STVA and -C28 error codes k4-k7 600/750 - Page 2 - GSXR.com
 8Likes
post #41 of 162 (permalink) Old 02-17-2014, 03:14 AM
very thankful for your knowledge brother!!
i have a k7 gsxr 750... I'm having the same c28 issue. i read in this forum that Chuckster aka TheGeek was working on putting this info for testing on a website. does anyone happen to have a link for that, or have a copy of the STVA k6 - k7 testing file that is able to open.. i have no luck unzipping the thing, and would appreciate the helping hand. my email is. [email protected]
I'm hoping this isn't a dead forum
Jesse661 is offline
post #42 of 162 (permalink) Old 02-19-2014, 04:00 AM
I bought my 750 K5 with the throttle plates already removed and it revs clean all the way to the redline. But yesterday the red light and F1 came on and when I turn the ignition on I can't hear the STVA working. Will this give me problems in the future? How can I clear the fault code?
HenningDB is offline
post #43 of 162 (permalink) Old 02-19-2014, 04:45 AM Thread Starter
First you verify the code is C28. Then you get the STVA repaired or replace it. Removing the throtttle plates does absolutely zero for you.
post #44 of 162 (permalink) Old 03-08-2014, 02:38 PM
HI everyone!
I ride GSxr 750 06. I have removed air box and found that secondary throttle valves are 100% open in both cases - when ignition is on or off. Is it normal? I tried this on cold engine if it matters...
Here is the video I took to clarify my case...
http://www.youtube.com/watch?v=7Kh7y...ature=youtu.be
thanks in advance for help...
levanso is offline
post #45 of 162 (permalink) Old 03-08-2014, 04:17 PM Thread Starter
No problems there. Push them closed by hand, then turn the ignition on. They'll go to full open. Then start it and let it run for a little bit and they'll close.
post #46 of 162 (permalink) Old 03-09-2014, 11:24 AM
Thanks.
I checked again and everything was as you said.
but I noticed that while I was pushing accelerator some gases leaked out from intake. Is that normal?
I have started those investigation due to engine vibration from 4000 to 8000 rmp.
levanso is offline
post #47 of 162 (permalink) Old 03-09-2014, 07:38 PM Thread Starter
Not sure what you mean by gasses.
post #48 of 162 (permalink) Old 03-09-2014, 08:24 PM
MPG mod
gixxerfool's Avatar
Do you mean steam?
Sent from Motorcycle.com App
MPG wins=6
gixxerfool is offline
post #49 of 162 (permalink) Old 03-10-2014, 04:16 AM
Yes like steam but smells as exhaust... same staff as out from exhaust....
levanso is offline
post #50 of 162 (permalink) Old 03-10-2014, 06:06 AM Thread Starter
You should see nothing coming out of the intake while it's running. It's a vacuum inside. If you're getting puffs out of it, my first concern would be cam timing.
post #51 of 162 (permalink) Old 03-10-2014, 07:13 AM
Maybe the gases came from underneath and I thought it was from throttle intake. I examine it again.
levanso is offline
post #52 of 162 (permalink) Old 04-11-2014, 08:40 AM
spinnnerrr's Avatar
The Geek
I just recently got my STVA fixed by the Geek. I highly recommend him for anyone who is experiencing the C28 code. I would of attempted to have fixed it myself, but I didn't have the proper tools and knowledge... and quite frankly, I probably would of messed things up more
He sends along some easy-to-follow instructions for re installation also.
Quick and easy! 5 Stars for the Geek
www.stva-repair.com/
spinnnerrr is offline
post #53 of 162 (permalink) Old 05-19-2014, 04:25 PM
Do i test the STP sensor on my 03 1k the same way as 04-05??
RenoRRprez is offline
post #54 of 162 (permalink) Old 05-19-2014, 05:10 PM Thread Starter
Yes and no. It's still just a resistance test, but the values and wiring pattern will be different. Get the values from a service manual.
Then do some tests to figure out the logic.
