Re-using the old clutch springs + hard shifting - GSXR.com
  • 1 Post By ABbeSkrrting
  • 1 Post By Ozsyd600
post #1 of 7 (permalink) Old 12-24-2018, 02:54 PM Thread Starter
Hey guys, am new around here.
I was wondering if I can reuse the old clutch springs cause I didn’t find any close to me. All I can find is a kit with gasket, fibers and steels but no springs.
My second problem is when I shift from 1st to 2nd is very hard whither its up or down is it because my clutch is damaged or is it because of something else?. Thank u guys
ABbeSkrrting is offline
post #2 of 7 (permalink) Old 12-24-2018, 06:01 PM
coreyyok's Avatar
Did you check the springs with calipers to see if they were all still within oem limits?
Work Hard, Play Harder
coreyyok is offline
post #3 of 7 (permalink) Old 12-25-2018, 05:59 AM Thread Starter
Didnt check yet but is there any symptoms for bad springs? Without opening it? Cause i found EBC kit for sale but alot of people saying the EBC springs are a pain in the a**
post #4 of 7 (permalink) Old 12-25-2018, 09:25 AM
Well, Why did you rebuild the clutch? Was it slipping?
Did you do the 3 point adjustment properly on the old clutch?
Did you know that revving the engine a lot with the clutch pulling in shortens the plates life some?
Yes, if the springs are worn out (provide less tension), then the clutch might slip under load.
Sounds like you might have an adjustment issue?
Sorry if I missed it, but how about an introduction post, year, size of your gixxer, etc.?
post #5 of 7 (permalink) Old 12-25-2018, 11:19 AM Thread Starter
Its a 2007 gsxr 600 it has 30,000 km in good shape but the previous owner is a kid that doesn’t know anything about bikes so he just revs it alot and do wheelies.
Sorry for the lack of info but I was in hurry
Didn’t rebuild the clutch yet am looking for the full kit. The clutch at high rpm slipps at 5th and 6th gear and that was 2 months ago. Last week the clutch slipps in 2nd so I figured change the whole set to avoid in future problems.
Thank u dude for your patience.
post #6 of 7 (permalink) Old 12-27-2018, 01:04 AM
Have you tried shifting up gears without the clutch?
As you accelerate in first, ease off the throttle and knock it into second and then back on the gas. Same for all up shifts. I never used my clutch to change up gears.
As others have said, before spending $ on a new kit, itís worth doing a proper adjustment as per the service manual. PM me your email address and Iíll send you a service manual if you donít have one.
Also, have you changed the oil since you bought the bike? Perhaps the PO used car engine oil in it which can cause slipping in wet clutches. Might be as simple as changing the oil....
post #7 of 7 (permalink) Old 12-27-2018, 07:33 PM
CrickiKaze's Avatar
I have unused/unopened oem springs in the garage somewhere, just need to make sure I have all six.
The Vagabond
"Be polite, be professional, but have a plan to kill everybody you meet." General James Mattis
If you need a 08-10 750 service manual, I have one for an 08 750.
CrickiKaze is offline
Clutch disengagement and hard shifting lordviper13 Tech and performance chat. 14 05-19-2016 05:22 PM
throttle break shifting verses clutch speed shifting hammer9 Drag Racing 4 05-11-2010 12:58 PM
2006 gsxr 600 shifting hard jjcline28 Tech and performance chat. 5 09-02-2009 03:08 PM
Shifting under hard acceleration Psygnosis Tech and performance chat. 9 05-08-2006 11:20 PM
HTML code is On
