Leak?normal? - GSXR.com
post #1 of 6 (permalink) Old 09-05-2019, 11:15 PM Thread Starter
Leak?normal?
I have a 2013 gsxr 600 and just noticed what looks like oil near the shifter or out a screw on bottom of housing and my bike has only 8300 miles on it any idea what and why that could be
Trillchase85 is offline
post #2 of 6 (permalink) Old 09-06-2019, 02:54 AM
Is it close to the front sprocket?
RockerGuy is online now
post #3 of 6 (permalink) Old 09-06-2019, 04:42 AM
Welcome.
The most common cause of a "leak" in that area is slung chain lube. Clean the area thoroughly and watch it for awhile.
post #4 of 6 (permalink) Old 09-09-2019, 11:41 AM
+1
We need a better description than "screw on bottom of housing". A pic or reference to a drawing in the parts fiche would help. Some screws have sealing washers.
As I recall, the transmission countershaft on my K6 1000 has a seal that is known to leak and replacement requires splitting the crankcase. It's close to the sprocket. But I think that they've redesigned that area on newer models to make replacement easier.
post #5 of 6 (permalink) Old 09-12-2019, 07:25 PM Thread Starter
This is where its dripping from and if i have to replace the seal which i just picked up yesterday will the oil and coolant drain out when i do and do i need new oil and coolant?
post #6 of 6 (permalink) Old 09-13-2019, 02:45 AM
Jimmy boy's Avatar
Originally Posted by billv View Post
+1
There is a seal from the clutch rod on my 03 1000 that requires the case to be split . Not sure about counter shaft though. Definitely a bad design on suzooks part.
Jimmy boy is offline
