F1 Light On Gsxr 750k7 - GSXR.com
post #1 of 22 (permalink) Old 06-07-2008, 04:00 PM Thread Starter
Light Comes On, So I Shut It Off And It Goes Away. Weeks Later The Same Thing. And Now Twice Today
JD750 is offline
post #2 of 22 (permalink) Old 06-07-2008, 04:04 PM
ur exhaust axuator mite need ajusting
hunter is offline
post #3 of 22 (permalink) Old 06-07-2008, 10:34 PM
gsxr600ls1's Avatar
its not f1 its FI (fuel injection) light check the code use a paper clip
2004 2010 YZF-R1
LS1 camaro
UsDA i dRink GasoliNe Szwagier
gsxr600ls1 is offline
post #4 of 22 (permalink) Old 06-08-2008, 08:27 AM
Pyro's Avatar
I have the same exact bike, and just started having the exact same problem. It came on one morning last week when I started it, so I shut the bike down. Started it again, and it was gone. Rode it several times with no problems. Yesterday, I started it up, no FI. Then I stalled it(yeah, duh), and when I started it again, the FI was back, along with the red light. I shut it down, waited a minute, started it back up. FI was still there with the red light. An hour later I started it, everything was fine.
My owners manual(pg 3-16) says this is a fuel injection failure, and that the bike should be taken to an authorized repair shop. It also indicates that it's alright to let it run. What is the problem with my fuel injection, and why doesn't performance seem affected?
[/SIGPIC]
Pyro, AKA Dave
Pyro is offline
post #5 of 22 (permalink) Old 06-08-2008, 08:39 AM
Remove the set valve and cut the #5 wire and it will never come on again. If thats a bit to radical, when it acts up turn the bike fully off and reach down and fully open and close the valve a couple of times. Then restart as normal.
k6 blk/gry 750 is offline
post #6 of 22 (permalink) Old 06-08-2008, 08:43 AM
The Bestest Racer
UltimatE's Avatar
Its not fuel injection, its Fault Indicator.
OP: pull the code
2011 GSX-R 750
2001 GSX-R 750 - Sold :(
UltimatE is offline
post #7 of 22 (permalink) Old 06-08-2008, 09:03 AM
Pyro's Avatar
After doing some research on this site, I'm a little less worried. Seems like the set valve is a constant source of trouble on these bikes. I'll see how often this happens, maybe I'll remove the set vavle, and that wire.
[/SIGPIC]
Pyro, AKA Dave
Pyro is offline
post #8 of 22 (permalink) Old 06-08-2008, 09:06 AM
Pyro's Avatar
OP: pull the code
According to my manual, FI refers specifically to a fuel injection problem. That being said, wouldn't the red light be the Fault Indicator, and the FI stand for Fuel Injection since it's the only thing that causes that code?
Then again, does it really matter?
[/SIGPIC]
Pyro, AKA Dave
Pyro is offline
post #9 of 22 (permalink) Old 06-16-2008, 11:33 AM
Fault Indicator is more geared towards it as it can be something other than fuel injection problem.
sig pics can not be larget than 200 pixels tall and 500 pixels wide.
onedownfiveup is offline
post #10 of 22 (permalink) Old 06-16-2008, 12:33 PM
KBorne's Avatar
coincidently i had the same error code come up on my 600 today. shut it off and came back and it was gone. Im going to grab some fuel injector cleaner and put it in the tank, but beyond that i'll just leave it alone. my bike only has 1200 miles on it...if the fuel injectors are bad with only that many miles...im concerned.
Guns, Bikes, Guitars....I love America!
KBorne is offline
post #11 of 22 (permalink) Old 06-16-2008, 04:45 PM
illest's Avatar
Just something that i've noticed with my FI problem. When starting the bike up, keep it in neutral, put the stand up, twist key, then switch engine to start position. Allow that fuel pump to prime, and wait till all the noises are gone, THEN hit the start switch.
Seems that every time i've waited for all the values, pumps etc to prime in the beginning before starting i haven't got a FI error. Give it a shot, maybe it will work for you too.
06 GSXR600 Black and Grey
illest is offline
post #12 of 22 (permalink) Old 06-17-2008, 02:22 PM
had the same thing happen to me, i took my bike to the dealer and the tech told me when it happens turn off the bike, twist the throttle completely and let it go. then start the bike again and it will reset it, i havent had a problem since.
newhvn750 is offline
post #13 of 22 (permalink) Old 06-17-2008, 02:32 PM
same exact bike same FI LIGHT... Nothing to worrie about like previously stated just turn it off and turn it back on THAT should correct the problem...