A-B
B-C
A-C
One pair will be a static value regardless of the position. One will read backwards of the values (ie, reads a high value when it's supposed to read low). And, one will read correctly. You have to do this because they tell you to use the "test harness", but they won't tell you what that wiring is.
post #55 of 162 (permalink) Old 06-04-2014, 02:39 PM
Hello ppl, maybe someone can shine some light here for me. My 2007 GSXR 750 gave me a C28 the other day. Now I followed shop manual and everything checks out to spec. STPA has 7.6 ohms when hooked up to harness, right at ECU connector. STPS is with in spec, and adjusted to spec. All gears inside the motor are good. At this point everything points at ECU, what I cant understand is how is this possible for voltage spikes to burn only that part of ECU and not effect any other systems? If I cant figure this out I'll pull the butterflies off since my bike has PCIII and its tuned.
rotary13b is offline
post #56 of 162 (permalink) Old 06-04-2014, 02:44 PM
BlueNwhiteGSXR's Avatar
Where are you located? I would swap for a know working ECU if you have one around. Also as you said try disconnecting the PCIII and see if that fixes it. The rest of the guys will be around soon, but it seems like you are on the right track
Street A - K7 750 Blue/White
Street B - K7 600 Blue/Black
Race - K6 600 Blue/Black
Project - 97 GSX600F Katana
2014 & 2015 MPG Champ
BlueNwhiteGSXR is offline
post #57 of 162 (permalink) Old 06-04-2014, 06:18 PM
Im in Stouffville Ontario, Canada. ( near Toronto). Im checking local spots for a used ECU as none of my boyz have gixxers anymore. The only friendwith a 750 gixxer is 2010 and I'm not sure if the ECU's are the same.
Btw my motor buffers instead of cycling the plates, and the bike never had charging system issues.
post #58 of 162 (permalink) Old 06-05-2014, 03:14 PM
Chuckster, any idea? Site will not allow me to P.M you.
post #59 of 162 (permalink) Old 06-05-2014, 05:12 PM
By "motor" to you mean the STVA? (actuator)
Does "buffers" mean flutters?
Any ECM from a K6 or K7 600 or 750 will plug in and run the bike. The maps are different between the 600 and 750 so it will not be tuned properly, but it will start and run fine.
post #60 of 162 (permalink) Old 06-05-2014, 06:44 PM
Yes, STVA/ stepping motor, and yes again I meant to say secondary throttle plates flutter back and forth. I saw a post by Chuckster saying that he saw hundreds of ECU's fail on 06/07 models, so even thou I never had charging issues I decided to check my voltage regulator. It passed the inspection as per Suzuki shop manual, however it has to small holes in the back of it. Possibly its on its way out and it damage my ECU
post #61 of 162 (permalink) Old 06-05-2014, 06:46 PM
I'm working on an ECU, hopefully I can get my hands on one soon.
post #62 of 162 (permalink) Old 06-05-2014, 07:46 PM
I know Chuckster has previously mentioned failures of these ECMs. Hopefully he will describe the failure mode. I have not read about a lot of failures in the last couple of years except for ignored over volt condition and one guy who's friend started disconnecting battery wires while the bike was running.
If you are getting 14.0-15.5 volts measured at the battery at 5k rpm then the charging system is good and not the cause.
It seems when the bikes overvolt they go to about 18 volts, blow headlight bulbs and boil the battery. When the battery boils out it really spikes, the ECM fails and the bike stops. This does not seem to be the scenario you describe.
post #63 of 162 (permalink) Old 06-05-2014, 08:56 PM
You are right, that is why I'm confused here. My bike still has original battery in it as I always plug my battery tender when not in use, just a habit. However after hours of testing and searching forums I decided to pull my regulator off and inspect it. Like I said it passed, all I found was two little marks at the back, size of a small screw/head. Just in case I ordered a new one from motorcycle superstore. ( Ricks)
The bike runs/starts fine, except for the C28 and secondary plates fluttering.
post #64 of 162 (permalink) Old 06-06-2014, 01:08 PM Thread Starter
Has to be a 2006 or 2007 ECU. There's really no way to diagnose it other than swapping it with a known good. It's more of a process of elimination to get to that point, which you've already done. It's just a hypothesis and I really don't know the pathology, how much of an over-volt it takes to cause the damager, or any other details. Only a lot of history and testing to show the STVA is good, and reports that the bike just suffered from other electrical issues. Just a lot of reasons to think the ECU is the issue.
