Red light and F1 flashing on cluster - GSXR.com
post #1 of 24 (permalink) Old 05-23-2010, 04:52 PM Thread Starter
I have a 06 gsxr 600 its got 4700 miles on it and the Light just started flashing after i started it up. When the F1 flashes is that a code or is that a signal that i need to check fluids or get the bike tested at a dealer for something wrong? Help me out please..
k6gsxr22 is offline
post #2 of 24 (permalink) Old 05-23-2010, 05:02 PM
Bry
The Honey Badger
Bry's Avatar
Do a search for dealer mode for your bike, follow the directions and report back after you get the error code
Edit: the f1 red light is actually FI
2011 ZX10R
07 750-Sold
Bry is offline
post #3 of 24 (permalink) Old 05-23-2010, 05:05 PM
SP GSX-R's Avatar
Post
you have any mods?
K7 600 Red/White
"If loud pipes save lives, imagine what riding that thing can do."
"I Ride in Leathers because I would rather sweat than Bleed..."
SP GSX-R is offline
post #4 of 24 (permalink) Old 05-23-2010, 05:12 PM Thread Starter
two brothers slipon
k6gsxr22 is offline
post #5 of 24 (permalink) Old 05-23-2010, 05:25 PM
SP GSX-R's Avatar
Post
Originally Posted by k6gsxr22 View Post
two brothers slipon
I have a Two Brothers slip on as well. There are some wires in the exhaust that get stretched out from the heat. Its something like that, my mechanic explains it much better. So shouldnt be anyuthing to worry about, they can correct that for you on your next stop in a shop or you can research the codes and DIY.
mine came on just a few weeks ago and thats what they told me. just hit about 7500 miles on the 07. Just some sensor for the exhaust. Get on the highway and bomb it to redline in 2nd to 3rd and it should go away probably not the best thing but it works. Its a gsx-r, itll live
K7 600 Red/White
SP GSX-R is offline
post #6 of 24 (permalink) Old 05-23-2010, 05:38 PM Thread Starter
i dont have the connector to plug in but if i cycle the kill switch it turns the f1 signal off And im not getting a code unless im not doing something right. all i get is f1 and temp flashing with running and with key turned on I dont understand the dealer mode and how to activate without the conector to plug in
k6gsxr22 is offline
post #7 of 24 (permalink) Old 05-23-2010, 05:41 PM Thread Starter
also another issue i dont know how reset clock or shift light fyi just got the bike a month ago
k6gsxr22 is offline
post #8 of 24 (permalink) Old 05-23-2010, 05:44 PM
SP GSX-R's Avatar
Post
You dont have a manual? theres a manual thread on here if you just search.
Mine comes on since the bike was downed about a month ago and some sensor is off in the exhaust. Get a manual is all i got for you
K7 600 Red/White
SP GSX-R is offline
post #9 of 24 (permalink) Old 05-23-2010, 05:47 PM
SP GSX-R's Avatar
Post
I dont have my shift light set up either, but the clock is pretty easy. Just hold down the button that toggles between the diffrent options, like clock, miles, trip miles... and then just click the other buttons on the other side of the cluster to edit the clock. This is so hard to explain, but shouldnt be hard to do. play around a little and youll get, its been years (since 2007) that ive touched my clock
K7 600 Red/White
SP GSX-R is offline
post #10 of 24 (permalink) Old 05-23-2010, 05:55 PM Thread Starter
thanks for the help
k6gsxr22 is offline
post #11 of 24 (permalink) Old 05-23-2010, 06:07 PM
pop-rivet's Avatar
https://www.gsxr.com/showthread.php?t=1234
Did you eat a bowl of STUPID for breakfast?
'01 GSXR 1000
pop-rivet is offline
post #12 of 24 (permalink) Old 05-23-2010, 06:22 PM
bradgsxr03's Avatar
I get the same thing but it happens randomly...
bradgsxr03 is offline
post #13 of 24 (permalink) Old 05-23-2010, 06:37 PM
01 K1 F1 light
i had the same thing happening but when i put in a new battery it went away
slickofski is offline
post #14 of 24 (permalink) Old 05-23-2010, 07:45 PM
SP GSX-R's Avatar
Post
yea my comes one and off sometimes
K7 600 Red/White
SP GSX-R is offline
post #15 of 24 (permalink) Old 05-24-2010, 10:13 AM
Lean With It's Avatar
Did you read the how-to on the dealer mode thread?
Can you read? We can already see writing and describing is not a strong point.
I HIGHLY doubt your bike doesn't have the dealer mode plug. If it didn't - how would the dealers find the codes?
