How To Change Motorcycle Tires - GSXR.com
post #1 of 2 (permalink) Old 06-29-2017, 07:28 AM Thread Starter
Sponsored Editorial Content
Why would anyone want to change their own tires? Isnít it hard work that usually involves at least one bleeding knuckle? Donít the tools cost a small fortune when you consider that shops only charge about 25 bucks for the service? Well, some riders donít live within a few miles of a bike shop. And some folks, well, theyíve always got to do things themselves.
The good news is that, overworked sweat glands aside, changing tires is relatively easy Ė once you have the right tools. All you really need is a bead breaker, a set of tire irons, some dish soap, and a tire balancing stand.
Begin with your bike on front and rear stands. Once youíve removed a wheel, unscrew the valve core with a valve stem tool. After the tire has finished its lengthy sigh, place your wheel on an old tire or other work surface. Whatever support you use, you want to make sure the wheel is not resting on a brake disc while youíre working on the bead. Discs bend all too easily and are quite expensive.
Read more about How To Change Motorcycle Tires at Motorcycle.com.
Motorcycle.com is offline
post #2 of 2 (permalink) Old 06-10-2019, 12:41 AM
Thank you very much for sharing kindly share one more thing that how to change trailer tire i have a trailer which we use for Rite Way Towing New York. i face some difficulty to change the tire.
martinbrown9271 is offline