The other issue I've seen is a STPS that has cross faulted. Usually that causes a different behavior that a fluttering. I would say your ECU is the faulty component.
post #65 of 162 (permalink) Old 06-06-2014, 10:36 PM
Thanks Chuckster, I tried a known STPS today and it made no difference. At this point I'm looking for a used ECU, however so far no luck. Will post as soon as I fix the problem.
post #66 of 162 (permalink) Old 06-15-2014, 08:01 AM
As promised here is an update. In my case the ECU was the problem. I installed a used one and the problem went away. I also got a Ricks R/R just to be sure cause I still can't understand what caused the ECU to fail. Here is a little fact:
Suzuki R/R output at idle 14.4V, 5K RPM 15.48V.
Rick's R/R output at idle 14.45V, 5K RPM still 14.45V. Those are the values I took from my bike and Rick's R/R works much better. It is very possible that O.E R/R when very hot at high RPM spikes the voltage past 15.5V. I'm thinking of adding a "volt gauge " to the bike in the near future.
Thanks for all your input and help.
post #67 of 162 (permalink) Old 06-15-2014, 03:59 PM
Glad you got it fixed and thanks for posting the resolution.
Are you sure it was an OEM R/R you had on it previously?
There was another guy that had an Ebay/Chinese R/R that also controlled well when cool but overvolted when it got hot.
I have not read about an OEM unit doing this is why I ask.
Do a search for voltage gauges, there are a couple of neat digital models and annunciator lights.
post #68 of 162 (permalink) Old 07-05-2014, 12:41 PM
Gixxerjake02's Avatar
Same problem as mentioned above. STVA checks out good abot 7.4ohms then checked the stps also good readings open and closed butterflies. What I'm wondering is if it's possible to use an ecu from an 09 an long as you get the wiring harness for that year also? Because the ecu for 06-07 gsxr 750 seems to be hard to come by.
Gixxerjake02 is offline
post #69 of 162 (permalink) Old 07-05-2014, 02:40 PM Thread Starter
There's a reason they're hard to come by.....
I don't know if the 09 would be compatible with the 06/07, but without some concrete confirmation, I wouldn't even try it. Just one pin different and you could risk bricking the thing.
post #70 of 162 (permalink) Old 09-21-2014, 12:21 PM
issue after c28
I need alot of help here guys. i had a c28 code pop up on my bike and i am mechanically inclined enough to do the repair myself which is did. 7.2 ohms on both of my connectors and the butterflies now when i turn on the bike go all the way open and rattle a bit but after all of that i get a c14 code which i know is the tps on the stva. i go to adjust it and the line will never go middle even with 1000ths of an inch difference its top line or bottom only. At one point of time when i was troubleshooting the stva i did get the line to go middle once. I tested the voltages coming out of the ecu and it reads 5.0 VDC on the red wire and 4.42 on the other wiring. When i turn on the bike the code pops up and it seems that when it is trying to regulate where it should be at it gets stuck in the middle of moving the secondary valves and the code wont clear. What am i doing wrong with adjusting it? I have bought a new tps thinking mine was bad and that failed.
GTOwnin is offline
post #71 of 162 (permalink) Old 09-21-2014, 07:42 PM
ive done some more troubleshooting. What i have found is i have 7.2 ohms all the way to the plug that goes to my ECM. Im assuming my only option is that my ECM is bad and i need to get a new one.
GTOwnin is offline
post #72 of 162 (permalink) Old 09-22-2014, 07:43 PM Thread Starter
C14 is the TPS UNDER the STVA. The one mounted to the STVA is the STPS. Most likely, you installed your STVA wrong, and unless you're lucky, you've damage the STPS. C14 is completely unrelated to the secondary system. Are you sure you're mechanically inclined???
The STPS can not be adjusted by the line. That's only for the TPS. The STPS has to be calibrated directly. Your ECU isn't faulty, you're just making mistakes.
post #73 of 162 (permalink) Old 09-25-2014, 08:23 PM
well, you are right what i was reading out of the manual was totally my fault. I did fix the STVA, and its giving me good multimeter readings, and it is working fine by opening up when i turn on the bike. But after it runs for about 15 secs the throttle vavles go closed and stay closed then a c28 pops up again. i tested the resistance to the wires and everything all the back to the ecu and its all 7.2 ohms. So you say it isnt an ECU at that issue? I am closing the vavles and installing the STVA and that is what is happening. Any advice to me to get this running?
