R1 / R6 Throttle Mod Tutorial - GSXR.com
  • 1 Post By Knee Dragger
post #1 of 20 (permalink) Old 06-05-2011, 10:04 PM Thread Starter
Illis quos amo deserviam
Knee Dragger's Avatar
I take no credit for this tutorial but I noticed a lot of people asking from the search so I did some research and found this tutorial for the R6 and another for the R1 So I decided to make a super thread of Both.
This info is from KGIXXER7 from gixxernation.com
The R6 throttle will give you a 1/6th throttle...what I used ...part # 2C0-26240-00-00
-you will have to modify (dremel) your throttle housing to fit the larger cam of the R6 throttle tube. Not alot, but you will have to test it a few times to make sure there is no binding
The R1 throttle will give you a 1/5th throttle...part # 4YR-26240-02-00
-no modding(dremel) will need to be done to your throttle housing with this throttle due to the cam not being as large(but still larger than the stock GSXR) just take old tube off, replace new one and go.
Info and Credit For This Part Of Tutorial goes to Jayonhavok from gixxernation.com
Original Link http://www.gixxernation.com/forums/a...hp/t-7198.html
Enjoy everyone
This is one of the easiest and cheapest mods you can for your GSXR. I spent around $13 for the throttle tube from FunBikeCenter here in San Diego...
Thanks to Rob and Jami for the info!:thumbup
What you will need:
-Philips Screwdriver
-2004 R1 Throttle Tube Part# 4YR-26240-02-00
1: Adjust locknut towards the throttle to allow for slack...
2: Remove screw 1 of 3...
3: Remove screw 2 of 3...
4: Remove screw 3 of 3...now you can open the kill switch housing.
5: Remove Bar End...
6: Use slack to remove throttle cables from OEM throttle tube, and slide the OEM throttle tube off.
7: Install R1 throttle tube into the kill switch housing and insert cables into their respective slots...
8: Reassemble kill switch housing with steps 2-4, but in reverse, and re-insert the bar end. Then readjust throttle cable locknut from step 1.
When you're all done, it should look something like this...
Enjoy! :cheers :lol
K9 600
Yoshi R-55/Yoshi Case Savers
CRG Levers/Driven -1 +2
Bazzaz ZFI/AFM/Z-BOMB
K&N Filter/Evotech Sliders
Spiegler Lines
Puig Z Racing WS
12k HID/R6 Throttle Mod
Knee Dragger is offline
post #2 of 20 (permalink) Old 06-05-2011, 10:22 PM Thread Starter
R6 Dremmel Modding
Pictures from KGIXXER7 from gixxernation.com
*********** FOR R6 MOD ONLY *************
jsmitty6619 likes this.
K9 600
Spiegler Lines
Puig Z Racing WS
post #3 of 20 (permalink) Old 06-05-2011, 10:23 PM
chevyguy4321's Avatar
what does it do?
Bikes
2015 RMZ 450-Dirt Devil
2013 Ninja 300-The Putter
2011 GSXR 750-Track only
2001 GSXR 600-sold
1998 GSX 600-sold
Cage
2013 Silverado 2500HD
MPG wins 9
chevyguy4321 is offline
post #4 of 20 (permalink) Old 06-05-2011, 10:32 PM Thread Starter
Originally Posted by chevyguy4321 View Post
what does it do?
Better throttle response and less of a turn to WOT
K9 600
Spiegler Lines
Puig Z Racing WS
post #5 of 20 (permalink) Old 06-05-2011, 11:39 PM Thread Starter
What do you all think of this tutorial and or any advice to make it better? I want to get this Sticky worthy so help and advice is appreciated
K9 600
Spiegler Lines
Puig Z Racing WS
post #6 of 20 (permalink) Old 06-06-2011, 10:32 AM
fireman's Avatar
Looks good to me. Ima try this on the new to me k6 I'm about to buy. This should put me right back at home, since my previous bike was an r1.
"The Force is strong with this one"
fireman is offline
post #7 of 20 (permalink) Old 06-06-2011, 11:19 AM
outlaw750's Avatar
looks good to me - great mod for the $,great write up, I did the r6 swap back when I first started stunting out my 750 and by far one of my best mods for this bike
Click Here~> -REAL RECOGNIZE REAL AND YOU DONT LOOK FAMILIAR
Be Good Or Be Good At It
outlaw750 is offline
post #8 of 20 (permalink) Old 06-06-2011, 11:22 AM
Great post thanks..
