07 600 brake lever - GSXR.com
post #1 of 15 (permalink) Old 05-06-2019, 08:23 AM Thread Starter
07 600 brake lever
So i decided to change out my lever but after i alligned the the hole on the lever and the pin, i still see the pin. My question is, am i suppose to see the pin? If not, then the new shorty levers are the the correct fit. If i remember correctky, on the oem, i only see the rubber piece. The brakes seems normal. Just seeing of its normal to see the pin after installing a shorty lever i got from amazon
gixxer6002007 is offline
post #2 of 15 (permalink) Old 05-06-2019, 09:05 AM
A picture or two might be very helpful.
I don't know what pin or rubber you are talking about.
post #3 of 15 (permalink) Old 05-06-2019, 01:05 PM
Also, be very careful with cheap aftermarket brake levers. If they donít fit perfectly, they can apply a small amount of pressure to the system all the time. As you ride the brakes heat up and then you could get a front wheel lock up.
Not a nice thought...
post #4 of 15 (permalink) Old 05-06-2019, 02:09 PM Thread Starter
Ill takr a pictire after work and post it.
post #5 of 15 (permalink) Old 05-06-2019, 05:30 PM
This is what happens when you buy shitty parts. Send those back and buy quality ones.
post #6 of 15 (permalink) Old 05-06-2019, 07:02 PM Thread Starter
Can you see it?
post #7 of 15 (permalink) Old 05-06-2019, 07:25 PM
I'm guessing your mean the pin between the lever and the master cylinder piston. Yes, I see that.
I can't really give any opinion as to whether that should show or not as I just don't know how the lever is designed.
The really important part, as mentioned by a few, is that you didn't need to push the master cylinder piston in to install the lever.
post #8 of 15 (permalink) Old 05-06-2019, 07:44 PM
Originally Posted by gixxer6002007 View Post
Can you see it?
Yes, it looks like what happens when you buy crappy parts that were made using a copy-cat design with zero R&D. They tried copying ASV and failed.
post #9 of 15 (permalink) Old 05-06-2019, 07:48 PM Thread Starter
Can you see it?
So its not suppose to show the pin?
post #10 of 15 (permalink) Old 05-06-2019, 08:15 PM
No, that is not normal.
post #11 of 15 (permalink) Old 05-06-2019, 08:51 PM Thread Starter
Can you be serious. You seem to hate the fact i bought some cheaper aftermarket levers. I need a 2nd opinion if the pin is suppose to shoe on shorty levers
post #12 of 15 (permalink) Old 05-07-2019, 05:32 AM
alik9992004's Avatar
that's why i always use stock levers . try to install cheap levers on mine , after one ride reinstall stocks ...i opinion will be not use cheap china levers .
alik9992004 is offline
post #13 of 15 (permalink) Old 05-07-2019, 10:51 AM
I am being serious, "you [just] seem to hate the fact [that I'm telling you your parts are shit]."
I love when people buy shitty parts and are all surprised that they don't work like they're supposed to. The previous owner of my bike had these crappy levers on, I trashed them and got CRG RC2s and they are vastly superior. The crap levers, which are the same that you have, always felt like they had play (where it almost felt like there was air in the lines) while the CRGs are rock solid with zero play. It's a byproduct of being made by a company that never truly designed it.
The only people that will tell you these are fine are people that have no experience with good levers, and while that may stroke your ego, it's not the advice you want.
post #14 of 15 (permalink) Old 05-07-2019, 08:01 PM
CrickiKaze's Avatar
I'm just going to say that it looks like the barrel is rotated properly to accept that part of the master cylinder. If you rotate the the barrel it should be a 'hole' that is goes into.
The Vagabond
"Be polite, be professional, but have a plan to kill everybody you meet." General James Mattis
If you need a 08-10 750 service manual, I have one for an 08 750.
CrickiKaze is offline
post #15 of 15 (permalink) Old 05-07-2019, 08:05 PM Thread Starter
Parts might not be the ones you get but i dont have any issues with these amazon levers. They work and also ive used cheap after market levers for 4 years and worked fine. All im asking is if the pin is supposed to show that much with the lever installed. I havent rode my bike in awhile and threw away the old ones and cant remember if the pin is suppose to show that much. The pin doesnt kink, it goes in n out smoothly as i press and release the lever. If you had bad experiences with after the cheaper after marlet lever, thats fine, but dont just come shitting on my post because i didnt get the more expensive levers. If you dont know then just stop posting.
How many of you run short clutch lever and long brake lever? 6Gears1Speed Tech and performance chat. 15 08-22-2014 11:35 AM
Gsxr 600/750 06-07 Exhaust, gas cap w/key, Carbon Tank Bra / 07 Gsxr 1000 ASV lever darula8 For Sale 1 03-21-2011 10:34 PM
brake lever stuck out, cant activate front brake. RoadRover Tech and performance chat. 8 10-06-2010 06:05 AM
Rear brake lever for 03 600 Ferris Wanted 3 10-20-2006 03:14 PM
03 600 front brake lever freak_accident Tech and performance chat. 0 04-11-2005 01:34 PM