909GSX-R is offline
post #14 of 22 (permalink) Old 06-17-2008, 02:43 PM
qUICK Q:... this only happens to my bike when its really hot out or i hit a bunch of lights is this about the same for everybody else???
909GSX-R is offline
post #15 of 22 (permalink) Old 06-17-2008, 09:01 PM
strictlye's Avatar
Ok people, I've gotten my set valve replaced under warranty once before and the problem still happened on occassion. I brought it back a few weeks ago and I believe Suzuki is now aware of this problem because the service guy told me that they had some problems with the cables for the set valve. It was either too long or too short, I can't remember. Either way they replaced the cable and everything is working fine free of charge of course.
strictlye is offline
post #16 of 22 (permalink) Old 06-20-2008, 10:48 AM
Possible FI Indicator FIX
Found this on another board after months of searching and trying different things this one worked check out the link
It has detailed instructions with pictures so if you mess this up I am not responsible for anything that happens
DO NOT CUT OR PULL THE WRONG WIRE AS IT WILL CAUSE SERIOUS DAMAGE
Copy and paste this link in your browser and print out the details
http://jsdproducts.com/docs/2005-set.pdf
GOOD LUCK
daMarine is offline
post #17 of 22 (permalink) Old 06-20-2008, 10:52 AM
If you don't let the fuel pump completely prime before you hit the start button it can cause the light to come on.
That would explain why when you shut it off and restarted the light went away.
mitch is offline
post #18 of 22 (permalink) Old 06-22-2008, 05:38 PM
I just got this error today on my 750. It says "CHEC" then "F1" and alternates between the two. The red light stays lit.
I have tried shutting everything down, turning the throttle max, then letting it go to its normal position, then turning the key, letting it prime completely, after no more noise is heard, I start it. Light and error is still there.
What do you mean use a paperclip to check the error code? ANy idea what's the problem?
eristic is offline
post #19 of 22 (permalink) Old 06-23-2008, 04:44 AM
Fix Works
Late last week I posted a fix, I had a chance to test it out on my bike, worked like a charm, performace was back to original, the light did not come back on.
daMarine is offline
post #20 of 22 (permalink) Old 06-23-2008, 12:04 PM
dgrobe2112's Avatar
my bike did this same thing a few weeks back.. i turned it off.. and restarted the bike.. no problem since till yesterday.. i riding down the road, and the engine shuts off, then back on.. then off and on.. pretty bad.. same error code.. how is the paper clip thing work?
My bike is a 2004 GSXR1000
dgrobe2112 is offline
post #21 of 22 (permalink) Old 06-24-2008, 12:27 AM
Guys, search this sight and you can find out exactly how to do it. It seems all the K6 and K7 600's and 750's are getting this error including mine. Under your seat there is wire harness that goes no where. You can stick a paper clip into 2 hole to connect it. This is what the dealership would do if you took it in there but with real equipment. This allows an error code to show up on your dash where FI would usually be. The most common code is C46 which indicates somthing exhaust valve not opening all the way. My FI would come on only somtimes and restarting the bike would fix it but now it is on every time. You can still ride and it wont hurt your bike but your loosing some power. I have yet to fix mine and figure out exactly how to do it. But if you search the posts you will find everything on "dealer mode" and whats all the error codes are. check out these links. First has a dealer mode section and a lot of other nice info. The second is how to fix the exhaust (set) valve.
http://www.bugmanweb.com/gsxr/gsxrindex.html
http://www.tfriders.com/phpBB3/viewtopic.php?f=9&t=71
memphisb12 is offline
post #22 of 22 (permalink) Old 08-02-2011, 03:30 AM
This looks like exactly where I need to be. I have a 07 750 with slip on and a PC3. I am the second owner and it has about 8K on it. It seems as though, from reading several threads, this is notorious with the 06/07 600/750's. Does anyone have an educated response as which is better- having a fully functioning SET valve as opposed to removing it?? I do perceive a difference in power when the code is on. I do know that you can remove wire 30 from the main black harness and it will cut the light but does it fix the problem?? When the light is on, why is there less power?? What does the computer adjust to cause this?
AirborneMechanic is offline
750K7 RPM drop and Oil Pressure Light HELP! FireMedicK7750 Tech and performance chat. 11 10-09-2011 04:50 PM
rear tire 190 in 750K7 JavieR6 Tech and performance chat. 3 12-10-2007 07:54 AM
Remus megaphone exhaust 750k7 neil29 Bikes 5 09-16-2007 08:31 PM
My new 750k7 gixxer750k7 Bikes 16 09-09-2007 02:55 PM