GTOwnin is offline
post #74 of 162 (permalink) Old 09-26-2014, 08:10 AM Thread Starter
I'd be real surprised if it was the ECU. More common is a false positive test. I'd say send it to a pro.
post #75 of 162 (permalink) Old 09-28-2014, 03:51 PM
Continued Troubleshoot
To this point of it all ive got the motorcycle popping out a C28 code 15 secs or so after it is running. The butterflies open fully then close fully then a C28 pops up. Is this the STPS not set properly? or is this the STVA is still not working properly? Or a faulty STPS? It will run if i set the valves open a little bit and i cant get past 6k Rpm's if i dont open then a little it will die. Please help.
GTOwnin is offline
post #76 of 162 (permalink) Old 09-29-2014, 01:48 PM Thread Starter
If they move open, then back closed at powerup, the STVA is usually fine and it's a sensor issue. Pretty easy test. Connect a meter to the sensor in the positions of the black and red wires. Cycle the secondaries. Regardless of position, the reading shouldn't change. If it does, your sensor is faulty.
post #77 of 162 (permalink) Old 10-01-2014, 12:10 AM
Thanks for the help chuck, the reading i get is 4.8k ohms no matter the position. If i read correctly somewhere you said it needed to be at 1.6k ohms? if i put the sensor on in the closed position i get a c28 if i put them on with the valves open i get a c14. Definite bad sensor?
GTOwnin is offline
post #78 of 162 (permalink) Old 10-01-2014, 04:12 PM
Hey guys. Im new to this site and Im looking for a bit of information. Ive read a lot about the testing of the stva but I cant seem to come up with a fix for my issue. Im on an 08 600 and while racing the other weekend I noticed that an injector was hung open. I happened to have a spare throttle body assembly with me so I just swapped it out and put the original stva on the new assembly. I couldn't get the stva to sync correctly. I noticed with the original setup the butterflies were closed with ignition off. When I turned the ignition on they would fully open then close again. After the swap they open probably 1/16th of the way and close back and makes a humming/buzzing sound. I pulled it back off. Opened the stva(turned completely ccw) and opened the butterflies, reinstalled and cycled the key. It completely closed, opened the 1/16th then closed and more humming. Obviously, Im missing something somewhere. Help, please?
shon922 is offline
post #79 of 162 (permalink) Old 10-03-2014, 11:51 AM Thread Starter
Sounds like a sensor alignment issue. Was it a complete throttle body or did you swap over your working STVA?
post #80 of 162 (permalink) Old 10-04-2014, 12:48 PM
Afternoon, master in c28s of thine GSXRs. I'm also getting the C28 code on my 07 Gsxr 600 that I recently purchased with only 1000 miles. The previous owner did lay it down maybe going 5-10 MPH very low speed minimal damage. First i wasn't able to find the testing instructions for k7s on your website maybe i'm just blind since the zip just doesnt work for me. Just some background with the issue, I have disabled the exhaust Set Valve by pulling plug 34 from the pin while in the wide open position I did see some improvement as far as the issue of it not wanting to accelerate at a normal speed above about 6k RPM but now it's moved closer to 8k rpm only in gears 2-6 and will even lose acceleration momentarily and slow down but with no issues in first gear getting well over 10k rpm without issue. I recall you reading that it is most likely the ECU gone bad or could it still be the STVA? I'd like to test it but unfortunately can't open the damn zip folder.
gsxrsamz is offline
2007 600 stva c28 mystery rufiogsxrk7 Tech and performance chat. 2 12-02-2016 06:24 AM
Problem after STVA and -C28 error code k4gsxrlover Tech and performance chat. 0 12-04-2014 01:41 PM
k7 c28 code STVA -not your normal fix- jmcafee302 Tech and performance chat. 14 08-26-2013 01:05 PM
C22 and C28 Codes. STVA is bad. Question about AP sensor White22 Tech and performance chat. 4 09-02-2010 09:25 PM
HELP C28 Code STVA! k4600 Mylesf7 Tech and performance chat. 3 07-26-2008 10:08 AM
