull hard.This stuff should help clear gumed up jets and improove idle quality for you.It only cost about $9.00 a can.
corvettesR1 is offline
post #7 of 15 (permalink) Old 06-01-2008, 06:37 PM Thread Starter
Thanks, I found the problem out yesterday. It turns out the previous owner had attempted a wheelie and dumped the bike. He did not pick it back up for a few minutes cause oil to run into the spark plugs. It had fouled out a plug. I changed the plugs and all is good. Thanks again.
2005 GSXR 600
gsxrguy1 is offline
post #8 of 15 (permalink) Old 06-01-2008, 07:20 PM
Im glad that you have found the trouble and were able to get it fixed.I wonder if seafoam would have cleared your plugs?
post #9 of 15 (permalink) Old 06-01-2008, 09:50 PM Thread Starter
Yes, the problem has been fixed. Thank goodness it was an easy one. Went on a nice ride today. Thanks again
2005 GSXR 600
gsxrguy1 is offline
post #10 of 15 (permalink) Old 07-02-2009, 12:33 AM
sparkplugs
Hey gsxrguy1,
How did you figure out that the sparkplugs weren't working? I'm assuming mine is having the same problem. Is it pretty easy to replace the sparkplugs?
Calvin
ctkf9884 is offline
post #11 of 15 (permalink) Old 07-02-2009, 12:38 AM
pinkfloydscorpio's Avatar
Is the bike in good shape?
This might be typed from my iPhone!
K6 GSXR1000 Red and Black
https://www.gsxr.com/showthread.php?t=70615
pinkfloydscorpio is offline
post #12 of 15 (permalink) Old 07-02-2009, 12:53 AM
nickw's Avatar
pretty much everything everyone above me said could be the problem. i would first suggest changing the spark plugs and changing the oil. Even if this doesn't fix it, it probably needs to be done anyways.
If that doesn't work, try to adjust the idle at which the throttle is set... even if it's not the true cause of the problem, it will hopefully fix it anyways
'01 gsx600f
'02 cbr600rr Custom Repsol Replica
'07 gsx-r600 Current *Project*
nickw is offline
post #13 of 15 (permalink) Old 07-02-2009, 08:46 AM
It's a '04 with 10,800 miles on it. It was just serviced not long ago. And I rode it with no problems when I first got it.
Is it hard to switch out the spark plugs? Is it just taking engine cover out? I don't wanna go to any shop if it's easy to do. Man, I'm such a noob.
ctkf9884 is offline
post #14 of 15 (permalink) Old 06-15-2011, 09:58 AM
this thread was alot of help. was having the same probelms. previus owner had dumped it hard. tip over sensor is fine, gonna pull plugs and switch them out now and see how that works hoping thats the only issue.
semipro06 is offline
post #15 of 15 (permalink) Old 09-26-2012, 08:10 PM
Hmm, Im hunting down the same problem Guess I wiil try new plugs
ripsweetness is offline
what stops my 07 gsxr 750 from wheelies mikeytas Stunts 48 11-02-2017 12:00 PM
2006 600 dies at idle only when engine is cold. edgar_rx Tech and performance chat. 7 11-11-2015 10:45 PM
k7 600 stops revving at 11k rpms climber90 Tech and performance chat. 2 05-09-2013 06:48 PM
GSXR 400 stops after .5 hr desm0 Tech and performance chat. 0 03-08-2012 08:33 PM
Bike Dies On Hard Stops SILVERK5 Tech and performance chat. 12 08-11-2007 08:34 AM