Here:
start bike> bike won't start>bike does start
FI light comes on. Tachometer reads "FI"
If bike is running - take a paper clip or extra piece of wire and jump the connections in the dealer switch in the trunk of the bike. It may also be located along the side behind the tail fairing.
The light MUST BE ON and remain on before you connect those two spots.
As soon as you connect them - a code will pop up in the tach.
-C00 means you have no faults or you did the test wrong.
My Youtube Channel <---clicky
_______
Lean With It is offline
post #16 of 24 (permalink) Old 05-24-2010, 10:50 AM
Bry
The Honey Badger
Bry's Avatar
I mentioned the dealer mode earlier and figured the FI light was more important than setting the clock and shift light...stupid me.
2011 ZX10R
07 750-Sold
Bry is offline
post #17 of 24 (permalink) Old 05-24-2010, 12:49 PM
yea I saw that.
_______
post #18 of 24 (permalink) Old 05-25-2010, 04:41 AM
gsxR-madness's Avatar
Hi - I have K4 600 , ex-track bike , i bought the bike few months ago and had no issues or any problems with the bike , i actually think the bike is done up somehow, any ways i have the FI and Red light that flashes and read up on all the topics here but found a bummer , i have located the dealer swith next to the battery but i have 6 wires running into it and they are all black with green marks and white stripe through them , which 2 wires do i bridge to get the fault code...i've taking my bike to 170mp/h and had no problems then all of sudden this light appears and the bike does not wanna exceed 9000rpm what could be the cause and which wires do i use for the fault code ? anybody please help me !!!
gsxR-madness is offline
post #19 of 24 (permalink) Old 05-25-2010, 03:23 PM
you have found the wrong plug
the dealer plug only has 2 wires going into it and guess what - those are the 2 wires you jump.
pic credit to bugmanweb.com dealer mode section
if your FI light is only coming at 170 (on a k4 600 = LOL) you will need to hook up the "dealer mode switch" so you can hit the switch while riding when the red light comes on and get the code while riding. The hardest part about hoooking up the switch for use while riding is figuring out where you want to put the toggle switch for easy access. The wiring is very simple.
_______
post #20 of 24 (permalink) Old 05-27-2010, 04:17 AM
Talking
Thanks million dude......we've located the dealer switch and found _C28 fault which we will have to bypass till i can afford new one
post #21 of 24 (permalink) Old 05-27-2010, 08:19 AM
Bry
The Honey Badger
Bry's Avatar
Are you planning on removing the butterflies as your bypass? A lot of people that had the c28 problem recommended a PM to thegeek over at gixxer.com or buying throttle bodies or the actuator if you can find one.
If you do a search (top left corner of the screen) for c28, there are lots of threads on this..here are a couple
http://www.gixxer.com/forums/showthread.php?t=159818
https://www.gsxr.com/showthread.php?t=71779
2011 ZX10R
07 750-Sold
Bry is offline
post #22 of 24 (permalink) Old 06-01-2010, 01:24 AM
Wink
thanks again for all the assistance , we have removed the butterflies for now as the actuator apparently cannot be bought seperately, but now i have the bike dying out on me and the throttle response is very vast from before , i see from your text "pm" what does this stand for ?
post #23 of 24 (permalink) Old 06-01-2010, 03:41 AM
Bry
The Honey Badger
Bry's Avatar
PM=private message.
2011 ZX10R
07 750-Sold
Bry is offline
post #24 of 24 (permalink) Old 12-30-2014, 04:15 PM
I have the same problem:
red light on with Check on the screen..goes away when engine start. Local shop told me it's common for any aftermarket exhaust installed. Mine is 09 Gixxer 1000,,w/ Taylor made exhaust & cat.. Bike seem to run fine.. I do want a get rid of this light..& also read about Dealer mode way?
Any input will help
finest318 is offline
09 750 FI C33 and FI red light flashing B1GR1G Tech and performance chat. 6 10-13-2015 01:45 PM
2005 Gsx-r 1000 red light on my cluster gauges???( flashing F1 where temp. is) crazygerman1000 Tech and performance chat. 12 07-13-2012 07:50 PM
03 gsxr 600 wont start f1 light & flashing red light cbauer1987 Tech and performance chat. 0 05-29-2012 06:30 PM
Changed Muffler now getting f1 Flashing light Corza Tech and performance chat. 9 12-09-2009 09:26 PM
Red light flashing and FI is on! Gixx/2broscarb Tech and performance chat. 8 06-19-2009 01:55 PM
