Different ECM fitment for 00 GSXR-750 - GSXR.com
post #1 of 6 (permalink) Old 06-16-2019, 07:55 AM Thread Starter
Hi all,
I have an issue with my bike cutting out, refusing to start but does turn over. Either way, i bought a second ECM to eliminate that as an issue. However, although the listing i bought the ECM of said it was for a K1-K3 GSXR 750, the part numbers are different. below are the numbers on the ECM's.
Currently fitted;
32920-35F00
112100-0530
12V NEP041
Purchased ECM;
32920-39F00
112100-0610
12V NEP047
Are there any major differences between the two that would require modifications/ could cause damage, or can it just be plugged in?
I remember with my old bike there were more than 5 ECU's that could be fitted, which all had different restrictions/ ignition timings etc, hence why i'm asking
Many Thanks
Ross
Ross46 is offline
post #2 of 6 (permalink) Old 06-16-2019, 08:41 AM
The 2000 is a 750y the 01 k1 750. The stva is slitely diffrent and the y and k1 fuel pump are a little diffrent. Ones a 3 wire 1s a 4wire I beleive something to do with the fuel level. As far as the ecm it will run your bike just fine with no problem .i had a issue with my 750y and trouble shooting I wound up with 3 computers I had the 2 computers you have and the 04-05 they all ran my bike the same.
post #3 of 6 (permalink) Old 06-16-2019, 05:14 PM
I accually have a 750y computer still for sale, it works as it should. I’m not sure your interested .
post #4 of 6 (permalink) Old 06-17-2019, 03:56 AM Thread Starter
very strange then. I plugged the new ECM into the bike and it straight away caused a misfire. I'm wondering if that is that the ECM isn't compatible, or pointing to my issue/ fault. I had it in dealer mode and no error codes came up?
Ross46 is offline
post #5 of 6 (permalink) Old 06-18-2019, 10:49 PM
mr_hollywood's Avatar
The 39F00 is for a 600. Although a 750 may start and even run with it, it will not work properly and will cause damage in the long term. You need a 35F00 ecu.
Always replace your ecu with the same part number (check the label)...
mr_hollywood is offline
post #6 of 6 (permalink) Old 06-19-2019, 06:16 PM
2000 750 ecm number
