Loosing engine oil 750k1 - GSXR.com
post #1 of 7 (permalink) Old 07-28-2019, 05:18 AM Thread Starter
Is it common on k1 750 loosing quite a bit oil after every few hundred miles, when bike in the garage do not see any evidence of oil leak. Any Help would be appreciated
sergio101ster is offline
post #2 of 7 (permalink) Old 07-28-2019, 05:37 AM
No that's not normal.
Is there oil on the air filter or in the air box?
Winchester Boy is offline
post #3 of 7 (permalink) Old 07-28-2019, 06:11 AM Thread Starter
Have not checked to be honest, will do.
If is got oil in the airbox/filter, what causing it?
Thanks
post #4 of 7 (permalink) Old 07-28-2019, 06:18 AM
Thanks
It would be sucking oil from the crankcase through the intake.
John or one of the others can speak about it better than me.
You should also pull the spark plugs.
post #5 of 7 (permalink) Old 07-28-2019, 12:54 PM
First, are you sure you are not overfilling the oil? With the bike leveled, 1/2-3/4 in the window is fine.
The oil is either leaking out, which you say it isn't, or the engine is burning it. Is it making blue smoke?
It could be forced into the coolant system but you would have some serious other symptoms by now.
post #6 of 7 (permalink) Old 07-29-2019, 11:25 PM Thread Starter
Have not seen any blue smoke.
And oil level was always between min and max level when I filled it up, got my garage ( they did forks on it) after I did oil change on it and they said ohh your oil level was low so we filled it up( could not see through the oil level “window”) so I drained a bit out...
post #7 of 7 (permalink) Old 07-30-2019, 05:00 AM
Check your coolant, check your spark plugs. The oils going somewhere . How fast does it disappear ? Are you checking the oil level at around the same engine temp? You could get a diffrent reading if you check when the engines hot and if you check when it’s cold. Also my 750 would smoke sometimes at first start up on the day once it warmed up it was fine. I would check the oil often but it only needed once a month less than 1/2 quart it did not bother me I would just check the level more often.