OUTINFRONT is offline
post #9 of 20 (permalink) Old 06-06-2011, 11:38 AM
If you use the R6 on the 2006+ 750, the cables will be just slightly too short. If you have that combo, and turn the bars fully to one side, the throttle doesn't snap back quite right. I solved this by grinding off the adjuster lock nuts on the injector side of the cable to make them thinner.
Some people have just left it, but I feel that it is important to have the throttle return properly.
Using the R1 throttle tube, you will not have this problem.
Zippy is offline
post #10 of 20 (permalink) Old 06-06-2011, 12:13 PM
outlaw750's Avatar
good note I flipped and switched my clip ons so I did not need to do this for my k6 750
post #11 of 20 (permalink) Old 06-06-2011, 12:19 PM Thread Starter
I feel this is Sticky Worthy!!!
K9 600
Spiegler Lines
Puig Z Racing WS
post #12 of 20 (permalink) Old 06-06-2011, 12:35 PM
strictlye's Avatar
I did the R1 throttle tube swap and I can't say I notice a difference.
strictlye is offline
post #13 of 20 (permalink) Old 06-06-2011, 12:53 PM Thread Starter
The R1 tube is a slight difference the R6 is a noticeable difference
K9 600
Spiegler Lines
Puig Z Racing WS
post #14 of 20 (permalink) Old 06-06-2011, 02:03 PM
tls2death's Avatar
I did the R1 throttle and then zip-tie on top of it. It's noticeable
2007 GSX-R 600 Red/White
Bitches love red
tls2death is offline
post #15 of 20 (permalink) Old 06-06-2011, 09:25 PM Thread Starter
TTT
K9 600
Spiegler Lines
Puig Z Racing WS
post #16 of 20 (permalink) Old 06-06-2011, 10:57 PM
BaDAZ
GixxerRdr4Life's Avatar
Nice write-up, probably going to do this when i get back!
K7 Gixxer 6
Blk/Blue
Yosh R-55
Puig Double Bubble Dark Smoked Screen
Smoked Rear Turn Signals
8000K H.I.D's
EBC HH Pads
"I didn't say it was your fault, I said I was blaming you."
GixxerRdr4Life is offline
post #17 of 20 (permalink) Old 06-06-2011, 11:00 PM
Live Fast Die FUN
SRAD600's Avatar
I did the r6 tube last year, or maybe 2 years ago. One of my favorite mods and yet I forget about it all the time, which actually makes it better in my eyes.
I did not have to dremel anything btw.
GSXR.com Moderator
SRAD600 is offline
post #18 of 20 (permalink) Old 06-06-2011, 11:16 PM Thread Starter
Moderator... I dub this Stickyness worthy!! I approve and have approval of my fellow GSXR family
K9 600
Spiegler Lines
Puig Z Racing WS
post #19 of 20 (permalink) Old 06-12-2011, 10:02 PM Thread Starter
Ttt
K9 600
Spiegler Lines
Puig Z Racing WS
post #20 of 20 (permalink) Old 06-21-2011, 02:33 PM
sluggy's Avatar
I don't know I just did the r1 mod on my 01 600 and I noticed a big differamnce in trottle response. And the only thing I see is the thing is smaller over the stock one so the handle bar is a bit longer. The the tube picture will be up after I get off work
sluggy is offline
R1 or R6 throttle mod? elitopus Tech and performance chat. 114 02-05-2014 02:47 PM
R1/R6 Throttle Mod nick357 Tech and performance chat. 13 09-10-2013 04:44 AM
FS R6 to GSXR Caliper Conversion Spacers and R6/R1 Calipers - R6/R1 Calipers - EBC HH antor1 For Sale 4 02-13-2012 02:30 PM
R1 Throttle Mod OR Hrc Throttle Kit trancedmp3 Tech and performance chat. 33 12-01-2009 06:51 PM
R1 throttle tube mod makes throttle stick open Jersey5.0 Tech and performance chat. 16 01-25-2009 05:10 PM
You may not post new threads
You may not post replies
